polk crs
F1 and other friends on this page! I just tried to see the center of the stuck magnets and I got a flashlight !! it really is glued !!! I will have to repair this week and I will be showing photos !! thank you very much to all of the group !! they are geniuses !! your advice helped me a lot! Greetings and thanks to all!! I will post more photos of the work !! greetings friends
Hello people!! I had to disassemble the speaker Would it look good or is it better to buy a new one? I run some risk that it sounds bad !! What details should I take into account with disarmament? the price of disarmament in my country is around 30 usd the 4 repaired !! regards
a complete disarmament was done !! the coils are perfect! They are only frozen as you said !! thanks greetings
You can repair them! Do a search here. I have not tried it myself however it has been done with success many time, good luckYamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
thnks !! randy!!
If those drivers are mw6503 then they are 8 ohm speakers. Check the ohm readings with a meter and make sure they are good. Should ohm out at 7 to 7.5. If they dont they are bad. There are plenty of mw6503 on ebay right now
Hello!! I always thought they were 6! are the 8? thanks greetings
The nominal rating for the speaker is 6 ohms. The driver is supposed to be rated at 8 ohms.Political Correctness'.........defined
President of Club Polk -
I have a yamaha rxv 365 with two inputs of 8 and 6 ohms !! I connect to the 6 ohms channel! was that good? greetings friends thank you ...
lucasalt56 wrote: »I have a yamaha rxv 365 with two inputs of 8 and 6 ohms !! I connect to the 6 ohms channel! was that good? greetings friends thank you ...
Those markings are just letting you know the speaker impedance range supported by your Yamaha receiver. Hook the speakers up to the larger binding posts labeled Front L and R.
perfect!!!!!clipdat!!! tnkss!!!
So what ended up happening with the woofers?
!! hello everyone I comment on the repair of the woofers! I managed to repair two .... they sound a thousand times better! It was repaired without changing anything, everything was pasted again !! I am just afraid to make it sound !! for knowing that it was repaired! and two others do not sound good I will have to buy full !! it could not stick so well and it does not sound good !! makes some squeals !!! greetings thanks friends! having 100% of the polk I make a video !! regards
the same original cones were glued again !!! they carefully pulled out and stuck the same cone !! Do you think you should buy that two new damping cones? they sound good nothing else I do not know if they will last !! Thank you
two woofer the cones I think they were not glued well and no longer serve to re-glue! they sound bad!
https://youtu.be/gF2uq_w5-Ow hello friends of polk !! almost perfect !!! the wofers repaired !! 1 woofer makes a noise that is almost impossible to hear !! but the most super !! Now if you notice the difference of what these speakers sound like !! thanks friends greetings !!!
Very nice set up.
tnks !!!! pitdogg2
Very cool wall mount turntable shelf. Glad your speakers are sounding better!
great.
The video's sound sounded great.
Did you take any pictures of the repairs in progress?Most people just listen to music and watch movies. I EXPERIENCE them.
