Do I REALLY need a ton of juice for my RTiA9's?
BjornB17
BjornB17 Posts: 752
edited January 2020 in Speakers
I know the answer is typically yes. I had a pair of RTi10's and then RTi12's and they would take all the power you could throw at it, but they were never paired with an awesome sub.
I am building a new 11-channel home theater around the RTiA line - A9's in the front, CSiA6 in center, 4x FXiA6, and 4x RT-90 in ceilings. That is a lot of speakers. However, on this particular home theater, I will be using two Rythmik F18 which are absolute beasts, and will likely cross them over at 80 Hz (in my 2 channel setup I have my Rythmik F12 crossed over at 100 Hz and sounds amazing). So with that in mind, I'd rather have the subs do the heavy lifting. Due to crossover slopes, the A9's will still play some stuff below 100Hz, but won't need the juice that they otherwise would have to deliver that sub 30 Hz bass like they did before.
So in this case, I'm thinking an 11 channel amp like the Yamaha MX-A5200 would be fine. 150 wpc in 2 channel model, about 80 wpc all channels driven (which rarely happens). Maybe a little more if they release a new amp at CES next week which I think it likely the case.
Other options are the Monolith 11X and Emotiva XPA-11. I'd prefer to skip Emotiva since, while good, are a bit bright with the RTi's (been there done that). The Yamaha sound signature is wonderful and I think is the most premium of the 3 and sounds more satisfying at a lower volume level. I haven't seen or heard the Monolith but it also looks great.
Thoughts?
KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
  • afterburnt
    afterburnt Posts: 7,892
    What size is the room and did you file single or married?
  • BjornB17
    BjornB17 Posts: 752
    afterburnt wrote: »
    Big room, 18'x23'x10', dedicated theater :D
    mhardy6647 Posts: 33,044
    English ton or metric ton (tonne)?
  • BjornB17
    BjornB17 Posts: 752
    Yes
  • afterburnt
    @BjornB17 What AVR are you running? BTW I loved it when you whooped McEnroe!
    F1nut Posts: 49,801
    That's really high.
    txcoastal1 Posts: 13,132
    Find a used Parasound A21 used for the front 2 A9
    3-chnl monolith for center and rears
    Yamaha for the rest ...should keep you in budget and good for 2chnl IMHO
  • BjornB17
    BjornB17 Posts: 752
    edited January 2020
    afterburnt wrote: »
    Thanks but I'm trying to put my past in my behind.
    I haven't yet purchased one but either will get a RX-A3080 AVR or a CX-A5200 pre-amp. Will need a standalone amp in either case, but the 3080 can power most of the speakers but the CX-A5200 offers slightly better processing and balanced outputs for all channels and subs. Again may depend on what Yamaha presents at CES in a few days.
  • BjornB17
    BjornB17 Posts: 752
    That's really high.
    Yep, but with the YPAO room correction blends perfectly with my little RTiA1's.
  • BjornB17
    BjornB17 Posts: 752
    edited January 2020
    txcoastal1 wrote: »
    That is a lot of different amps in one system! Parasound was on my list, and I may still consider it, but they are about 2" too long to fit in my shelf.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    If you're planning Atmos, go with 4xRTiA1 or A3 over the FXiA6, or at the very least only use the FXi for the side surround. Back channels should be bookies, IMHO.
    F1nut Posts: 49,801
    BjornB17 wrote: »
    That's really high.
    RTiA1 Lower -3dB Limit 60 Hz. I'd try setting the sub at 70 Hz for less overlap and possibly less localization. But what do I know.....
  • BjornB17
    BjornB17 Posts: 752
    BjornB17 wrote: »
    That's really high.
    Wouldn't you want to cross them over above the speakers F3 point? I'm not sure what it is on the A1's but I'm guessing it is more than 10 Hz about the -3db point (I may be wrong). I'll look into it.
    Now back to the original question :D
  • mantis
    mantis Posts: 17,056
    edited January 2020
    I think the Yamaha MXA5200 is completely fine for your setup. I also agree using all 80 watts per channel is such a rare case. Most people get caught up in more power more more more etc and actually never ever need it. Having head room is NEVER a bad idea but in most cases well blown past need more of a manly want then anything else. Who doesn't like to brag about having 200 watts per channel ( Flexes Muscles LOL).
    What is missed here is the room interaction with the speakers and sub. The room is why we use 80hz crossover points and 120hz crossover for subwoofer so setting the sub to 100hz isn't to high at all. Actually when using LFE not 2 channel the LFE channel is mixed up to 120hz so cutting it at the old way of 80hz you don't replay the 81hz to 120hz signals of the LFE track correct or where it should be which is in the subwoofer.
    The relationship of the room greatly effect bass performance , even with tower speakers that have the ability to play down to 30hz isn't ideal in a room as that bass placement where the main channels typically go for 2 channel playback and front left and right of a home theater setup doesn't usually equally play bass across the seating area or even the KING SEAT as I like to call the best seat in the room.
    So allowing a speaker to play to 70hz now clouds the bass performance.
    I think over the years of confusing information and old way of thinking and yes I'm guilty of this as I grew up in the business dating back to the 90' when we where learning about how a subwoofer is placed and how to set it up. We had THX and Dolby and thats it. Later came DTS and guidlines and training has changed greatly since then.
    Dan
  • rooftop59
    rooftop59 Posts: 7,981
    BjornB17 wrote: »
    BjornB17 wrote: »
    That's really high.
    From stereophile’s measurements: “the Polk's low frequencies are actually flat to the point where they start to roll off, reaching –6dB at the port tuning frequency (50 hz).”
    Audiophile speaker are not designed to be crossed over but rather are carefully designed to be able to play their designated range and then roll off as to not damage the Woofer. I have found that most bookshelf speakers (in the appropriate sized room) sound better running full range with sub blended in.
    This addressed your original question: it seems like a waste $$$ to get the 9s and then cross them over. Those babies should be running full range. And if they are, they need lots of power to get all those woofers dancing...
    Game Room 5.1.4:
    Bedroom 2.1
    edited January 2020
    rooftop59 wrote: »
    Audiophile speaker<s> are not designed to be crossed over but rather are carefully designed to be able to play their designated range and then roll off as to not damage the Woofer...
    On the other hand, sounds to me from that description that they have a built in first order acoustic XO (in fact, sounds like a critically damped alignment -- Qts Qtc = 0.707 -- based on the verbal description from Stereophile) and thus might be readily integrated with a subwoofer if one wished to extend the LF cutoff downward.
  • mrloren
    mrloren Posts: 2,454
    Hmmm, it's all about how much you want to spend.
    One question I have, do you have electrical circuits for your theater room? I'd say at least two 20a circuits is needed. Having lots of subs and amps needs lots of juice.
    I do like the Yamaha pre and amp together would be fine. You could always add a bigger amp for the front 3 later if you think you need it. an A31 or Monolith 3 added in would take a lot of the load off the Yamaha amp. Running 11 speakers off a single amp is asking a lot of the amp.
    I agree with going with A1/A3 over the F/X speakers for surrounds. If it was a 7.1 setup the yes the F/X are good but add in the ATMOS direct speakers are better.
    My brother was here for the holiday's. He was digging my setup. He has the room and space to build a theater room and asked what I would use. Simple list
    AVR; Marantz SR8012
    Amp; Parasound A52+
    subs; Dual SVS PB4000
    He will get home price it out and then keep his 2005 AM radio setup
  • rooftop59
    rooftop59 wrote: »
    rooftop59 wrote: »
    I think we are saying the same thing doc. I agree they can be easily integrated with a sub. What I am als I saying is that you should ideally not add an additional crossover but simply you the crossover in the sub to blend it in...
    Game Room 5.1.4:
    Bedroom 2.1
    edited January 2020
    rooftop59 wrote: »
    rooftop59 wrote: »
    rooftop59 wrote: »
    Right, Gotcha. Yes, I'd concur. Sorry, I must've read right through that! :/
    (not the first time)
    I run the subwoofer at my house the same way, as a matter of fact.
  • rebelsoul
    rebelsoul Posts: 756
    If you want to hear what they can do 200 watts.
