First system
Here's the thing, I drilled a hole in the base and the platform to run the speaker wires through. I even stuck 1/4 inch feet on the 40s so the wire would run under it to the binding posts.
Well you can seal the bottom wire hole with some epoxy putty. As long as you can still remove the top shelf you should be able to fill the stands from above.
PS: the epoxy putty from Harbor Freight is cheaper than the stuff from Home Depot and fine enough for this task of sealing around the wire.George / NJ
Crown D150 amp
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Nice standsWhen I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
Best thing to do is just listen to it and enjoy. Rome wasn't built in a day.
mcphatty00 wrote: »Here's the thing, I drilled a hole in the base and the platform to run the speaker wires through. I even stuck 1/4 inch feet on the 40s so the wire would run under it to the binding posts.
Yeah, you could epoxy or glue, or even stuff foam in around the cable over the bottom hole.
Say you had 1-2" tall foam or a sponge. Just cut a slit in it to the center-ish area and wrap the cable like a taco 🌮. Reassemble the bottom, stuffing the foam/sponge to fit, turn stands upright, and fill.I disabled signatures. -
I get amped up reading threads like this, it reminds me of when I put my first HT together (though I spent more on my R50s than he did for his whole setup).
I would enjoy it as it is for now, as @willow said, Rome wasn't built in a day.
And welcome to the asylum!So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
I get amped reading this thread when I look at this mess.
And that's not all of it. -
Personally I'd focus on obtaining stands and working with what you got.
Welcome To Club Polk
Your LCR tweeters as close to ear level as possible.
I believe Mantis would advise your surrounds:
1. go out more to the side,
2. a bit further away, ~5-6’ if possible
3. just behind you (~110 degrees)
4. pointing down into the listening area
I hope he chimes in to correct. Can’t say on that rear center
TonySamsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work -
Tony
I have the rear center because, just by chance, I bought a used receiver that featured 6.1. -
Got the 30s down at ear level.
Exponentially better. I clearly wasn't hearing the surrounds before, except in extreme instances. The rear center, although it looks too high, is strong.
Is there such a thing as a rear center option on an amp?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Thanks. Learn something new every day.
Out of curiosity, what is it for? Is there rear dialogue with 6.1?Lumin X1 file player, Westminster Labs interconnect cable
While it's fine for movies, I find it outstanding for music. I have two music performance degrees and I can hear a great deal more with it. -
Interesting. I know there is some music done in 5.1, but never heard of 6.1 music. What would be a good 6.1 CD? I need to start using my HT again.Lumin X1 file player, Westminster Labs interconnect cable
My last Rotel could do 5/6/7 channels.
Can’t recall if the “middle surround” was was a true rear center & it didn’t work all the time. The wife, at one point had me put my LCR and tv in a corner forcing adding a six channel to fill the hole. Please don’t laugh: like the same day God provided. Found someone selling a single new RTi A1* on eBay for, I think $50 including shipping
* using 2 for surrounds at the time
Also I recall reading somewhere, in the days prior to 7.X, if you routed your surround’s pre-outs through an older analogue pre/pro’s LR channel inputs, you could extract a Rear Center.
OP: I think your L&R surrounds need to be a little more to the rear pointing towards you, but you’re satisfied😊...
Ok, I did what I didn't think I would. I found a pair of Monitor 70s for $140 that were 5 minutes away. I got them and moved the 40s to the surround spots. Honestly, I probably wasn't going to rest until I did this.
mcphatty00 wrote: »Ok, I did what I didn't think I would. I found a pair of Monitor 70s for $140 that were 5 minutes away. I got them and moved the 40s to the surround spots. Honestly, I probably wasn't going to rest until I did this.
Sweet! Now you really need more power for those big boys!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
They're currently working and sounding rather solid. I'll just have to be on the lookout for a badder unit. -
mcphatty00 wrote: »Ok, I did what I didn't think I would. I found a pair of Monitor 70s for $140 that were 5 minutes away. I got them and moved the 40s to the surround spots. Honestly, I probably wasn't going to rest until I did this.mcphatty00 wrote: »They're currently working and sounding rather solid. I'll just have to be on the lookout for a badder unit.
Less than 3 weeks in and already planning on upgrading. It's official, we have another convert.
Truth!
Maybe someone can answer this. It goes across all the models and apparently lines. For example, Monitor 30s have 1 tweeter but so do Monitor 70s. Why?
That's all that's needed.
Because two would be outrageous!
joecoulson wrote: »Because two would be outrageous!
Tekton Moabs. Never heard them but there is plenty of buzz on them ( good and bad) in our hobby.
