Infinity RSII....??? Any one had ears on them?
    audioluvr Posts: 6,037
    Looking good!
    txcoastal1 Posts: 13,519
    CH46E wrote: »
    treitz3 wrote: »
    CH46E wrote: »
    Debating on bringing them in tonight to try them out.
    Well, I guess you didn't debate too long. This post was an hour ago. LOL
    Yes, I was going to do it tomorrow but I remembered I have to mow the lawn and then we are going to see Celine Dion later that night.
    I’m sorry
    Tell her you need to watch the grass grow after mowing
    msg Posts: 10,599
    Chris, those look great, congratulations. Beautes! Looking forward to seeing how you progress with them and your impressions.
    msg Posts: 10,599
    txcoastal1 wrote: »
    CH46E wrote: »
    I’m sorry
    Or just pull a Ricky Gervais and tell her to take her tickets and... well, never mind.
  • CH46E
    CH46E Posts: 3,595
    edited January 2020
    treitz3 wrote: »
    Caig DeOxit is your friend.
    Do I just open them up and spray? I've never dealt with pots before. (Pot...yes, but not pots)👍😁
    It's ok guys, I actually like Celine.
    As far as caps go thi is not going to be a overnight purchase. Holy crap these will be the most expensive crossovers I've re capped. And if I'm reading the schematic right, there is a 1600 if cap! I cant even find one. Nor the 600uf. At least in found some 300s I can tie together.
    treitz3 Posts: 20,239
    edited January 2020
    That depends on the type, location and access of the pot itself. Unless it's completely sealed, remove the knob if there is one (power off), spray down the openings around the armature of the pot and twist back and forth (do not force).
    Repeat as necessary until clean.
  • CH46E
    CH46E Posts: 3,595
    Thanks Tom. I just put a can in the cart.
  • lawdogg
    lawdogg Posts: 470
    Congratulations!
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
  • CH46E
    CH46E Posts: 3,595
    So it looks like the RS1b skeletons I got with them are the same dimensions and I can use the base and wood to recondition my RSII.
  • CH46E
    CH46E Posts: 3,595
    Still listening to them, only the wife is in here with me now.
    I dont know if it was all the doubt about the TFM45 being up to the task or not, but I find myself thinking there is something missing. Maybe I just need to re-seal the sub enclosure or maybe I really need a better amp.
    I looked at CR, the bay and our own FS thread and I keep thinking maybe a Adcom GFA-555 or another Parasound amp is in order.
    What's missing? If you're looking for earth shaking bass then the TFM45 will not be ideal. Look for some monoblocks with lots of current capability and a dampening factor of 400 or more. If it's mid / treble life than it could be old capacitors.
  • Gardenstater
    Gardenstater Posts: 4,867
    If the RS II 's are bi ampable perhaps that TFM45 would be good for the higher end (mids and EMITs)? It's a tube amp correct? I read somewhere in a review for the RS I that a tube amp is required to get good sound out of the mids and tweets, but for the woofers, a high current, high power solid state amp is ideal. Damping factor of only 7 is quite low, and with my limited understanding and experience I'm not sure how you can get good woofer control with that situation.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • CH46E
    CH46E Posts: 3,595
    I wish it was a tube amp. It was only transfer function calibrated to sound like Bob Carver's tube amp.
  • Gardenstater
    What's that under your RS II's? Townsend Audio Platforms?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    edited January 2020
    I see that amplifier is rated into 1, 2, 4, and 8 Ohm output loads! I also see that it has seperate terminals provided for each output. Do you use the 4 Ohm ouput terminals with those RS II's? How tight is the bass? k054hla26dcw.png
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • LoStrings
    No, since I rotate my speakers, I use furniture dolly’s to help move them.
  • LoStrings
    Yes, I use the 4 ohm tap. That amp works very well with those RS II’s, and yes, very tight and defined bass. Also, the McIntosh runs very cool.
  • Gardenstater
    That seems like an excellent amp for these. How often do you see the clipping protection circuits get activated on the amp? What dB levels or type of music, ie. pipe organ etc..
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • LoStrings
    I have never seen the Power Guard lights come on..I listen to Jazz Fusion, Classical, Electronic music (Jean Micheal Jarr, William Orbit, Tomita to name a few).
    That is a big boy Amp that can handle the load. Nice rig ya' got there LS.
  • LoStrings
    I have been using a Yaqin VK-2100 tube integrated amp with the RS II's. It is a fantastic sounding amplifier with 85 wpc, class A/b solid state amp, with a preamp that utilizes 4-6n1 tubes. amazing sound, and plays well with the Infinity's.8liyh1faffn1.jpg
  • LoStrings
    treitz3 wrote: »
    Thanks Tom, it’s a journey we go on in this hobby, it’s nice to see other people enjoy it.
    Gene.
    That it is, Gene. That it is. I wouldn't trade my audio journey for anything. It's been nothing but fun!
    BTW, I see that you are relatively new around here. If I have not said so before...Please allow me to offer you a warm a very warm welcome to Club Polk.
  • LoStrings
    treitz3 wrote: »
    I have been a long time lurker, but I don’t post that often, but thank you for the warm welcome.
  • CH46E
    CH46E Posts: 3,595
    LoStrings wrote: »
    That looks like great way into tubes on lower budget. Very interesting.
  • CH46E
    CH46E Posts: 3,595
    Anyone with some help for cleaning the foam surround on that one bottom woofer.
  • Gardenstater
    Hydrogen Peroxide kills mold, but I'd be leery of spraying that onto foam
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • CH46E
    CH46E Posts: 3,595
    That's what I'm worried about. That form looks like it will soak up anything.
  • CH46E
    CH46E Posts: 3,595
    Hafler XL600 is for sale locally. Looks to be able to handle a 1 ohm load no problem. Anyone know what the sound quality is like on one of these. I know very little of the Haflers.
    http://www.hifi-classic.net/review/hafler-xl-600-427.html
