Time to get to work on the Grundig!
afterburnt
I hope this stuff works. I was genuinely perplexed, I thought my Grundig was melting or something. Thanks to the internet I know I am not the only one with this problem.
https://swling.com/blog/2018/08/etons-solution-for-sticky-radios/
Your Grundle?
@Clipdat no, it's a cool little radio that the manufacturer coated with some compound that over time turned into schmutz. It's so sticky that you have to wash your hands after touching it.
I hate that schmutz, I know exactly what you're talking about.
You have one of the affected radios? Evidently it was a pretty widespread problem affecting many models.
https://swling.com/blog/2012/12/mikes-solution-for-sticky-radios/ -
Not familiar with that particular radio, but am familiar with things getting that sticky schmutz on them after several years.
Really? I never saw anything like this before. Someone in one of those links said it was to provide a good grip. Mine is so sticky you almost have to shake it off of your hand to put it down.
Perhaps if you showered more than waiting for a court order to force you to....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
afterburnt wrote: »
My go to goo and grease remover. Be careful, it will suck all the oil out of your skin. Wear gloves.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Yeah, what Dave said. Also, careful because it can stain or discolor metal if you use it full strength or leave it sitting too long.I disabled signatures.
Be careful, if it stays purple for more than four hours call 911.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
– Kevin Alfred Strom -
westmassguy wrote: »afterburnt wrote: »
Just a little heavy on the TMI side for me...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
nooshinjohn wrote: »westmassguy wrote: »afterburnt wrote: »
That's not what I've heard John
