Does It Really Get Better Than This
  • Sprags
    edited June 2013
    Who needs a sound source?...having an ultimate system has nothing to do with actually listening to musics...Everyone knows its really about having more expensive stuff compare the other members. Shame on you.
    Years ago I worked with a guy that also had a Harley. One day he made a comment that sounded something like this: I hate riding this bike because when I do it means I need to clean it.
    edited June 2013
    Whatever you are smoking, stop.
    edited June 2013
    Sprags wrote: »
    Wow.....now there's one for the record books. Move over T-unit. :biggrin:
  • thor098
    edited April 2014
    Well, it's been another year again. I still have the same system - no extra spending money. The LSI's continued to break in. The harsh highs continued to mellow and the soundstage continued to get more detailed and three dimensional. I can still tell that they could use more power. They don't come to life until you turn them up a bit.
    2 CH
    Parasound 2100 preamp
    Polk Lsi15s
    powered by a
    Parasound HCA 1500a
    2 Passive JBL 10" Subs
    powered by a second
    Parasound HCA 1500a
    HT
    Denon 3311-CI
    Polk Lsi15 Fronts
    Polk LsiC Center
    Polk Lsi7 Surrounds
    2 Passive Polk 10" Subs
    powered by ADCOM 545
  • thor098
    I have to first say I can’t believe it’s been 7 years. I have since change my 2 channel system to magepans. Love them but they do have their drawbacks. I moved my LSi 15s with lsi 7s and the center match to my surround system and love them. Could not be happier. Thoughts about replacing my magnepans with lsim703s. I like the sound of my lsi7s on my 2 channel system. I have good subs.
    2 CH
    Polk Lsi15s
    powered by a
    Parasound HCA 1500a
    powered by a second
    Parasound HCA 1500a
    HT
    Denon 3311-CI
    Polk Lsi15 Fronts
    Polk LsiC Center
    Polk Lsi7 Surrounds
  • BlueFox
    Seven years and only 38 posts. You need to stop spamming the forum. :)
  • dhart86
    YOU NEED A GOOD DAC for good digital music to sound best. PS audio perfectwave MKll or dsd jr. Forget the CD player and other upgrades until you get a good dac since you like the convenience of digital
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
  • halo
    edited May 2020
    dhart86 wrote: »
    Thankfully, you don't necessarily have to spend a lot to get a good DAC these days (check out https://audiosciencereview.com/forum/index.php?reviews/ and you'll see what I mean). And, the DAC built into the streamer may be better than you think. I had the good fortune to try out a Benchmark DAC3 in my setup for several months. I discovered no audible difference between it and the built-in DAC on the Bluesound Node 2i. I also tried a Micromega MyDAC for a while and, again, no audible difference to my ears. However, the MyDAC measures considerably better than the Node 2i so I can easily leave it in the setup if I want to "cover my bases." I will give the Topping E30 a try since it measures so well and it is such a bargain. Not expected to arrive until the end of July though.
    Of course, we all hear/experience things differently so YMMV.
  • You need to get some tubes in the mix somewhere...
  • xsmi
    See, that's why he only has 38 posts. Every time he posts, we spend his money! 😂
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • afterburnt
    edited May 2020
    To answer the OP's original question, no. If you are over 25 it doesn't get any better than this. Since you posted this seven years ago you are probably over 25 by now and it has gotten so bad that you can't remember it being better than this but it was. The best years of your life are way behind you.
  • ptrooper
    @afterburnt ,You Mean,,"The best ears of your life " are way behind you :)>
    ZLTFUL wrote: »
    So the thing I find suspect about lists like this is that they include the Apple Lightning to 3.5mm dongle in their "Audio DAC Performance Index" and review it as such.
    But it is literally in no way shape or form a DAC at all. The USB-C/Lightning/Thunderbolt connectors have provisions for analog signal transmission built into them and the DAC is whatever device they are being plugged into. So the review/information being shared is whatever device the dongle is being plugged into. To call the dongle itself a DAC is asinine at best. It makes me wonder what else in their reviews are questionable...
    You should definitely contact Amir to let him know this and then post his response here. https://www.audiosciencereview.com/forum/index.php?misc/contact/
    Well it sounds like that went well. :#
