Dual Rythmik F-25 Direct Servo subs - On the way!
124»
    treitz3 Posts: 19,966
    My first experience hearing huge percussion drums was at the 1996 Olympics. Everyday, there were performances of Japanese Taiko Drums on a huge raised stage in the park. <snip> I thought the drums cast an unreal sensation in the park each time.
    THAT. That right there is something I would have loved to have heard. That unreal sensation you speak of is something that reproductive systems have limitations on and is exactly what I was referring too above. I simply believe that no human technological advances in reproduction can emulate something like that. It seems to me that it is unreal because folks rarely hear something that powerful and impactful at the same time.
    ES, I am only asking $900 for both plus shipping. I'll PM you picks later on if you are interested. The shipping is where it will sting a little bit, depending on where you live. Don't quote me on this but I do believe that I have the original boxes/packing stuff as well.
    Here is a pic (below) of one of the Tyler's behind/next to my main speakers that I pulled from another area of the forum. Each sub utilizes this driver - https://www.madisoundspeakerstore.com/approx-10-woofers/seas-excel-w26fx-001-e0026-10-aluminum-alloy-cone-woofer/?gclid=CL-Szab0v7UCFQm0nQodhgEAxw
    Some of the highlights of the plate amps are as follows -
    High power class AB output stage
    Patented tracking downconverter power supply
    Full parametric bass EQ
    Phase reversal switch
    Advanced soft clip circuitry
    Toroidal power supply transformer
    Auto On/Off
    As for the parametric EQ the Dayton's incorporate, here's some additional information;
    EQ-Frequency: Establishes the specific frequency at which EQ boost or cut may be applied between
    18 Hz and 80 Hz.
    EQ-Bandwidth: Determines how narrow or wide the EQ curve will be within a range of 0.1 to 1.0. If for example
    a frequency of 60 Hz were selected along with a Q of 0.1, the frequencies to either side of 60
    Hz would be less affected. This is a narrow bandwidth that could be useful for “surgically”
    removing an offending peak without disturbing adjacent frequencies. At the other extreme, a Q
    of 1 would result in a much broader effect which could be used for smooth overall bass boost or
    cut, to balance the overall tone character of the sub.
    EQ-Level: Permits the application of up to 6dB of boost or 14.5dB of cut at the selected frequency and
    bandwidth. Setting the control at the 0 position effectively removes the EQ from the circuit path.
    It is good to remember that high levels of boost reduce amplifier headroom; it is the same as
    turning up the low pass gain control but only at the selected EQ frequencies. It would be helpful
    to reduce or increase the low pass gain control to balance the amount of cut or boost applied
    by the EQ
    One additional note - Neither sub have ever had a hum [whatsoever] in Trey's house or mine.
    EndersShadow Posts: 17,702
    Thanks Tom. I’m quite sure 900 is fair, but its outside my budget. I mainly was curious as to what they were.
    Those crossover boxes are bigger than your sub lol
  • Irrenhaus
    Irrenhaus Posts: 1,100
    I have one F25 for HT use and love it. Sounds amazing and rattles the whole house. I am just thinking of give it a try on the 2ch rig just for fun.
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • verb
    verb Posts: 10,176
    Lol I’m reading this thread, got the image now burned in my brain, of Tom busting a move at Joe’s house, and seem to recall are there subs for sale? :smile:
  • treitz3 wrote: »
    I thought I posted this several days ago but must have not hit "post". It sure looks like a lot of fun and maybe some others may be interested in meeting up and going.
    In September each year, there is a Japanese Festival in Atlanta. Usually there is a Taiko Drum Troupe that performs and offers a workshop to learn to play them. The festival is just off I-85 at the Infinite Energy Center. Here is info:
    https://www.japanfest.org/
    Harry
    Harry / Marietta GA
    I am game. Would love to attend that!
    Never been to one of those before abut after experiencing some stomp dancing concerts, this would be a treat to experience as well. Anyone else interested in attending?
    txcoastal1 Posts: 13,505
    treitz3 wrote: »
    Joe will probably go...If you promise to learn new dance moves
  • joecoulson
    joecoulson Posts: 4,943
    He would just fall asleep and Russ would start praying again....but yeah let’s do it!
    After we go to this, we should all go home and listen to our respective systems and put this album on. http://sheffieldlab.com/item.php?item_id=53
    Everyone can afford this CD, as even though it is discontinued, it's still easily found at reasonable costs.
  • Placed an order for the CD from Amazon. $11.60 total.
    I like this:
    This unedited, live recording will test the mettle of any sound system - not to mention the good will of neighbors. - LA TIMES
    **CAUTION** This disc contains music of extraordinarily wide dynamic range, encompassing long passages at the threshold of audibility that build to levels of extreme intensity.
    Harry
    Harry / Marietta GA
  • afterburnt
    afterburnt Posts: 7,892
    How much are those, I can't seem to find the price on the site?
  • sgmsmg
    sgmsmg Posts: 556
    I like this:
    Harry
    Was that the price for a used one?
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
    Imma check some out on Spotify and then order some hard copies
    That was just a link to the original place to purchase it through Sheffield Labs. It is now OOP. I saw this used for as low as 4 bucks us shipping IIRC this morning.
    They can readily be found on most outlets that sell CD's
  • afterburnt
    Sorry, I was asking about the subs.
    My bad man. Here ya' go. Call them for best price. They don't haggle but they cut me a small break because I bought two and saved me some dough on delivery charges as well. (Worth a shot)
    http://www.rythmikaudio.com/index.html
  • sgmsmg wrote: »
    Harry
    Yes $6.99 on Amazon with $4.61 shipping. "used like new".
    New ones are considerably more (> $60).
    Harry / Marietta GA
  • sgmsmg
    sgmsmg Posts: 556
    sgmsmg wrote: »
    Harry
    Okay thanks for clarifying. Looks like they have it streaming on Prime so I will check it out before I buy it.
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Pre: Anthem AVM90
    Amps: Buckeye NC502
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,764
    All virtual this year!!!!
    Harry / Marietta GA
    *sigh*
    Virtual is nothing like the real thing. While I might chime in if I'm bored that day? I'll wait another year for the real event. Experiencing it live is what I was looking very forward too. Witnessing things like this first hand and in person are things that one tends to never forget.
    Any of y'all get and play this album on your rigs yet?
  • joecoulson
    Funny you asked. I loaded the CD in my Amazon cart, then thought, wonder if this is on Tidal? Yep! Added it to favs. Will try it soon.
