Common Ground Issue?
  • I got my upgraded 2.3's with new Polk tweeters and David Shirly upgraded crossovers for a very reasonable price as well so maybe I will do it.
    I don't even have $1k in the amp and speakers.
    What really is going to be the difference? Does it have less to do with the common ground issue than I am reading into it? I think I read it will work well with non SDA speakers too.
    F1nut Posts: 51,750
    The difference? Mo' better sound.
    You mis-read. Using the Dreadnought with common ground amps also results in mo' better sound. There's absolutely no reason or for that matter, no way to use the Dreadnought with non-SDA speakers.
  • I was just going through the paper work I received when I bought my 2.3's and came across the paper work from the crossover work.
    Looks like Dave offers a prebuilt unit. I will have to contact him to see what was actually done to my crossovers as well
  • monepolk
    monepolk Posts: 1,154
    ^^And a Dreadnaught
    pitdogg2 Posts: 27,035
    edited March 2020
    OK STOP Dave put neutrik sockets and made a cable which now means that the linked dreadnought is NOT plug and play.
    You would need a new case or drill that one for neutrik connections and buy neutrik ends for the cable. Which also means either solder new connection or strip and re-terminate with quick connect.
    Best bet is to contact @westmassguy and work a deal for him to maybe build one for you.
  • westmassguy
    westmassguy Posts: 6,850
    That's a four year old QUOTE Ivan. All I did for the original owner was rebuild the crossovers. The binding posts were not touched, nor were SpeakON sockets or a new Interconnect ever furnished.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    Thanks Dave read what I could. I misinterpreted that you made new cable and connection.
    Then the linked is still an option.
  • I only posted that picture to show that someone might be selling prebuilt units. The availability of new complete units for sale was in question. I should have blurred the prices.
