New subwoofer(s) recommendation?
So I have the setup in my signature. My theater room is about 16'x16'x10'(H). I had to relocate my Velodyne CHT-12 to my home office to replace a CHT-8 that just bit the dust, so that leaves my home theater without a subwoofer. I'm actually open to the idea of having two subs as well, but I might buy one now and a second later. I don't have a particular budget in mind but maybe less than $1000 would be ideal. Is there a go-to sub for that price point that would work well in my room size?
KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
    SVS or HSU
  • BjornB17
    BjornB17 Posts: 752
    A pair of SB-13 Ultra's looks awesome :o
  • Willow
    Willow Posts: 11,310
    tonyb wrote: »
    SVS or HSU
    Can't go wrong. They have a great return policy and upgrade policy. They usually have some great deals. Or buy used.
  • rpf65
    rpf65 Posts: 2,127
    May also want to look at Rythmik and Power Sound Audio.
  • mrloren
    mrloren Posts: 2,474
  • cfrizz
    cfrizz Posts: 13,415
    edited December 2016
    "Amazon has an SVS for $400 if you want to go dual https://www.amazon.com/SVS-SB12-NSD-400-watt-Controlled-Subwoofer/dp/B009F8Y7SO/ref=sr_1_3?ie=UTF8&qid=1481683509&sr=8-3&keywords=svs"
    I'm getting one of these delivered in a few hours, for the price it's hard to beat.
  • larlane
    I recently went with SVS dual SB 2000's. $1300 from SVS new. I found a gently used gloss black and ordered another gloss black from OneCall for $1100 total. These are part of a downsizing I did. I had a huge Elemental Designs A7S-450.
    They are EQ'd with my Denon X4000. I did boost the levels a bit to suit my liking. They are paired with LSIM 705's. Really happy with this as they do a fine job with music and are very capable with action movies.
    Buying new is a plus because of the return policy, but you can generally find at least one for sale used and buy another "open box" if you want to save cash. Plus OneCall has an Amazon store and you can use Amazon credit to spread out payments with no interest.
    msg Posts: 10,546
    Dang Cathy, good heads up on this!
    I've always been curious to try the smaller sealed SVS subs.
    cfrizz wrote: »
  • BjornB17
    BjornB17 Posts: 752
    rpf65 wrote: »
    Just following up on this thread years later. I bought an SVS sub, which was okay but a bit underwhelming, but was able to recover most of my cost by selling it. Recently bought a Rythmik F12 (turns out they are local to me), and I've been in audio heaven ever since. The servo system and ultra deep frequency response really are awesome.
    treitz3 Posts: 20,208
    Trust your ears, B. They never lie.
  • GlennDog
    GlennDog Posts: 3,158
    BjornB17 wrote: »
    It’s Christmas, buy another one!
    If you’re still in the 16 x 16 room, one should be plenty. Otherwise, get another F12
    Rythmik is very good stuff
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • BjornB17
    BjornB17 Posts: 752
    edited December 2019
    GlennDog wrote: »
    BjornB17 wrote: »
    I'm in the process of moving, so all I have is my little 2.1 system in my signature hooked up to my PC in my home office, great system for a 11'x10' room. I'm building a new house with a 26'x'18'x10 home theater and I'll be getting dual F18's :#
  • WLDock
    WLDock Posts: 3,073
    BjornB17 wrote: »
    I guess sometimes the journey takes time. Hard to go wrong with Rythmik.
    Been strongly considering one or two myself.
  • mpitogo
    mpitogo Posts: 520
    SVS SB-3000
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • GlennDog
    BjornB17 wrote: »
    2 should do it… B)B)
    For those unfamiliar with the F18
    http://www.rythmikaudio.com/F18.html
    btw congratulations on the new digs!
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • TEAforONE
    TEAforONE Posts: 1,099
    Congratulations on the Rythmik. I don't think I've ever read a bad thing anywhere about their subs. Those 18's are beasts!
  • BjornB17
    BjornB17 Posts: 752
    TEAforONE wrote: »
    Thanks! The only thing I would like is if they used a real oak veneer (like the black Polk RTi's have) instead of the vinyl oak wrap, but the fit and finish is still excellent regardless.
  • BjornB17
    BjornB17 Posts: 752
    GlennDog wrote: »
    BjornB17 wrote: »
    Thank you!
  • GlennDog
    BjornB17 wrote: »
    Contact Jim Salk at salksound.com
    he’ll construct a dead silent, furniture grade cabinet in any finish you can imagine
    I have an F12 in one of his “standard finishes” that I’m quite pleased with.
    I’m seriously thinking of another F12
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • GlennDog
    You cannot go wrong with Rythmik! I wouldn’t be contemplating a 2nd sub if I thought the technology wasn’t spot-on
    However, I understand the F18 and F25 (might be others, too) are only available in the XLR3 plate amp
    treitz3 wrote: »
    They are not the easiest to dial in but once they are? Holy Smokes Batman!!!
    I am a huge proponent of “ease-of-use“
    The XLR2 amp allows you to use multiple subs as slaves to the main/master sub. Set-up should be a breeze with multiple subs using XLR2s
    Might want to reach out to Brian at Rythmik and pick his noodle
    Good luck!
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
