iPad issue
BlueFox
My original full size iPad only displays an exaggerated Polk background when I connect to the forum at forum.polkaudio.com, while the iPad Mini is okay. It started sometime this morning. Anyone else having issues?
I’m on an iPad Air and not having any issues, but I DO get the screen below for about half a second when moving between screens on the forum (took me a few tries to get a screen shot of it, as it’s that brief...)
― Aleksandr Solzhenitsyn -
Yes, that is it all the time on my full size iPad with iOS 9.3.5, which is the last version Apple supports on this hardware.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I am getting this on my tablet (iPad Mini 2nd Gen) and my computer as well (Win7, Google Chrome.) I don't have the problem with that showing up all the time.
Bud, Did you try deleting cookies? -
I can’t find any options for Cookies in any of the selections.Lumin X1 file player, Westminster Labs interconnect cable
What browser are you using?
In Chrome you click the three dots on the top right, select "settings" I think? And then scroll down. It may be under advanced at the bottom of the page.
I can't remember how to do it in Safari. -
Found it. Thanks.
Same problem. No help, and now I have to re-add all my sites. LOLLumin X1 file player, Westminster Labs interconnect cable
I exclusively use my iPad Pro 13” . Just letting you know I have had no issues.
Good luck. DMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?” -
The issue, most likely, is the OS version on the iPad. Apple quit supporting the iPad hardware I have, first Retna display. The real problem is Vanilla does a terrible job of QAing their updates.Lumin X1 file player, Westminster Labs interconnect cable
...The real problem is Vanilla does a terrible job of QAing their updates.
Ding ding ding... Winner!
Also, I get it that companies can’t support hardware indefinitely, but a 10-12 year old iPad should not be abandoned to the trash heap. Unfortunately, when they stop the software updates, they are forcing you into new hardware. I still have my first iPad, and functionally it works great, but from a software point of view, it’s almost useless. Now it just runs the Oppo app to control my 105.
...refurbished iPad from Apple. They’re like new, and it’s impossible to tell they’ve ever been used. Not a single scratch or blemish anywhere.
Refurbished iPads from the Apple Store
Every iPad I’ve ever purchased (over ten of them, between the kids, the wife, and myself) has been through the Apple refurb shop. With the exception of the one my daughter broke dropping it on the tile floor, every one of them still functions. The only reason the old ones are not in service is lack of software support.
Interesting all the spam started after Vanilla screwed up iPad access with IOS 9.3.5. Coincidence?Lumin X1 file player, Westminster Labs interconnect cable
Nope the spamis@bvttHURTdouche bag2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
