Polk L200 Speaker Demo Reviews
13468915
  • I echo Erniejade's first impressions.
    hdjh9v7eiu5o.jpgHome theater trials and comparison of the L200 against three other Polk bookshelf speakers (2 channel music only) have been completed.
    vbie8tx42hpc.jpgSetting up the L200 in my 2 channel system. The red light on each speaker is a laser level which assisted with toe in alignment. Feeding the L200s a higher quality signal resulted in much higher quality sound.
    The tonal balance and bass performance are excellent.
    More later.
    Dang! What a tease :# I'm just kidding of course. We're looking forward to your review. ;)
    K_M wrote: »
    both those speakers you mention (703's and Rainmakers) have a boosted top end.
    I'd really like it if you could elaborate on this because without some kind of active external signal processing like a gain varistor on the speaker inputs (would have to be powered too) or some kind of complex capacitance circuit, there's no way for a speaker to have a "boosted top end" without some kind of amplification circuit that changes the cutoff frequency to push it past the components +6 dB capabilities.
    Even then, if you did do that, there is a physical limit to the components. You may be able to boost the signal past the +6 dB cutoff but just because you can boost the signal doesn't mean your drivers can actually reproduce it or your ears can actually hear it. A +/- 3 dB cutoff is typically the most boost you can get out of a signal processor before you get signal clipping and a +/- 6 dB cutoff is where the physical limits of the components are reached.
    The only time I have ever been able to push a response curve past a +6 dB limit is with subwoofers in SPL competitions where you are building the enclosure and taking advantage of the enclosure loading caused by the massive amounts of pressurization a sub will provide. Even then, you're barely hitting a +9 dB cutoff and it's not even the driver that's doing it. It's the enclosure resonances and it's hitting it at a very tight frequency stretch, right around driver resonance, that is maybe 10 Hz wide with a super powerful peak right in the center of that range. But even then, you're driving that driver at or just past it's physical distortion point and using the pressure in the sub box to brace the driver against it trying to tear itself apart. Your sub is a one note wonder, though and good for only one thing...competing with the Space Shuttle launches on SPL levels for a "burp" which is, at most, 3 seconds long before you send your amps into thermal failure.
    Speakers are passive devices. They don't boost anything. You can use crossovers to move your -3 dB cutoffs around so that you have a decent amount of driver response curve overlap to make a less than desirable -3 dB cutoff point a non-issue. The thing is, though, without some sort of external amplification either on the actual power end or through some kind of processing on the signal path end (bass button, tone controls, gain knobs, equalizers, etc) you're not going to boost a -3 dB cutoff frequency at all let alone anything above the 0 dB base.
    So, unless you're misusing terminology here to describe something else, you're full of baloney.
    Expert Moron Extraordinaire
    edited December 2019
    I imagine we are using boosted as a way to represent more prominent. IE I used it to describe the way a 703 has a bloated/more prominent midrange than a lot of more accurate speakers.
    I don’t think the LSiMs are bright at all; in fact the lower mid-bass bump (reflected in stereophile measurements) makes them a bit warm sounding. However, we all know that Polk does make bright speakers. From John atkinsons measurements of the RTiA1:
    “While the woofer is quite flat within its passband, the tweeter shelves up by 5dB in its top octave.”
    Read more at https://www.stereophile.com/content/polk-rtiii-a1-loudspeaker-measurements#QtxA7cG1hQLGCsZZ.99
    How would you explain that @Jstas?
    Game Room 5.1.4:
    Bedroom 2.1
    rooftop59 wrote: »
    Measuring frequency response is not the same as boosting frequency response in crossover curves.
    https://soundcertified.com/what-does-crossover-do-what-is-crossover-frequency-how-crossovers-work/
    What you see in that Stereophile article you posted is physical measurements with either sensors attached directly to the loudspeaker assembly or response graphs from microphones placed in proximity to the loudspeaker in an anechoic chamber. Any power measurements are not going to be a baseline standard. They are going to be measured at the output level of the amplifier being used. You can monitor that output level with measuring equipment but you are not going to be able to energize the crossover circuit with that amplifier and measure the electronic components at the same time without disassembling the speaker and putting the components on a bench.
    The Stereophile article comes to it's conclusions via measuring it's amplifier output and graphing the SPL produced by the loudspeaker/individual drivers at each measured frequency point and graphing it against the amplifier power level at each point. They can also measure impedance and cabinet flex/resonance with sensors that will show cycles of movement of electricity or physical vibrations which travel in sine waves.
    How would I explain it? You don't understand as much as you think you do. You're trying to goad a gun fight with your pocket knife. That's how I would explain it.
    Jstas wrote: »
    L200 Speaker Review
    My L200 review was done with three systems:
    1. Home theater system, where it was compared to three previous model Polk Audio bookshelf speakers: The SDA CRS+ (highly modified), the LSi9, and the LSiM 703.
    2. Two channel system (no comparisons to other speakers).
    3. Work office system (compared to the highly modified SDA CRS+s I listen to every day at work).
    General Observations
    I was impressed with the balanced sound, clarity, detail, and sound stage characteristics. The L200 sounds "bigger" than it's physical size, but it didn't generate a large sound stage in the three systems I reviewed it with. However, the images within the sound stage were well defined and stable. The cabinet construction, real wood veneer, driver and tweeter, and binding posts are very high quality. The aesthetics are somewhat "bland" for my tastes. I much prefer the curved lines and satin finishes of the previous LSiM line.
    Program material was DSD music files of instrumental jazz, jazz vocal, and rock recordings.
    My evaluation methodology is based on mapping and describing the locations and sound quality characteristics of sound images in the sound stage.
    L200 Home Theater Trials
    Figure 1. Tower speakers on each end: LSiM 707. Bookshelf speakers L-R: Legend L200, LSi9 (modified), LSiM 703, SDA CRS+ (modified).
    Listening environment: 22' x 16' room with 12' ceiling. Speakers were placed on the long wall. I sat 12' from the speaker front plane. Only one pair of speakers was in the room at one time. The bookshelf speakers were set on 30" Metal Technology TMT-30 stands in the same locations as the 707s. The CRS+s were 9'- 3" apart center to center and 15-3/8" from the rear wall. The other three speakers were 8'- 6" apart center to center and 12.5" (LSi9), 12.75" (LSiM 703), and 14" (L200) from the rear wall. The SVS subwoofer was not used for two channel music evaluation.
    Order of listening:
    1. LSiM 707. (For reference purposes.)
    2. SDA CRS+.
    3. LSi9.
    4. LSiM 703.
    5. L200.
    Going from the LSiM 707s to the CRS+s was an upgrade in every respect except for bass tactile sensation.
    Figure. 2. These modified 1989 model SDA CRS+s outperformed the LSi9, LSiM 703, and L200 in every respect: clarity, detail, sound stage, image weight, etc. In my excitement, I forgot that the Dreadnought isolation transformer (black box on the floor) sounds better oriented vertically.
    Bear in mind that the CRS+s are substantially larger than the other bookshelf speakers in this review. At 1.5 cubic feet, they are 50% larger than the L200s, 27% larger than the LSi9s, and 21% larger than the LSiM 703s. In addition, the CRS+s have over $1900 in cabinet and electronic component modifications, including custom crossover boards, Sonicap capacitors, Mills MRA-12 resistors, teak cabinet veneer, driver and tweeter retaining rings and brackets, the "TL" tweeter/crossover modification, low DCR SDA inductor, and the Dreadnought 1000VA isolation transformer.
    Figure 3. A pair of Bosch model 3LL30 laser levels were used to assist with setting toe in angles.
    Figure 4. The laser levels centered on top of each speaker projected horizontal and vertical cross lines. My head was in the same location as the tiger's. The speaker's toe in was adjusted until the two vertical lines were just outside of the tiger's head. This meant the speakers' center axis lines converged a few feet behind my head.
    Figure 5. Setting up the LSi9 speakers and adjusting toe in with the laser levels.
    The LSi9's have the following modifications: 1. Original crossover capacitors and resistors replaced with Solen and Sonicap film capacitors and Mills MRA-12 resistors. 2. Original wiring replaced with Cardas 15.5 gauge litz wire. Total modification cost was $535. They are some fine looking and fine sounding speakers, but they were a huge step back from the modified CRS+s.
    Figure 6. The LSiM 703s were the most visually appealing of the group and came in 3rd place in overall sound quality.
    In addition to curvy good looks, the 703s were a leap up in clarity, detail, and sound stage.
    Figure 7. The L200 was the best sounding and best imaging of the conventional stereo bookshelf speakers. Overall, it came in a distant second place behind the modified CRS+s.
    Serving as front speakers in a 5.1 home theater speaker arrangement, the L200s were a "decent" match for the LSiM 706c center channel and LSiM 702 surround speakers when watching movies and when listening to multichannel music.
    Associated Equipment For Home Theater Trials
    Yamaha CX-A5100 Preamp Processor
    Oppo UDP-205 Blu-ray Player/DAC
    LG OLED65E8PUA 65" OLED TV
    Synology DS918+ NAS
    Bryston BDP-1 Digital Player
    Revelation Audio Labs Dual Conduit USB Cable1.25m
    PS Audio PerfectWave P5 AC Regenerator For Source Components And TV
    PS Audio PerfectWave P10 AC Regenerator For Prepro And Power Amps
    PS Audio PerfectWave AC-5 Power Cords For AC Regenerators
    Two 20 Amp Dedicated AC Circuits
    PS Audio Soloist SE In-Wall Power Conditioner For AC Circuit #1
    PS Audio Soloist SE In-Wall Power Conditioner For AC Circuit #2
    PS Audio Statement SC Power Cords, 2m - 7 Total (PrePro, Front Amp, Center Amp, BDP-1, Surround Amp, Blu-ray, TV)
    Adcom GFA-565 SE Power Amp (250 wpc) Surround Speakers
    Adcom GFA-565 SE Power Amp (250 wpc) Front Speakers
    Adcom GFA-565 SE Power Amp (250 wpc) Center Speakers
    Polk Audio LSiM 706C Center Channel Speaker (Biwired)
    Polk Audio LSiM 707 Front Speakers
    Polk Audio LSiM 702 F/X Surround Speakers
    SVS PB12 Ultra/2 Subwoofer
    PS Audio xStream Plasma Power Cord For Subwoofer
    Signal Cable Silver Resolution Reference XLR Interconnects for Power Amplifiers
    DSR Silverline (9 Gauge) 36 Foot Pair For Surround Speakers
    Salamander Quad 30 Audio/Video Cabinet
    50 Feet/Side Monster UL/CL3 In-Wall 12 Gauge Speaker Cable For Surround Speakers
    36 Foot Blue Jeans LC-1 CM Rated In-Wall Subwoofer Cable
    AudioQuest Cinnamon HDMI 2.0 Cable 2m Prepro To TV
    AudioQuest Cinnamon HDMI 2.0 Cable 2m Prepro To Blu-Ray
    Straightwire Select HDMI Cable 1m Tivo To Prepro
    Douglas Connection DCF-92 Speaker Cables, 10 Feet/Side Center Channel Speaker
    Douglas Connection DCF-92 Speaker Cables10 Feet/Side Front Speakers
    Post edited by DarqueKnight on
    Dang, I feel sorry for the dude that has to follow one of Ray's reviews. :)
    question re: @DarqueKnight's review above:
    When you say:
    In my two channel system, the L200s produced more weighty and solid images with improved definition and speed.
    What is the comparator? Does this refer to the L200s in the first setup vs. the two-channel setup, or a comparison of the L200s to some other loudspeakers you previously auditioned in the two-channel setup?
    Thanks.
    PS and strictly FWIW:
    The sound stage was still shallow and confined to the area between the speakers.
    I had the same impression.
    ... I did note, with some surprise, that the image was ‘small’ – centered between the speakers but not extending beyond them. It was also ‘shallow’; considerably less depth than I am used to from my FrankenAltecs. Both of these observations might stem from the L200s’ placement, so I am loath to fault them too much for this...
    (and not that I'm feeling defensive or anything ;) )
    Perhaps this limited depth/spaciousness arises from the extremely conventional cabinet design?
    Just musing, you know?
  • mhardy6647 wrote: »
    When you say: What is the comparator? Does this refer to the L200s in the first setup vs. the two-channel setup, or a comparison of the L200s to some other loudspeakers you previously auditioned in the two-channel setup?
    Thanks.
    Compared to the way they sounded in the previous home theater setup.
    I had thoughts along the same lines. I wondered if the small sound stage size was a result of the speakers being built more for sonic accuracy rather than imaging.
    tonyb wrote: »
    They are coming to me next. I don't have nearly the same volume of things to experiment with in my home, but hopefully with some help from a few friends I can provide enough detail to add value for others here. :)
    Analog: Hana ML > MoFi UltraDeck > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
    MastersounD Dueventi > Rosso Fiorentino Certaldo or Hifiman EF600 > Hifiman Arya Stealth
    Discogs
    I think A/B comparisons with other, familiar loudspeakers (ideally of similar configuration) are invaluable (not that you were looking for any advice :p ).
    What are any of your thoughts on the new style binding posts? $3 parts? I’m not a fan, I thought the previous gen LSiM has better binding posts.
    Has anyone opened up the box to look inside at the crossover? Prolly a cheap $3 parts?
    How about the driver basket? Are they stamped steel? The LSiM where cast aluminum but prone to damage from the heavy motor structure.
    Not to be negative here as I own Legend speakers but built to a price point is starting to nag at me for premium speakers built overseas.
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
    Buyers remorse setting in?
    I thought the binding posts were quality metal binding posts. That's also mentioned in non-forum reviews out there. I had no problems with the binding posts on the LSiM's but I thought the binding posts on the L200's were superior. For what its worth.
    I'd love to see the innards of the L200 myself... 'course, I believe I've mentioned that a time or two already :#
    48952892252_06f28b4871_h.jpgDSC_6908 (2) by Mark Hardy, on Flickr
    Connection hardware seemed OK to me, but then again, I would consider these (i.e., specifically and explictly the L200s) to be expensive - irrespective of country of manufacture - for small two ways of fairly ordinary design and construction values based on what I have seen of them so far.
    mpitogo wrote: »
    If you own a set, crack them open and see. I'm sure everyone here would like to see pictures as well. I would have cracked open the set I had for demo but that would have been uncool of me since they weren't mine to do that to.
    I got no impression that any of the components were cheap in any respect. The binding posts, since that's what we're stuck on right now, were as good as it gets without getting into esoteric stuff like solid gold posts plated in antique sterling silver with painted markings made from a tincture of 30 year old Scotch and llama spit from a specific herd from an isolated valley in the Andes that Peru sends rodeo clowns with buckets to piss off the llamas so they will spit and they can catch it in the buckets.
    The design was simple, as Doc stated, but there's beauty in the simplicity. The fact that the veneer is an actual wood veneer helps a bunch in that respect because the plain, flat surfaces let the beauty of the wood grain speak for itself. It also means that if the cost is a reflection of the resources that went in to it, cabinet construction and finish is likely the lowest cost factor of the whole thing. So the value is in the driver array and crossover network.
    When I was more active in drag racing, the bracket racers had a saying up here in the Northeast, aka: the salt belt. "If it looks like ****, it runs like stink." meaning that all of the money is in the drivetrain and suspension. So just because it looks plain or even beat up doesn't mean it should be overlooked.
    mpitogo wrote: »
    I prefer the looks and enhanced safety feature (shorting protection) of the LSiM's plastic encapsulated binding posts.
    The all metal Legend binding posts appear to be of very high quality, but I don't know who makes them. They kept a very tight grip on the large, heavy spades of my large heavy speaker cables.
    mpitogo wrote: »
    I wanted to...and I always take a peek inside of my new toys. But, since this was a loaner item rather than my own property, I successfully resisted the urge to take them apart, on the remote chance that something could go wrong.
    mpitogo wrote: »
    I doubt that. I did note that none of the Legend series marketing materials I have read mention crossover parts quality. A marketing brochure for the LSiM series stated:
    "Orth Crossovers—Proprietary engineering, designed and patented by Polk Audio to maintain a lower order crossover design and in-crease power handling. Orth crossovers feature mylar and polypropyl-ene capacitors for sparkling highs and air core inductors for superior transparency. Notch filters and sophisticated Zobel circuits smooth the impedance curve of the system for more efficiency and better high frequency response."
    Now, since the Legend series has overall better sound quality than the LSiM series, I doubt Polk took a step back in crossover parts quality.
    mpitogo wrote: »
    Take yours apart and see. Let us know what you find.
    mpitogo wrote: »
    Is there something specifically about the build quality of your L800s that you don't like? I was impressed with the build quality of the L200s.
    With regard to overseas manufacturing, that is just a reality of today's marketplace. Another way to look at it is that you typically get higher quality at a lower cost than if the same item were built in the US.
    I thought there were some photos of the drivers in one of the early roll-out threads? Am I hallucinating this? Maybe that early YT video?
    I would presume that the drivers in the actual production models are very similar to the 'prototypes' (if that is what they were) shown early on.
    I would be less sanguine as to the identity of the prototype XO boards shown from the
    L800 (which were kind of scary looking ;) ) and the actual production boards -- at least in terms of the passive components used... but this is, obviously, completely speculative.
    https://youtu.be/4Tnns8Os0Hg
    https://forum.polkaudio.com/discussion/187480/new-polk-audio-legend-speaker-series-shown-at-2019-hong-kong-high-end-audio-video-show/p13
    I am under the impression that the so-called "simple design" was a volitional nod to the classic or "legendary" design of bookshelf speakers. I wouldn't be surprised if we see more of it from other other mfg's. I thought the fit and finish was as good as my Dynaudio's.
    Just read through the last few pages of this thread. Thank you all for sharing your thoughts so far! Nice to see such a variety of comments, and impressions from such a wide range of gear and environments.
    And, I'm reminded, my journey has just started! I've got a lot to learn! And experience! :smile:
    The Legend binding posts are of higher quality than the LSiM. Polk has published photos of the L800 crossover and drivers for all to see. For example, look at the Music Direct catalog to see them.
    I should add that one would be hard pressed to find a speaker not made overseas.
    L800 crossover.
    Drivers.
    I don’t want to detract from the positive reviews being made here. If you think I’ve crossed the line please let me know.
    I don’t have buyers remorse. I am pleased as an overall package but they are borderline into the low end of mid-line Focal, Sonus Faber, Scansonic etc. I did find a defect in mine I would rather not air in public. The defect is something which should have been found in QA and rather than deal with support I was able to fix it myself, hopefully not voiding the warranty. It had me think this was a high volume mass produced product they are selling in tens of the thousands.
    I have all the respect for Polk and I do like to support the company. I’ve even recently purchased a bunch more speakers but I guess its me just watching too much Tech Talk Tuesdays by Danny Riche (GR Research) on youtube. Its published under New Record Day. I have to treat is as more entertainment so the OCD doesn’t kick in and make me wanna void the warranty, replace the crossovers, put in no rez, upgrade the crappy binding posts, internal wiring etc...
    Maybe my complaint on the binding posts are unfounded when Totem speakers costing 1/3 these have better WBT binding posts while these have binding posts which look to cost $3. Likely purchased in the bulk and used across the entire line helps drive that cost down further.
    Those pictures further reinforces my thoughts on the quality of the components used.
    https://youtu.be/7yozUh8xBfk
    Post edited by mpitogo on
    You should probably pull those crossovers while you're in there. They are definitely going to be needing better caps, resistors and inductors.
    You've definitely crossed the line. You want to complain about your speakers do it in your own thread and how dare you post that video in this one.
    Post edited by F1nut on
    Understood @F1nut nothing further from me in this thread.
    I do appreciate the honest reviews by everyone.
Welcome!
Welcome!
