Herbie Audio Lab - Tube Dampers
dorokusai
Herbies Audio Tube Dampers - 2 Pair @ $50/shipped....each pair.
Theses are the earlier HAL-O I.
Teflon/Silicon versions. Will fit 9pin miniature tubes like 12AU7, 6922, 6DJ8 etc etc.
Perfect condition. The new HAL-O III are $45/each.
Price drop $40/pair shipped.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Last call.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
So I'm starting to learn more and more about tube vibration, and the potential negative effect on audio. Learned a new word, microphonics.
Makes sense to me, install a dampening device to counteract any vibration the tube may endure. In mechanical engineering, we do that all the time!
Bump! BTW!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Thanks Verb. It’s a mixed bag. Depending on how they test, microphonics show up. Usually older tubes naturally but if your rocking dual subwoofers...they may appear because of you. It’s a cheap enough tweak to lay some of these endless ideas to rest.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Yup. Fascinating subject that I never knew applied to audio equipment.
Mass dampers are typically a compromise solution, where only a certain range of frequencies are targeted for attenuation. In reality, a real time adjustable damping system would cover everything, but, as you suspect, very expensive.
We use real time damping on some of our higher end vehicles.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
