Billet SDA-CRS terminal plates
  • motorstereo
    motorstereo Posts: 2,428
    xschop wrote: »
    Would these work on my 1.2tl's with the neutrik holes?
    Absolutely, I'll supply the stainless neutrik mount screws
    Awesome; I'm in for a pair then
  • motorstereo
    I wouldn't trust myself anywhere near them with a battery powered drill. Hopefully the extra holes can be done properly?
    xschop Posts: 5,931
    No problem as you can still drill them with extra holes. I designed them with extra area just for that.
    This is my last set for a couple weeks and my Hurco CNC mill is set up for another operation at the moment.
    xschop Posts: 5,931
    For future reference, what would be the ideal (most used) terminal positioning for the two extra terminals? Right now they are set at 5 and 7 o'clock. I can either make the extra two holes at 3 and 9 o'clock..... or 11 and 1 o'clock.
    F1nut Posts: 52,406
    My 2 cents...11 and 1. My other 2 cents....keep the mounting holes in the original configuration.
  • CH46E
    CH46E Posts: 3,595
    They look so nice it's a shame to put them in the back. Maybe move them to the front! Lol
  • motorstereo
    This is what I plan on doing. Jesse do you remember if the binding posts you installed will fit these plates or do I need longer ones? Hopefully they'll fit.
    F1nut Posts: 52,406
    You'd need longer posts with xschops' plates.
    pitdogg2 Posts: 27,921
    yes somewhere once upon a time he mentioned the Cardas long post for length.
  • motorstereo
    Dammit; Well that project just got put on hold indefinitely.
    xschop Posts: 5,931
    Will the Cardas short posts install properly thru 1/4" thick plate? And what is the washer diameter that will set on the backside?
    On my next batch, I can leave the baffle hole centering step and router out 1/4" more depth.
    F1nut Posts: 52,406
    xschop Posts: 5,931
    Thanks F1, now I remember that drawing. I'm not so sure that 1/4" depth would even allow for these short Cardas posts to fit. The drawing doesn't show the plastic spud mount depth that goes into the plate.
    That said, I still have this set available for LONG Cardas posts.
  • Gardenstater
    Gardenstater Posts: 4,991
    I measured mine, which I haven't installed in my 7B's yet. The plastic boss is about 0.058", and the extension of the threads is about 0.400" past the plastic. The plastic washer + Nut measured 0.302".
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,931
    So what is the THICKEST plate the short ones can mount through?
  • Gardenstater
    edited April 2020
    With the existing supplied nylon washer, only 0.156". But that washer is pretty darn thick at 0.158". So if you used a 1/16" nylon washer, you could have a 1/4" thick plate.
    It would need to be a special washer that has a 0.50" dia. boss on it to maintain electrical insulation when mounted on an aluminum plate.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,931
    edited April 2020
    Thanks Gardenstater. I'll definitely revise the next batch then.
  • motorstereo
    Sadly I had to pass on these plates. Between me wielding a drill for the extra holes and undoing Jesse's work on my Cardas posts I decided it would be in my best interest to leave things alone. Good luck to you xschop on your next batch.
    xschop Posts: 5,931
    No problem motorstereo. I can't find the old posts either where we discovered only the long Cardas posts would work.
    I am willing to trade this last 1/2" thick set for a pair of MW6503's or pair of MW6510's.
    Just PM. Thanks, Rob
    xschop Posts: 5,931
    New design batch is done. I have nylon washers to go with them so Cardas short posts can be used...
  • Nesmith98
    Nesmith98 Posts: 225
    Nice job.
    Did you use any type of CAM software to program these?
    Outstanding work!
    xschop Posts: 5,931
    These had to be done on the CNC lathe and CNC mill. Both are conversational programming.
    Microsoft Paint was used lol.
    xschop Posts: 5,931
    edited March 13
    Going to build another set for myself soon.
    If you want a set, chime in and I'll make another batch in @ 4-5 weeks
    Pricing is $175/pair shipped US-48 and Alaska ONLY.
    EDIT: These fit ANY SDA or Monitor/RTA if I omit the Neutrik spot.
