DIY Audio Rack
  • Mike Reeter
    Mike Reeter Posts: 4,315
    hochpt21 wrote: »
    hochpt21 wrote: »
    When I had my Cronus powering the SDA's, it was a wonderful match up. I'm positive this setup sounds very good!
    I’ve only recently moved it down here. It sounds REALLY good. I do think that I’ve lost a decent amount of bass since I had the Parasound powering them however. Not sure if that’s because of the tube amp? Or maybe the bass is just tighter? I’m thinking about picking up a sub.
    I never felt like I was missing much in the Low-end with the Cronus powering some 1C's, 3.1TL's or the 2.3TL's in our previous home.
    But now, I'm running a pair of Subs in the setup, but I no longer have the Cronus, and I'm in a different room.
    My suggestion would be to incorporate a Sub :p
  • CH46E
    CH46E Posts: 3,595
    edited January 2020
    chumlie wrote: »
    $10K for a small rack????? Hahaha lol, you could get a real nice Double D rack that's much more enjoyable for $5K to $6K. If you are willing to put up with the rest of the package! 😉😉😁👍
  • hochpt21
    hochpt21 Posts: 5,423
    hochpt21 wrote: »
    hochpt21 wrote: »
    Just ordered a SVS SB12-NSD
  • mrloren
    mrloren Posts: 2,474
    Very nice rack, well done.
    The wood at HD is not bad but not great either. Looks like you got a good sheet of pine. I wouldn't worry about or double think of using HD oak or birch. Most of the time the pine is better.
  • CH46E
    CH46E Posts: 3,595
    @hochpt21 how much would you guesstimate it weighs?
  • hochpt21
    CH46E wrote: »
    A moderate weight. It’s not light, but my 9yr old and I moved it from room to room. Maybe 50lbs? Just a guess.
  • steveinaz
    steveinaz Posts: 19,545
    So what did you do for the feet? Rubber caps?
  • hochpt21
    steveinaz wrote: »
    The top looks like the bottom, so basically it's just the end of the threaded rod with a big old nut flush at the end.
    I had intended to do casters, but the ones I got didn't work and I used them for another project.
    I'll probably leave it as-is for now. Maybe forever... :)
  • TEAforONE
    TEAforONE Posts: 1,070
    Great job!!
  • steveinaz
    Very cool.
  • hochpt21
    I just finished some speaker stands to match, but I’m not super excited with how they turned out. Either way here they are.
  • chumlie
    chumlie Posts: 8,658
    Look good. What don't you like about them ?
  • hochpt21
    chumlie wrote: »
    The top boards are great, solid oak. I didn’t have enough though, so the bottom boards are regular 2x12’s that warped like a smile and made it impossible to get the legs perfectly vertical. Also, the stain came out different because of the different kinds of wood.
