Anyone had any experience with a Marantz NA6006 Network Audio Player vs Bluesound NODE 2i?
Milito
Milito Posts: 2,003
I was wondering if anyone had any experience with a Marantz NA6006 Network Audio Player vs Bluesound NODE 2i?
    gudnoyez Posts: 8,213
    As big as a Marantz fan as I am, I would choose the Node 2i myself for a streamer between the two.
  • Milito
    Milito Posts: 2,003
    Why do you say that, have you heard both of them?
    Not saying you are wrong, just curious why.
  • afterburnt
    afterburnt Posts: 7,892
    I had a NA6005 and returned it. It sounded good but it didn't play many of the files that I have even thought the specs said that it would. I would imagine the 6006 is an improvement. Don't know the Node.
    I have a friend that had that Marantz he didnt keep it long and ended up with a Bluesound Vault. Only Piece of Marantz equipment I didnt like.
  • Milito
    Milito Posts: 2,003
    edited May 2020
    OK, thanks.
    From what I have read, the 6006 is an improvement over the 6005. I read a review of a person who had both.
    I had read some reviews on the node and some liked it and others didn't like the way it sounded.
  • mantis
    mantis Posts: 17,669
    The Node 2 is a nice player well built and sounds great. I have not messed around with the Marantz. The best way to really decide on one of these streamers is to look over compatibility with what you want to use and go that route.
    Dan
  • gyosa
    gyosa Posts: 770
    Or you could spend a tad more and get a Cambridge CXN.....
    Would blow both of the others away ...
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
    edited May 2020
    gyosa wrote: »
    Bk
    Yet the OP didn't put the Cambridge CXN into the equation, the ones I've heard sound to sterile and clinical. If he was to spend what the CXN costs it is discounted l beleive, then he might as well spend a little more and get an Auralic and call it a day.
  • Milito
    Milito Posts: 2,003
    Thanks for the opinions, but the others aren't in the budget at this time.
    edited May 2020
    Milito wrote: »
    I would grab that Bluesound 2i if you have a separate Dac that's better, then good for you, if not the onboard Dac is good enough for the price plus if you stream Tidal its MQA compatible. Try it out it would be easy to sell should it not suit your needs.
  • Milito
    Milito Posts: 2,003
    edited May 2020
    OK, I don't have a separate Dac.
    I have also read some comments about Cambridge CXN sounding to sterile and clinical. I haven't heard one.
    I haven't decided if I'm going to get the Bluesound or wait awhile and maybe see what's available in the used market.
    I also haven't tried to sell my B&K Ref 4420 or Parasound Zphono USB Phono Preamp yet.
    Clipdat Posts: 13,104
    Take a close look at the control apps of the players that you are considering. There are major differences in terms of how intuitive their UI is, etc. HEOS, BluOS, and Cambridge Stream Magic would be the three to compare.
  • invalid
    invalid Posts: 1,559
    My friend had a heos and bought a bluesound to replace it, the bluesound sounded way better than the heos. Both his and my bluesound node 2 both have problems with the app not working locking up. You pick a song sometimes and it takes about 20 seconds or more fore it to play, sometimes I have to exit the app several times to get it to work. Hopefully the 2I is better.
  • Milito
    Milito Posts: 2,003
    edited May 2020
    Ordered the Bluesound node 2i and will get an better Dac later.
