Tube ID
I think @mhardy6647 summed it up a while back regarding the tube manufacturers, IIRC it was either malfeasance or shenanigans, or both!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
most GE tubes had the glass laser etched with the brand it would NEVER go away.
I think they were etched with acid (e.g., hydrofluoric acid or maybe fuming nitric acid) -- or possibly alkali; lasers were pretty high-tech in most of the vacuum tube era. Actually, the LASER was invented in 1960 (its microwave equivalent, the MASER, comes from the 1950s, IIRC) -- and they were pretty much out of the mainstream until comparatively recent times.I'm a relative nube with tubes,what is the seal on the exhaust tip?
So -- vacuum tubes start out as... just tubes. Fulla air.
They're evacuated after they're assembled and the tube used to exhaust the air is sealed to produce that little tip on the top of the tube. The tube is heat sealed and cut or broken off to form the final tube, avec vacuum.
I was gonna just call it a n-ip-p-le, but Vanilla doesn't like that kind of talk!
Here's a before picture of the glass envelope for a miniature tube, from RCA Receiving Tube Manual RC-20
http://www.tubebooks.org/tubedata/RC20.pdf
I just found my eye loop. It appears,from the scarce markings,I believe a red label Sylvania. The plates are identical to the green label Sylvania 12at7's I have.See my profile for list of gear.
Bing Bing Bing! What do I win?
It's too bad that Thomas Mayer doesn't - yet - have a blog post on 12AT7s.
http://vinylsavor.blogspot.com/
Oh, while I am wasting forum bandwidth, and FWIW, this is my personal favorite resource to "recommend" to someone who knows zilch about vacuum tubes (for hifi) but wants to know at least a little.
http://ken-gilbert.com/images/pdf/taste_of_tubes.pdf
A huge THANK YOU! Sorry, I'm not a rich man!See my profile for list of gear. -
mhardy6647 wrote: »It's too bad that Thomas Mayer doesn't - yet - have a blog post on 12AT7s.
Thanks for the link! I'll be doing some reading.See my profile for list of gear. -
J/K brother! Hopefully we can ride together someday!
I truly want to thank all you folks for taking the time to help me sort this out! This is the reason I joined this forum. It's quite obvious you are good eggs!
RaySee my profile for list of gear. -
My guess is 12AT7. Sylvania construction, could be branded differently.
https://www.ebay.com/itm/SYLVANIA-12AT7-VINTAGE-TUBE-Black-Box-PLate-O-Getter-TV-7-Superb/254220204175?hash=item3b30b4788f:g:CIsAAOSw3udcza2a
I think you're on to something,however the mystery tubes sound so different from the green label sylvania's. I'm very perplexed!!!
Green labeled Sylvania tubes suck. If you want to try a 5751 in your pre look for yellow labeled Sylvania from the late '50's. Sweeeeet! -
Were they manufactured differently?See my profile for list of gear. -
Yes
Yes
I found... a graph about this (well... sort of)... on the internet.
https://www.effectrode.com/knowledge-base/thats-a-sylvania-tube-the-print-is-green-no-its-blue/
In other tube news, here's another look at the innards of a 9-pin miniature pentode tube
This diagram calls out the exhaust nip tip
That is so odd,but very informative. Thanks for da link!See my profile for list of gear.
Interesting link Mark, thanks.
I should have been more specific in my green label sucks comment. I was referring to 5751's.
I have used Sylvania green label 6111 and am currently using 6112 green label sub miniature tubes, which sound fine. I also have used gold label Sylvania 6112, which I didn't care for. -
Alrighty! I just grabbed a pair of Sylvania 12at7's,black plate O getters. And yesterday I purchased a pair of Amperex Holland 12ax7's. I should be set for a while.
You did in fact say that in the post prior to the one I quoted; I bumbled across the link I posted looking for pictures of different Sylvania branded 12AT7s.
@mhardy6647 What a great site Mark! Thank you!
I now understand microphonics!
Gotta get me a rubber mallet! Tiny one of course!
Lots of great information in there!
https://www.effectrode.com/knowledge-base/Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I have some microphonics goin' on in a preamp I am trying to rehab this week -- 12AU7s.
If you get a good (bad), really microphonic tube (7199s were/are notorious, e.g.) -- have some fun, and sing into it with no program source playin'.
I am very easily amused.
Like a microphone
In a powered-up component with zero signal being reproduced but at some nonzero volume setting, tap a microphonic tube - typically a small signal tube, and often in a high gain circuit stage - with a stick or fingertip, and you'll hear the sound, dutifully amplified and reproduced through the loudspeaker(s).
EDIT: Google & YT turned up mostly gee-tar amps with microphonic power (output) tubes, but in hifi (IMO/IME) it's usually the preamp tubes (or splitters) that are the most salient culprits... here is one OK video that at least demonstrates an effect of microphonic tubes.
https://youtu.be/1zT10_ztHYAit's the last two tubes that get tapped
That plate structure screams 12AT7,"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
Must be microphonic then.
I know what Maude would say to me for posting the above...
(I mean, heck, she wouldn't know my name wasn't Walter...)
mhardy6647 wrote: »Like a microphone
Thanks Doc for sharing this. Learned a lot today!
I'll make a tape of me tappin' on the 12AU7 in the aforementioned preamp and share it here --- anon. If I get really ambitious, maybe even a video.
We do have the technology.
(actual source: https://www.americanradiohistory.com/Archive-Catalogs/RCA/RCA-1963-Television-Cameras.pdf)
Very cool Doc! But where is the digital converter?
