Thrift store 10b(s)? What do I have here?
Just snatched these up at a local thrift for $40 and figured they were some kind of special. (New to vintage audio and Polk audio in general) Got Em home and actually looked at them compared to some online references. They don’t look the same. Help please!
  • SIHAB
    SIHAB Posts: 4,521
    Nice pickup. Hope you like them.
  • Nightfall
    Nightfall Posts: 10,072
    edited October 2019
    Monitor 10s with SL1000 tweeters. Unsure how to know which revision though. Someone will chime in.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Jstas
    Jstas Posts: 14,712
    Pop them out and read the printing/sticker on the magnet.
    Expert Moron Extraordinaire
  • yuck_fes
    Thanks all! I’ll be sure to do that.
    Also fuses are blown on the back. 1a is what was in there, I have some 1 1/2a fuses on hand. Any chance I’ll ruin anything by running a bigger fuse or should I order in some 1a fuses?
  • Jstas
    Jstas Posts: 14,712
    Yes, they are there to protect the crossovers from surges. If you use a hotter fuse, it could break components in the crossovers and then you're looking at an expensive rebuild if you're not handy with a soldering iron and wiring diagrams. Fuses are cheap and can be found at any auto parts store.
  • yuck_fes
    Jstas wrote: »
    Heard that. Just grabbed the keys and I’m out the door!
  • yuck_fes
    Update: one tweeter is inoperable.
    Any tips on diagnosing the problem? Should I just replace the one bad one? Both? Etc.
    F1nut Posts: 49,805
    Swap the tweeters to see if the issue follows.
  • yuck_fes
    Very good idea.
  • yuck_fes
    The problem stays with the speaker after switching tweeters
  • Nightfall
    That's with the new fuse?
    afterburnt wrote: »
  • yuck_fes
    Correct. New fuse as well.
  • tonyp063
    tonyp063 Posts: 1,048
    Crossover rehab time.
    Worth it for those.
  • yuck_fes
    tonyp063 wrote: »
    Worth it for those.
    Looks like I’m going to learn a lot about vintage audio. Kind of excited though.
  • delkal
    delkal Posts: 764
    Hook up the "bad" tweeter directly to your amp and play it at a VERY low volume (barely moving the dial). If you get no sound or scratchy/distorted sound your tweeter is bad. Rebuilding the crossovers is always a good idea but its not going to save a dead tweeter.
  • boston1450
    boston1450 Posts: 7,474
    edited October 2019
    ^^^ I think he said it stayed with speaker. So I'd check fuse connection/clean & wires first & then crossover
    Randy/Maine
  • yuck_fes
    boston1450 wrote: »
    It stayed with the speaker, that’s correct. I just cleaned the fuse terminals with a towel and some isopropyl alcohol. No change. Still dead.
  • yuck_fes
    Looks like I’m rebuilding... Any videos or things I can read to help out with learning this stuff? I’ve got some minor electrical background, never done this before though. I’d like to do these speakers justice.
  • delkal
    delkal Posts: 764
    edited October 2019
    boston1450 wrote: »
    Well so much for my reading comprehension (and I didn't even get out the scotch yet).
    Then the first thing I would do is swap the fuses and retest. I have got a bad fuse before. Then its would be time to pull the crossover and check the continuity between the input and the board. Also look for cooked resistors (you can text them with a multimeter) or bulged caps (harder to test without an ESR meter but they are bad so just replace)
    Tony M Posts: 11,017
    What do you have?
    You have a model of Monitor 10's similar to the ones I bought from a goodwill store for 24.00pr. that started a 15+years long journey into audio heaven. :p
    Those 10's still make jaws drop when I play them for people.
  • yuck_fes
    Tony M wrote: »
    What do you have?
    i am very very excited to get them running at full potential. i can feel myself possibly catching the bug just the same.
  • yuck_fes
    tonyp063 wrote: »
    Awesome. Will do. Thanks!
    mhardy6647 Posts: 33,049
    I can't decide if I really like or really dislike the OP's moniker.
    I think it's worse than a political statement. And since it's not political, it must be ok. :D
  • verb
    verb Posts: 10,176
    Interesting. I had the same thoughts too. But, it is rather provocative, and a direct inference to verbiage that is banned here. Not my thing.
    BTW welcome Mr Yes! :)
  • yuck_fes
    verb wrote: »
    Hey thanks! Glad to be here.
    And to possibly alleviate any tension...it’s not by any means a statement. Haha Popped in my a couple years back, and it’s been my username for multiple platforms since as it is rarely taken and I assume makes people chuckle a bit. 🤷🏽‍♀️
    It does read better than "nuck fo". :D
