Tube ID
  • verb
    verb Posts: 10,176
    I think @mhardy6647 summed it up a while back regarding the tube manufacturers, IIRC it was either malfeasance or shenanigans, or both! :smile:
    mhardy6647 Posts: 35,146
    edited January 2020
    most GE tubes had the glass laser etched with the brand it would NEVER go away.
    I think they were etched with acid (e.g., hydrofluoric acid or maybe fuming nitric acid) -- or possibly alkali; lasers were pretty high-tech in most of the vacuum tube era. Actually, the LASER was invented in 1960 (its microwave equivalent, the MASER, comes from the 1950s, IIRC) -- and they were pretty much out of the mainstream until comparatively recent times.
    TEAforONE wrote: »
    I'm a relative nube with tubes,what is the seal on the exhaust tip?
    So -- vacuum tubes start out as... just tubes. Fulla air.
    They're evacuated after they're assembled and the tube used to exhaust the air is sealed to produce that little tip on the top of the tube. The tube is heat sealed and cut or broken off to form the final tube, avec vacuum.
    I was gonna just call it a n-ip-p-le, but Vanilla doesn't like that kind of talk! :p
    Here's a before picture of the glass envelope for a miniature tube, from RCA Receiving Tube Manual RC-20
    http://www.tubebooks.org/tubedata/RC20.pdf
  • TEAforONE
    TEAforONE Posts: 1,064
    I just found my eye loop. It appears,from the scarce markings,I believe a red label Sylvania. The plates are identical to the green label Sylvania 12at7's I have.
  • verb
    verb Posts: 10,176
    TEAforONE wrote: »
    Bing Bing Bing! What do I win? :smile:
  • verb
    verb Posts: 10,176
    Gotta laugh @mhardy6647 as I saw those too. Re-branded GE's? How ironic. :smile:
    It's too bad that Thomas Mayer doesn't - yet - have a blog post on 12AT7s. :)
    http://vinylsavor.blogspot.com/
    Oh, while I am wasting forum bandwidth, and FWIW, this is my personal favorite resource to "recommend" to someone who knows zilch about vacuum tubes (for hifi) but wants to know at least a little.
    http://ken-gilbert.com/images/pdf/taste_of_tubes.pdf
  • TEAforONE
    verb wrote: »
    TEAforONE wrote: »
    A huge THANK YOU! Sorry, I'm not a rich man!
  • TEAforONE
    Thanks for the link! I'll be doing some reading.
  • verb
    verb Posts: 10,176
    J/K brother! Hopefully we can ride together someday! :smile:
  • TEAforONE
    I truly want to thank all you folks for taking the time to help me sort this out! This is the reason I joined this forum. It's quite obvious you are good eggs!
    Ray
  • TEAforONE
    verb wrote: »
    That would be VERY cool!!
    F1nut Posts: 51,882
    edited January 2020
    TEAforONE wrote: »
    verb wrote: »
    I think you're on to something,however the mystery tubes sound so different from the green label sylvania's. I'm very perplexed!!!
    Green labeled Sylvania tubes suck. If you want to try a 5751 in your pre look for yellow labeled Sylvania from the late '50's. Sweeeeet!
  • TEAforONE
    TEAforONE wrote: »
    verb wrote: »
    Were they manufactured differently?
    F1nut Posts: 51,882
    Yes
    edited January 2020
    Yes
    I found... a graph about this (well... sort of)... on the internet.
    https://www.effectrode.com/knowledge-base/thats-a-sylvania-tube-the-print-is-green-no-its-blue/
    In other tube news, here's another look at the innards of a 9-pin miniature pentode tube :)
    This diagram calls out the exhaust nip tip
  • TEAforONE
    edited January 2020
    That is so odd,but very informative. Thanks for da link!
    F1nut Posts: 51,882
    Interesting link Mark, thanks.
    I should have been more specific in my green label sucks comment. I was referring to 5751's.
    I have used Sylvania green label 6111 and am currently using 6112 green label sub miniature tubes, which sound fine. I also have used gold label Sylvania 6112, which I didn't care for.
  • TEAforONE
    Alrighty! I just grabbed a pair of Sylvania 12at7's,black plate O getters. And yesterday I purchased a pair of Amperex Holland 12ax7's. I should be set for a while. :D:D
    You did in fact say that in the post prior to the one I quoted; I bumbled across the link I posted looking for pictures of different Sylvania branded 12AT7s. :)
  • verb
    verb Posts: 10,176
    edited January 2020
    @mhardy6647 What a great site Mark! Thank you!
    I now understand microphonics! :smile: Gotta get me a rubber mallet! Tiny one of course!
    Lots of great information in there!
    I have some microphonics goin' on in a preamp I am trying to rehab this week -- 12AU7s.
    If you get a good (bad), really microphonic tube (7199s were/are notorious, e.g.) -- have some fun, and sing into it with no program source playin'. :)
    I am very easily amused.
  • TEAforONE
    What do microphonics sound like?
    edited January 2020
    Like a microphone :|
    In a powered-up component with zero signal being reproduced but at some nonzero volume setting, tap a microphonic tube - typically a small signal tube, and often in a high gain circuit stage - with a stick or fingertip, and you'll hear the sound, dutifully amplified and reproduced through the loudspeaker(s).
    EDIT: Google & YT turned up mostly gee-tar amps with microphonic power (output) tubes, but in hifi (IMO/IME) it's usually the preamp tubes (or splitters) that are the most salient culprits... here is one OK video that at least demonstrates an effect of microphonic tubes.
    https://youtu.be/1zT10_ztHYA
    it's the last two tubes that get tapped :)
  • TEAforONE
    That makes perfect sense. Thank you!
    heiney9 Posts: 25,483
    That plate structure screams 12AT7,
    heiney9 wrote: »
    Must be microphonic then.
    I know what Maude would say to me for posting the above...
    (I mean, heck, she wouldn't know my name wasn't Walter...)
    pitdogg2 Posts: 27,163
    verb wrote: »
    Hard to say really. From what I've learned, a lot of history out there where manufacturers made tubes for one another, others removed the original labeling and post applied their own, you name it.
    Here's an example of the same tubes, Sylvania manufactured (except for double layer mica on top), labeled as Motorola.
    and yet that laser etching on the far right one screams to me GE. Except it is missing dots that GE also used.
    I retract this statement as I just looked at my early mid 40's and mid 50's Sylvania 6sn7's and yes they are etched and look the same except they say 6sn7 USA :smile:
    Yep Doc got to give you credit no laser more like acid as you stated. Long terrible day at work I was mush brained to think they had used lasers way back when.
  • verb
    verb Posts: 10,176
    Thanks Doc for sharing this. Learned a lot today! :smile:
    edited January 2020
    I'll make a tape of me tappin' on the 12AU7 in the aforementioned preamp and share it here --- anon. If I get really ambitious, maybe even a video.
    We do have the technology.
    B)
    (actual source: https://www.americanradiohistory.com/Archive-Catalogs/RCA/RCA-1963-Television-Cameras.pdf)
  • verb
    verb Posts: 10,176
    Very cool Doc! But where is the digital converter? :smile:
