Should I be Responsible?
2
  • Nightfall
    Nightfall Posts: 10,084
    I'm wondering your age if you really need to ask this question? My guess is late teens or early 20's?? Transportation should only take a back seat to housing imo.
    There's nothing wrong with my car. I'm dumb but not that dumb. There are cheaper options if something went wrong with my car that I could get done without thought. It's more a matter of what I really want to do to the car vs speakers.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Nightfall
    edited November 2019
    FestYboy wrote: »
    Even with hyper-mileing (sp), low 50s is the typical on an EF or EG DX. Make sure you aren't too lean, check your plugs on the regular, or get a wide band o2 installed pre cat. Last thing you want to do is burn a valve (not the end of the world, just very annoying).
    It's a VX. Over any other of the Civics it had aero parts, ultra light weight wheels, and a factory 'lean burn mode' that would engage if conditions are right, 5 wire wide band O2 sensor.
    afterburnt wrote: »
  • marvda1
    marvda1 Posts: 4,936
    Buy Speakers
    RABBITHOLE ALERT !!! I got home with the Fiesoles and it took all of a day before I called Skip wanting to upgrade to the Volterras :p
    http://rossofiorentino.com/fiesole/
    Puritan PSM156
  • Nightfall
    marvda1 wrote: »
    Do you run a sub?
    afterburnt wrote: »
  • FestYboy
    FestYboy Posts: 3,861
    My initial statement stands. I would be cautious with those numbers. Lean burn is 17:1, much higher than that, and excessive exhaust temps become an issue.
    Granted, I don't know how you drive or your average speed (both have a huge impact on mpg), but just to be safe, add the wide band and an EGT probe, and keep an eye on the plugs.
    I guess what I'm saying is: get the speakers, and be smart about your car.
  • marvda1
    Buy Speakers
    you will not need a sub. I don't mess with them as they are near impossible to integrate correctly. what size room are you putting them in?
    mine is 12 x 15 x 8.
    Puritan PSM156
  • motorstereo
    motorstereo Posts: 2,315
    Be Responsible and Smart
    Nightfall wrote: »
    Well I do see the handle of "village idiot of club Polk" highlighted in red in your sig :D Apparently I misinterpreted the very first post as well as the poll.
    In that case I'll vote for getting out the plastic and go max for both expenditures
  • chumlie
    chumlie Posts: 8,658
    Buy Speakers
    BlueFox wrote: »
    You can listen to your stereo 24/7, while a car, for most people, sits idle 99% of the time. It’s a no brainer. :)
    70 years experience. Listen to the man.
  • marvda1
    Buy Speakers
    are you thinking about getting the dedicated stands? they're not just plain wood.
    Puritan PSM156
  • afterburnt
    afterburnt Posts: 7,892
    Buy Speakers
    I voted for buying speakears so long as you have the appropriate gear to drive them if not you need to come up with the bucks for that too. Trust me you will sit back enjoying you speakers saying irresponsible is, gotta do this more often.
  • Nightfall
    No you were right. I didn't think it through enough to add all the information in the initial post which made it seem like my car is on it's last leg or something.
    afterburnt wrote: »
  • Nightfall
    Option C it is.
    afterburnt wrote: »
  • Willow
    Willow Posts: 11,216
    Nightfall wrote: »
    Option C it is.
    what is that? move in with Joey?
  • Nightfall
    Willow wrote: »
    Nightfall wrote: »
    Option C it is.
    Left for work an hour early to see if I could find a second job real quick, first place I walked into said yes. Option C is grind.
    Joey's house sounds too bright for me. ;)
    afterburnt wrote: »
  • indyhawg
    indyhawg Posts: 1,668
    Congrats on getting a second job to support the habit.
  • sucks2beme
    sucks2beme Posts: 5,681
    Now you don't have time to listen. Problem solved!
  • afterburnt
    Buy Speakers
    Another good reason to get speakers is you could die, then how would you feel?
  • afterburnt
    Buy Speakers
    Furthermore you should never take responsibility, ever!
  • Willow
    afterburnt wrote: »
    might as well just get both, a new engine and new speakers
  • Nightfall
    afterburnt wrote: »
    Who's not?
    afterburnt wrote: »
  • Nightfall
    I just want to say, also, and no offense to Skip. It's easy to be cynical and say to yourself "Of course he's recommending the things he sells, he wants to sell them." But I now 100% trust that he wouldn't sell something he doesn't believe in. The Rosso's are the real deal. Enough to get stick in my mind so bad that I need to make it happen.
    You should really go listen to them if you're near TX.
    afterburnt wrote: »
    nooshinjohn Posts: 25,877
    Buy Speakers
    afterburnt wrote: »
    Sage advice... Taking responsibility leads to child support for kids that may not even be yours! :o
  • displayname
    displayname Posts: 1,202
    Buy Speakers
    Nightfall wrote: »
    This line made me laugh just based on the size of Texas. But yes, everyone come visit us Texans!
    Analog: Hana ML > MoFi UltraDeck > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
    MastersounD Dueventi > Rosso Fiorentino Certaldo or Hifiman EF600 > Hifiman Arya Stealth
    Discogs
    VR3 Posts: 29,388
    Buy Speakers
    No joke, I drove across Texas and that is one heck of a drive
    msg Posts: 10,450
    Buy Speakers
    Nightfall wrote: »
    No car, no income. That's the risk.
    RePORTED!
    If this is a serious Poll, I'll have to change my answer to
    Buy *extra* speakers AND headphones to wear while you're using those Lime scooter things that are littering up the place.
  • BlueFox
    BlueFox Posts: 15,251
    Buy Speakers
    VR3 wrote: »
    Ditto.
  • aprazer402
    aprazer402 Posts: 3,352
    msg wrote: »
    Nightfall wrote: »
    RePORTED!
    In Omaha we are at the end a six month trial period for the rental scooters. Have both Spin and Lime Co. scooters in downtown and midtown. The riders lay them all over crowded sidewalks on their sides. Someone will eventually trip over one laying on the pavement and legal action will ensue. What a nuisance. The city is also considering a street car line. What a waste too. Few people ride the buses here. Maybe I'm just a curmudgeon. :) Sorry for the slight de-rail.
    mhardy6647 Posts: 34,917
    Nightfall wrote: »
    Alaska's still (much) larger -- in case any of all y'all were planning a day-trip, you know? ;)
  • afterburnt
    Buy Speakers
    aprazer402 wrote: »
    msg wrote: »
    Nightfall wrote: »
    RePORTED!
    You thinks that's bad? They got what I think they call "traffic diets" here where the turn care lanes into bike lanes. They got them scooters all over the place too, funny the weren't parked in front of the homeless tents though. Antway, what was this thread about ?
  • aprazer402
    We have those bike lanes too.
