Herbie Audio Lab - Tube Dampers
Herbies Audio Tube Dampers - 2 Pair @ $50/shipped....each pair.
Teflon/Silicon versions. Will fit 9pin miniature tubes like 12AU7, 6922, 6DJ8 etc etc.
Perfect condition. The new HAL-O III are $45/each.
  • dorokusai
    dorokusai Posts: 25,576
    Price drop $40/pair shipped.
  • dorokusai
    Last call.
  • verb
    verb Posts: 10,176
    So I'm starting to learn more and more about tube vibration, and the potential negative effect on audio. Learned a new word, microphonics.
    Makes sense to me, install a dampening device to counteract any vibration the tube may endure. In mechanical engineering, we do that all the time!
    Bump! BTW! :)
  • dorokusai
    Thanks Verb. It’s a mixed bag. Depending on how they test, microphonics show up. Usually older tubes naturally but if your rocking dual subwoofers...they may appear because of you. It’s a cheap enough tweak to lay some of these endless ideas to rest.
  • verb
    verb Posts: 10,176
    Yup. Fascinating subject that I never knew applied to audio equipment.
    Mass dampers are typically a compromise solution, where only a certain range of frequencies are targeted for attenuation. In reality, a real time adjustable damping system would cover everything, but, as you suspect, very expensive.
    We use real time damping on some of our higher end vehicles.
