Anyone had any experience with a Marantz NA6006 Network Audio Player vs Bluesound NODE 2i?
I was wondering if anyone had any experience with a Marantz NA6006 Network Audio Player vs Bluesound NODE 2i?
As big as a Marantz fan as I am, I would choose the Node 2i myself for a streamer between the two.Home Theater
Why do you say that, have you heard both of them?
Not saying you are wrong, just curious why.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream -
I had a NA6005 and returned it. It sounded good but it didn't play many of the files that I have even thought the specs said that it would. I would imagine the 6006 is an improvement. Don't know the Node.
I have a friend that had that Marantz he didnt keep it long and ended up with a Bluesound Vault. Only Piece of Marantz equipment I didnt like.Home Theater
OK, thanks.
From what I have read, the 6006 is an improvement over the 6005. I read a review of a person who had both.
I had read some reviews on the node and some liked it and others didn't like the way it sounded.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream -
The Node 2 is a nice player well built and sounds great. I have not messed around with the Marantz. The best way to really decide on one of these streamers is to look over compatibility with what you want to use and go that route.Dan
Or you could spend a tad more and get a Cambridge CXN.....
Would blow both of the others away ...
BkPS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO -
Bk
Yet the OP didn't put the Cambridge CXN into the equation, the ones I've heard sound to sterile and clinical. If he was to spend what the CXN costs it is discounted l beleive, then he might as well spend a little more and get an Auralic and call it a day.Home Theater
Thanks for the opinions, but the others aren't in the budget at this time.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream
I would grab that Bluesound 2i if you have a separate Dac that's better, then good for you, if not the onboard Dac is good enough for the price plus if you stream Tidal its MQA compatible. Try it out it would be easy to sell should it not suit your needs.
OK, I don't have a separate Dac.
I have also read some comments about Cambridge CXN sounding to sterile and clinical. I haven't heard one.
I haven't decided if I'm going to get the Bluesound or wait awhile and maybe see what's available in the used market.
I also haven't tried to sell my B&K Ref 4420 or Parasound Zphono USB Phono Preamp yet.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream -
Take a close look at the control apps of the players that you are considering. There are major differences in terms of how intuitive their UI is, etc. HEOS, BluOS, and Cambridge Stream Magic would be the three to compare.
My friend had a heos and bought a bluesound to replace it, the bluesound sounded way better than the heos. Both his and my bluesound node 2 both have problems with the app not working locking up. You pick a song sometimes and it takes about 20 seconds or more fore it to play, sometimes I have to exit the app several times to get it to work. Hopefully the 2I is better.
Ordered the Bluesound node 2i and will get an better Dac later.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream
