signa solo
hi, my signa solo stopped working. It was working last night. when I
turned my tv on this am. to whatch news there was no sound. Any ideas
what I should do? I've unplugged all cables for soundbar and still there is
no sound.
  • rooftop59
    rooftop59 Posts: 8,121
    What’s a signa sola? Is it a Polk product?
    Game Room 5.1.4:
    Bedroom 2.1
  • https://www.polkaudio.com/products/signa-solo
    rooftop59 wrote: »
  • @soul2heart How did you have it connected to your TV, optical? What brand and model TV do you have?
  • My Signa Solo has done the same thing, absolutely no sound. That's with any input, Optical, Aux or Bluetooth. The LEDs indicate the correct input selection, and I have done a factory reset (Pwr & Source & Vol+ buttons on the top, with the LEDs flashing to show reset has been correctly commanded) but still no improvement. It is completely silent. Any ideas what it can be ?
  • metoo
    metoo Posts: 1
    Me too. Just as teeseetwo described. Any help?
  • same thing, Polk Signa Solo, leds work, hooked up a different soundbar and works. getting signal from tv. tried BT and aux and nothing. only 45 days old.
  • vinay05
    vinay05 Posts: 1
    Same issue with my Signa Solo. Did any one figure it out the issue and fixed it?
  • java
    java Posts: 1
    Same issue with my Polk Signa Solo. 4yrs old. Any solutions to this?
  • I would recommend sending an email to: Kim.Jasper@soundunited.com and explain what happened.
  • Very same thing has now happened to me. Almost 5 years old. Worked fine a couple days ago, then next time I turned it on: no sound. Remote works. LED’s work. ‘Twas using optical cable input. Tried AUX and BlueTooth on different devices to no avail. Essentially bricked. Factory reset does not help.
    Surely it’s salvageable???
  • Any responses to this thread?
    F1nut Posts: 51,666
    cubudman wrote: »
    Sure
  • LMK4
    LMK4 Posts: 6
    Having the same problem with my soundbar. Turned it off, and then back on later that day to watch tv, and nothing. The lights are on, but nobody's home...
  • Hello,
    Welcome to the Polk forum. Let me refer this to a friend at Polk, can you confirm which model soundbar you have?
  • LMK4
    LMK4 Posts: 6
    SeleniumFalcon - I have a Polk Signa Solo. I have tried everything to get it to work, and nothing. I purchased an aux cord, and tried it on my laptop, and still nothing. I have tried using the bluetooth, but in that mode neither my laptop, tv, or phone could find the soundbar. I had it connected with the optical cable, and tried a new one that works on my other tv and soundbar, but nothing on the Polk. Everything works but the sound - all the lights and buttons are responsive, just no sound.
  • In that case send an email to: Kim.Jasper@masimo.com and explain the situation, he will help straighten it out.
  • LMK4
    LMK4 Posts: 6
    Thank you so much! They sent me a new soundbar, and a much better one at that. Polk is a great company.
  • Nikolai
    Nikolai Posts: 2
    Всем привет. Polk Audio Signa Solo перестал работать. Горит только белый индикатор. Ни в а какие кнопки не реагирует. Может кто подскажет причину?
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,270
    Translation:
    "Hello everyone. Polk Audio Signa Solo stopped working. Only the white indicator is on. Doesn't respond to any buttons. Can anyone tell me the reason?"
  • SeleniumFalcon
    Здравствуйте, добро пожаловать! Эта проблема, похоже, указывает на то, что звуковая панель заблокирована. Попробуйте следующее: отсоедините шнур питания, когда звуковая панель включена. Оставьте звуковую панель отключенной от сети не менее чем на 15 минут. Затем снова подключите шнур питания. Возможно, вам придется повторить эту процедуру 4 или 5 раз.
  • haudevbe
    haudevbe Posts: 17
    It sounds like your Polk Signa Solo soundbar might have encountered a common issue. Try these troubleshooting steps to get it working again:
    1. Check the Basics
    ✅ Ensure the soundbar is powered on – Look for an indicator light. If there’s no power, try a different outlet.
    ✅ Increase the volume – It might have been accidentally turned down or muted.
    ✅ Try a different input source – Switch between AUX, Optical, or Bluetooth to see if any work.
    ✅ Check TV audio settings – Make sure the TV is set to output sound through the soundbar (Optical or AUX, depending on your connection).
    2. Reset the Soundbar
    Unplug the soundbar from power for 5 minutes.
    Press and hold the "Power" and "Volume Up" buttons on the soundbar for 10 seconds while plugging it back in.
    Try playing audio again.
    3. Check the Connection Type
    🔹 Optical Cable Users – Ensure the cable is securely plugged in and check if the TV’s digital audio output is set to PCM (not Dolby Digital).
    🔹 Bluetooth Users – Try disconnecting and reconnecting from your device.
    4. Factory Reset (Last Resort)
    If nothing works, try a full reset:
    Turn off the soundbar.
    Press and hold the Bluetooth and Volume Down buttons for 10+ seconds until the LED blinks.
    The soundbar will restart and return to factory settings.
    Let me know if any of these steps work! 🚀
  • Nikolai
    Nikolai Posts: 2
    К сожалению ничего не получилось.(
    Хочу добавить про работу светодиодов на саундбаре.
    Когда включаешь колонку в розетку, то загораются все три светодиода( два белых и один синий). Через две секунды остаётся гореть только один белый светодиод, а через 6 секунд этот светодиод начинает гореть в половину силы, как при фонкиции "сон" ( ночной режим). После этого саундбар реагирует только на кнопки изменения громкости. ( Светодиод начинает гореть ярче и потом снова становится тусклее ). Ни на какие "сбросы" колонка не реагирует.
    pitdogg2 Posts: 26,922
    Nikolai wrote: »
    Unfortunately, nothing worked. (
    I want to add about the work of LEDs on the soundbar.
    When you plug the speaker into the outlet, all three LEDs light up (two white and one blue). After two seconds, only one white LED remains lit, and after 6 seconds, this LED begins to burn at half the strength, as with the "sleep" (night mode) phone. The soundbar then responds only to the volume buttons. (The LED starts to burn brighter and then becomes dimmer again). The column does not react to any "resets".
