Infinity RSII....??? Any one had ears on them?
  • CH46E
    CH46E Posts: 3,566
    I sanded the fuse holders on the speakers then cleaned them off with a some mass air flow sensor cleaner I had in the garage. Replaced all the fuses and we are up and running.
    Something to note, i was not super impressed with the imaging of these RS. I just figured it was the caps. But after replacing the fuses I did not toe them back in nearly as much. They are almost at zero toe-in and the imaging just popped right into place.
  • Gardenstater
    Gardenstater Posts: 4,195
    Mapleshade SILCLEAR Silver Contact Enhancer........I swear by this stuff for all my audio contacts:
    https://audioleman.ch/product/mapleshade-silclear/
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    Viking64 Posts: 6,697
    dromunds wrote: »
    Some pretty big value caps. Be patient and hopefully a good cap sale will come your way.
  • CH46E
    CH46E Posts: 3,566
    Does anyone know what the exact values are on the 1600 and 600 uf caps are. I'm trying to find out the voltage so I can make sure I get the right specs.
    I was trying to find Nichicon gold tune caps but voltages are all over the place. I've never had such a hard time trying to find caps. Uuuuggggh!
  • Gardenstater
    No I don't but I found the schematic for the crossover in the RS IIa/b, which *may* be of some interest. It's interesting that there are 3 tweeters and they each seem to use 1.25 amp fuses. The high midrange uses a 2.5 amp fuse and the low midrange uses none (?). Total of 4 fuses.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
  • CH46E
    CH46E Posts: 3,566
    Since these are Di-pole speakers ( i think that's the right term, there is a tweeter facing the rear) should I be worried about the acoustic treatments in the corners as seen in my photos? It's just some acoustic foam and the larger peices are Acurelex Bass Traps.
    Should I maybe raise them up to about a 45 degree angle from the tweeters on the back?
  • honestaquarian
    Unless the rear facing tweeters are firing in reverse phase with the fronts, they would be called BIpoles actually and not DIpoles.
  • gp4jesus
    gp4jesus Posts: 1,969
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
  • Gardenstater
    No Infinity Bass Contour Module included, which is a necessary part and was never an option. Amazing how many of these are missing that! They look fantastic though! I think the guy says he removed the grill pegs but he has the grills! I wouldn't want to use them but why remove the pegs and fill the holes lol?
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
  • CH46E
    CH46E Posts: 3,566
    gp4jesus wrote: »
    Those were the ones I really wanted. They are also the ones I was afraid of wanting to upgrade to after having these RSII.
  • CH46E
    CH46E Posts: 3,566
    edited January 2020
    So.... I think I really screwed up today.
    The screens that came with these RSII were a bit smelly and I had been in the garage spraying the fronts with Fabreeze. I set the bottle down to turn the screens over, I then picked up the bottle i thought was Febreze and started spraying the back sides. Turns out i picked up a bottle of RainX windshield cleaner. I had a good 4 to 5 sprays each screen before I realized my mistake. I dont see any bleaching effects. All looks ok. I guess I'll have to wait and see what happens.
    audioluvr Posts: 5,455
    Should be good to go and now they're water proof!
  • CH46E
    CH46E Posts: 3,566
    Well SOB! GD porch pirates strike! God help one of them if i ever catch them in the act on my property. So the box of items that included a can of deoxit must have been taken from my porch.
    Does anyone know if any places like Lowes , Home Depot, Ace or others carry something that does the same thing? I have no Radio Shacks near me. I cant find deoxit locally.
    I did notice the auto parts stores carry CRC contact cleaners and other electrical cleaners. Will these products work for cleaning pots?
    treitz3 Posts: 18,372
    Sorry to hear of that. Yes. Contact cleaner will work okay. DeOxit is just the "go-to" for audio.
  • CH46E
    CH46E Posts: 3,566
    Thanks Tom. I'll do that tomorrow. I'm tired of waiting to get started on these speakers.
    pitdogg2 Posts: 24,606
    A long time ago in a far away forum one of my tunerinfo folks had a transmission fluid concoction that was alluded to work just as well as deoxit. Swore deoxit to have transmission fluid in it.
  • CH46E
    CH46E Posts: 3,566
    I could see something like that working based on the properties of ATF. I'm not brave enough to try that **** out. Lol
  • CH46E
    CH46E Posts: 3,566
    Got some of this today. Going to try and remove the back panel to access the pots now.
  • Gardenstater
    edited January 2020
    From the Michael Percy catalog, apparently you need to be careful and use the right stuff if you have carbon or plastic pots vs all metal ones. Apparently also the base solvent is purified naptha. There is one formula of DeOxit that has much higher capacity to clean heavily oxidized pots as well:
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
  • CH46E
    CH46E Posts: 3,566
    edited January 2020
    Thanks again Garden. This stuff is safe for all plastics. I'll hold a rag to catch excess drippings. Just going to do a few light applications into the pots. After the first spray I'll let them sit a min or two then flush some more and work the pots back and forth then another flush. I'll repeat as necessary until the pots stop scratching the sound so much. Going to re clean the fuse contacts and the speaker terminal contacts where my banana plugs go in.
    I may also start with once driver at a time (as to not mess up the wiring assignments) and clear the Male and female ends at each driver. I'll use a dental pick to clean the female spades. Then spray them.
  • CH46E
    CH46E Posts: 3,566
    edited January 2020
    I pulled the crossover boards out to have a look and clean the pots. Plenty of suprises for sure. My right speaker has a 3.0 ohm load at the terminals. The left has a 3.5 ohm load. Someone has certainly been inside these. Both crossovers are different. It appears the right speaker has undergone some work. Some one also disconnected the 1,600 if caps in both speakers. The right speaker has a pile of smaller caps for the 1600 but its disconnected. The left only has one huge cap for the 1600 and again its disconnected.
    And should all these inductors be offset from each other? Not so close and in the same orientation???
    Well take a look at the pics.
    Post edited by CH46E on
  • CH46E
    CH46E Posts: 3,566
    These are all from the right speaker. Left to follow.
  • CH46E
    CH46E Posts: 3,566
    Can anyone tell me what the transformers are for? Noise suppression?
  • Gardenstater
    edited January 2020
    Pics from audiokarma
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
  • CH46E
    CH46E Posts: 3,566
    Looking at this schematic it looks like the 1600 if cap is to cross the top woofer over at 125hz and the bottom to 50 or 60hz?
    I tried to remove the woofers to test thier resistance, but they are damn sure stuck in there. I will tap the uppers out from the back. The lowers are going to have to be pryed out.
  • Gardenstater
    I'm thinking maybe the 3 *transformers* are perhaps laminated iron core inductors (or something)?
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    I see 7 inductors but the schematic shows 8. Probably a small one hidden in there somewhere.
  • CH46E
    CH46E Posts: 3,566
    edited January 2020
    audioluvr wrote: »
    Could this be it? Looks like a small iron core.
