iPad issue
My original full size iPad only displays an exaggerated Polk background when I connect to the forum at forum.polkaudio.com, while the iPad Mini is okay. It started sometime this morning. Anyone else having issues?
  • daddyjt
    daddyjt Posts: 3,268
    edited September 2019
    I’m on an iPad Air and not having any issues, but I DO get the screen below for about half a second when moving between screens on the forum (took me a few tries to get a screen shot of it, as it’s that brief...)
    ― Aleksandr Solzhenitsyn
  • BlueFox
    BlueFox Posts: 15,250
    Yes, that is it all the time on my full size iPad with iOS 9.3.5, which is the last version Apple supports on this hardware.
  • mlistens03
    mlistens03 Posts: 2,767
    daddyjt wrote: »
    I am getting this on my tablet (iPad Mini 2nd Gen) and my computer as well (Win7, Google Chrome.) I don't have the problem with that showing up all the time.
    Bud, Did you try deleting cookies?
  • BlueFox
    I can’t find any options for Cookies in any of the selections.
  • mlistens03
    What browser are you using?
    In Chrome you click the three dots on the top right, select "settings" I think? And then scroll down. It may be under advanced at the bottom of the page.
    I can't remember how to do it in Safari.
  • BlueFox
    Found it. Thanks.
    Same problem. No help, and now I have to re-add all my sites. LOL
  • Dabutcher
    Dabutcher Posts: 2,637
    I exclusively use my iPad Pro 13” . Just letting you know I have had no issues.
    Good luck. D
  • BlueFox
    The issue, most likely, is the OS version on the iPad. Apple quit supporting the iPad hardware I have, first Retna display. The real problem is Vanilla does a terrible job of QAing their updates.
  • daddyjt
    BlueFox wrote: »
    ...The real problem is Vanilla does a terrible job of QAing their updates.
    Ding ding ding... Winner!
    Also, I get it that companies can’t support hardware indefinitely, but a 10-12 year old iPad should not be abandoned to the trash heap. Unfortunately, when they stop the software updates, they are forcing you into new hardware. I still have my first iPad, and functionally it works great, but from a software point of view, it’s almost useless. Now it just runs the Oppo app to control my 105.
  • daddyjt
    Kex wrote: »
    ...refurbished iPad from Apple. They’re like new, and it’s impossible to tell they’ve ever been used. Not a single scratch or blemish anywhere.
    Refurbished iPads from the Apple Store
    Every iPad I’ve ever purchased (over ten of them, between the kids, the wife, and myself) has been through the Apple refurb shop. With the exception of the one my daughter broke dropping it on the tile floor, every one of them still functions. The only reason the old ones are not in service is lack of software support.
  • BlueFox
    Interesting all the spam started after Vanilla screwed up iPad access with IOS 9.3.5. Coincidence?
    txcoastal1 Posts: 13,520
    BlueFox wrote: »
    Nope the spamis@bvttHURTdouche bag
