MW 6503 Woofer rebuild
Does anyone know who does this repair/service?
Units are in excellent condition cabinet was dropped causing the magnets to disengage,put them back on but no go.
  • Gardenstater
    Gardenstater Posts: 4,855
    One alternative option would be to get a used one on eBay. Just make sure you pm the seller and make certain that when the cone is exercised manually there are no voice coil scraping sounds.
    This one is cheap and seller has 3. Don't get the one with the nick in the surround! Either the scuffed cone one or #2 which I guess has no cosmetic issues. But make sure you tell seller no voice coil scraping sounds!
    https://www.ebay.com/itm/Polk-Audio-MW6503-6-1-2-woofer-SDA-SRS-1-2-RTA-15T-Monitor-12-Speaker/184069009918?epid=1133827614&hash=item2adb5e31fe:g:3PAAAOSw1MNd5uxS
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Gardenstater
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Thanks Gardenstater, would rather have mine rebuilt if possible and cost reasonable. I know what I have. Just hard to appreciate that the magnets being dislodged could cause such havoc and failure with no other apparent damage.
    BTW I’m a Jersey Boy myself, born and raised in north Jersey, moving to ATL over 20 yrs. ago. Still miss the food !
  • Gardenstater
    There are a couple people here that do this. Not my place to volunteer them though. You can search the forum for some posts where people describe the fixture they made with PVC pipe and adjustment screws for re-aligning the magnets. I'll see if I can find them, I may have bookmarked.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • mothy
    mothy Posts: 1
    You can look the discussion for certain posts where individuals depict the installation they made with PVC channel and alteration screws for re-adjusting the magnets
    Mybkexperience
