polk crs
  • lucasalt56
    F1 and other friends on this page! I just tried to see the center of the stuck magnets and I got a flashlight !! it really is glued !!! I will have to repair this week and I will be showing photos !! thank you very much to all of the group !! they are geniuses !! your advice helped me a lot! Greetings and thanks to all!! I will post more photos of the work !! greetings friends
  • lucasalt56
    Hello people!! I had to disassemble the speaker Would it look good or is it better to buy a new one? I run some risk that it sounds bad !! What details should I take into account with disarmament? the price of disarmament in my country is around 30 usd the 4 repaired !! regards
  • lucasalt56
    a complete disarmament was done !! the coils are perfect! They are only frozen as you said !! thanks greetings
  • RandyCroissant
    You can repair them! Do a search here. I have not tried it myself however it has been done with success many time, good luck
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • lucasalt56
    thnks !! randy!!
  • Sound_Recluse
    If those drivers are mw6503 then they are 8 ohm speakers. Check the ohm readings with a meter and make sure they are good. Should ohm out at 7 to 7.5. If they dont they are bad. There are plenty of mw6503 on ebay right now
  • lucasalt56
    lucasalt56 Posts: 30
    Hello!! I always thought they were 6! are the 8? thanks greetings
    F1nut Posts: 52,167
    The nominal rating for the speaker is 6 ohms. The driver is supposed to be rated at 8 ohms.
  • lucasalt56
    I have a yamaha rxv 365 with two inputs of 8 and 6 ohms !! I connect to the 6 ohms channel! was that good? greetings friends thank you ...
    Clipdat Posts: 13,101
    lucasalt56 wrote: »
    Those markings are just letting you know the speaker impedance range supported by your Yamaha receiver. Hook the speakers up to the larger binding posts labeled Front L and R.
  • lucasalt56
    perfect!!!!!clipdat!!! tnkss!!! :)
    So what ended up happening with the woofers?
  • lucasalt56
    !! hello everyone I comment on the repair of the woofers! I managed to repair two .... they sound a thousand times better! It was repaired without changing anything, everything was pasted again !! I am just afraid to make it sound !! for knowing that it was repaired! and two others do not sound good I will have to buy full !! it could not stick so well and it does not sound good !! makes some squeals !!! greetings thanks friends! having 100% of the polk I make a video !! regards
  • lucasalt56
    the same original cones were glued again !!! they carefully pulled out and stuck the same cone !! Do you think you should buy that two new damping cones? they sound good nothing else I do not know if they will last !! Thank you
  • lucasalt56
    two woofer the cones I think they were not glued well and no longer serve to re-glue! they sound bad!
  • lucasalt56
    https://youtu.be/gF2uq_w5-Ow hello friends of polk !! almost perfect !!! the wofers repaired !! 1 woofer makes a noise that is almost impossible to hear !! but the most super !! Now if you notice the difference of what these speakers sound like !! thanks friends greetings !!!
    pitdogg2 Posts: 27,581
    Very nice set up.
  • lucasalt56
    tnks !!!! pitdogg2
    Very cool wall mount turntable shelf. Glad your speakers are sounding better!
    Tony M Posts: 11,876
    great. :)
    The video's sound sounded great.
    Did you take any pictures of the repairs in progress?
