I've tracked down a local set of SDS SRS... cover me, I'm going in!
  • Polar
    Polar Posts: 70
    edited March 2020
    Since you have never tried spikes on floor standers it's all about coupling, so the speakers don't rock/move. That's not move as in from their position.
    Spiking results in tighter bass and cleaner mids. You should try it.
    I already did in the early 90s. It didn't work well for me. I had a pair of highly custom two stage speakers, a separate woofer cab topped with what the builder called a "time aligned modified D'Appolito configuration". They sounded good at his demo room, sounded bland at my home, especially with the Hafler driving them. The top box stood on some extremely dense spikes.
    When I bought my B&W speakers I dismantled the D'Appolito specials, threw everything out but kept the spikes. We used TipToes for the turntables in our store when they first came out, and they did a good job. I figured I'd put them to good use when I got my next turntable. Flash forward 25 years and I finally did. As soon as I have the chance to get some MDF and make a proper bed for that table, I'll make sure to use these spikes. (The only time I'll ever allow MDF into any of my projects again, I think.)
    If you aren't satisfied with the sound, speakers on stands should be decoupled from the plate. Some use Blu-tack while others use pads. The stands should be mass loaded and spiked.
    FTFY again.
    My B&Ws on stands were spiked to the carpet in my previous place but they sit on rubber isolators now to protect my wood floor. The speakers themselves sit right on the stands. I have no issues with the sound at all.
    F1nut Posts: 49,794
    Well, no you didn't. No matter I'm done here.
  • Polar
    Polar Posts: 70
    I'm going to check out the speakers tomorrow. I'm hoping that the seller has represented everything properly. Hopefully he has them on spikes so I get the maximum impact of the speakers' potential (sorry F1, I had to say it :D Peace, bro)
    Watch this space tomorrow, I'll be updating in the afternoon.
  • verb
    verb Posts: 10,176
    Hey Polar, I suggest you first get squared away with those SRS's, get em running, and then establish a baseline for performance, and go from there.
    The journey is incremental, after all. I have not spiked my SRS's yet, but I will. Lot's of folks here have traveled that journey before, and I trust their judgement. YMMV of course, but you may consider giving it a try.
    I found myself wrapped up in trying too many tweaks at the same time, what I learned from that is tweak one variable at a time. That way you can realize if that one thing made a difference. Otherwise it's tough to discern what works.
    All good, the folks here are trying to help! I have really upped my game heeding the advice of many here!
    Keep us posted on your journey!
  • Polar
    Polar Posts: 70
    verb wrote: »
    Good advice. I haven't sat in front of the SRS since 1986, so I plan on just taking my time and getting to know them again. I have the right gear and the right material to listen to; the SRS playlist was a pretty good description of what we had on the shelf at the store and I have a lot of it here both digital and vinyl.
    I figure it'll take me a few months before I settle in and start playing with tweaks. I already priced out the tweeter replacements, since I still have a contact or two in the business, and I have paths available for anything else that might pop up.
    I think the biggest concern right now is transport, but I'll figure it out.
  • verb
    verb Posts: 10,176
    edited March 2020
    Sounds like a plan! I for one, am interested in your impressions, as I'm not that far in front of you! My only tweak thus far, is the tweeters.
    Be sure to post pics!
    And I have gotten plenty of advice here on CP to get the XO's upgraded! And I will! :smile: Eventually! One step at a time my brother!
    nooshinjohn Posts: 25,094
    I've been done since the comments about the tweeters... I love it when new people join seeking advise, only to refute the advice given and citing their own biases as the best path.
  • Polar
    Polar Posts: 70
    Believe me I'll be too excited to post much tomorrow, other than to give a brief update. My wife is probably going to shoot me with a tranquilizer dart.
  • Polar
    Polar Posts: 70
    Lighten up, Francis.
  • deronb1
    deronb1 Posts: 5,021
    Welcome Polar. Not sure if you are new, but your post count would indicate so. Congrats on the SRS! I would love to hear a pair someday. The tweets, if oprrable are not like fingernails on a chalkboard. Ive owned a couple of Polk models with them. That said, i did switch out the tweets with rdo-194s and there was improvement, but I enjoyed them for a long time with the sl2000s too. Not sure if my 54 yr old military damaged ears would hear a 5db spike at 13khz or not, but the overall tone of the upper registry was improved. Enjoy!
  • motorstereo
    motorstereo Posts: 2,049
    Hopefully you'll be bringing them home and if you do laying on their back is the best way to transport them to prevent magnet shift. With the help of a strong friend they both will fit in the back of an suv to.
    Another bit of advice would be to listen to the advice of the experienced members here. They do know exactly what they're talking about when it comes to getting the very best out of the big sda's.
  • slow_polk7
    Polar wrote: »
    I'm pretty darn new here myself, but it's interesting just how much a poster reveals about him/herself in the space of just a few posts.
    In the event I'm being too obtuse, let me just say, Polar (Bi-polar?) has made a really shi**y first impression.
  • Polar
    Polar Posts: 70
    slow_polk7 wrote: »
    Polar wrote: »
    Tri-Polar, actually. And I think you're really more acute than anything else in geometry.
    Personally, I think certain people took things too seriously. And what I learned long ago in life, not just audio, is that when you think you know everything, you've obviously missed something. Also, everything is open for debate. Again, except with certain people.
  • Polar
    Polar Posts: 70
    verb wrote: »
    deronb1 wrote: »
    Guys.... they're heeeeere!
    When I inspected them, everything that needed to be done has been done. All 8 tweeters have been replaced with the RD'OH0001944fourforwow tweeters (F1 is gripping his keyboard ... "must control myself... mustn't correct him....MUST NOT..... arrrggghh .... its the RD0194-1...."), and the mid-woofers look brand new. Everything about these is perfect all the way around. The grill cloth is uniformly black. No sags, no stains, no runs. There are a couple of pills at the bottom that look like pet claw snags, I'm going to try razoring those out later.
    The bottom of the cabinets are pristine. I had expected them to be scarred up but they're not. However there are 4 leveling feet on there with glide bottoms. I forgot about those things. Didn't they used to have rubber discs over them? Whatever - they have to go. I wasn't going to do spikes but after seeing those things I'll gladly swap them out for proper single-toes.
    I'm currently driving them with an old Carver I had laying around. At volume these are good towers, but at lower levels the definition isn't as good as I expected. I don't think that's the Carver, I think its the lame Marantz preamp I'm using, temporarily.
    I still have all my test CDs from the store, so I spent a few minutes listening after I got things set up. The old Sheffield Track Disc really shows the imaging these are capable of. If you have access to that, I recommend it.
    I'm done for now. Wife is home, and believe it or not she walked right past these and didn't see them. Win!
  • deronb1
    Congrats! Let the fun begin!
  • Polar
    Polar Posts: 70
    Hey before I go for the night, I have to ask what you all use to clean these. I gave them a cursory rubdown with Seventh Generation wood cleaner/polish and a microcloth, but I'm sure there must be some time-tested ritual that must be observed so these keep looking like they just came out of the box.
  • BinKY188_5
    BinKY188_5 Posts: 128
    I'd like to know also. @F1nut ?
  • Polar
    Polar Posts: 70
    BinKY188_5 wrote: »
    I think he's done with this thread. :disappointed:
  • krazypolk
    krazypolk Posts: 745
    So where's the pics?
  • BinKY188_5
    Polar wrote: »
    BinKY188_5 wrote: »
    I didn't notice that. I have read that he is a master woodworker and thought he might chime in.
  • Polar
    Polar Posts: 70
    krazypolk wrote: »
    When I get daylight tomorrow I'll post something up. I have to straighten up my AV center anyway.
  • krazypolk
    It's been a minute since I've bought new to me speakers so I'm sort of ridin shotgun witch ya on this one.
  • Polar
    Polar Posts: 70
    Plenty of room in the car, just don't touch my radio. :D
    pitdogg2 Posts: 24,559
    The glides never had rubber on them.
    audioluvr Posts: 5,432
    Polar wrote: »
    ...I'm currently driving them with an old Carver I had laying around. At volume these are good towers, but at lower levels the definition isn't as good as I expected. I don't think that's the Carver, I think its the lame Marantz preamp I'm using, temporarily...
    Maybe, maybe not. Rebuilt crossovers will make a huge difference. I'd pull them just to see what's been done if anything.
  • Polar
    Polar Posts: 70
    audioluvr wrote: »
    Great minds think alike. I already have that inspection on the menu, but I do want to put some known good components in there to rule that out.
    It's the Carver, unless it is a TFM55 or better.
  • Polar
    Polar Posts: 70
    edited March 2020
    Its an un-modded M1.0t. It sounds a little lifeless to me with these speakers, but with a pair of vintage KEF and a turntable it was very nice. I have an excellent TFM on the shelf that I may swap in there, but I have bigger and arguably better stuff than that laying around. I'll be having a lot of fun with this.
    The 1.0 isn't a bad amp. If you aren't a rebuilder, though, I'd spend your money elsewhere. As many others here will tell you, watts aren't everything. There are several next level brands of amps that would mesh really well those SRS's.
  • Polar
    Polar Posts: 70
    audioluvr wrote: »
    Indeed. I'm going to be rotating some cool amps in there, and I'll be posting my impressions as time goes on.
