Amplifier Advice needed
Hello all,
I have the Polk RTI-A7 Speakers and a Yamaha reciever RXV-485.
I’m thinking about the NAD C368
Do you have any suggestions, because the speakers are power hungry!
Thank you in advance
  • ken brydson
    ken brydson Posts: 8,981
    Your Yammy doesn't appear to have pre-outs to add an external amp....
    mhardy6647 Posts: 34,917
    Ahh, there's the rub :(
  • rooftop59
    rooftop59 Posts: 8,121
    The NAD C368 is an integrated with Dac. I am assuming the OP is going to replace the yammie with the Nad?!?
    Game Room 5.1.4:
    Bedroom 2.1
  • CH46E
    CH46E Posts: 3,595
    edited October 2019
    I'm a big fan of NAD and love my 906 amp. They always seem to play much louder than most would expect from their stated power output. Even when I use it un-bridged at 30 watts per channel it will play loud enough for most.
    I have even bridged two channels for 90 watts on a twin 10 inch sub and it did very very well.
  • mlistens03
    mlistens03 Posts: 2,767
    anonymouse wrote: »
    While NAD is a great brand, and I've owned a few pieces, you really do need a brutish amount of power for those speakers. Have you considered Peachtree Audio? You could get a used Nova for about the same price or less if you watch for them,
    I beg to differ because what NAD sometimes lacks in the quantity of watts they make up for in quality. My C352 sounded better than anything else did on my LSi25s even up to insane levels (about 95-100 DB, maybe not crazy for some). maybe their digital series stuff isn't as brutish, but I kind of doubt that. :)
    I may be a little hesitant with 9s, but you should be golden with the 7s (Probably golden with the 9s too, but less so. ;) )
  • rooftop59
    Following Micahs comment I would suggest an older big ole Nad integrated over that newer digital amp...
    Game Room 5.1.4:
    Bedroom 2.1
    tonyb Posts: 33,065
    This ^^^
    The second question should be, are you using them for HT or just music, or both ? Either way, that receiver isn't going to cut the mustard.
