L800 SDA Pro in depth w/ Stu Lumsden
    F1nut Posts: 51,749
    edited September 2019
    News to me, that was not discussed.
    Studying my SDA crossover photo there are no switches or jumpers on the board.
    nooshinjohn Posts: 25,916
    Can you post the pics now?
    F1nut Posts: 51,749
    I don't see it either. The only thing I can think of is swapping wires in the top right corner of the board...
    F1nut Posts: 51,749
    I suspect it was an idea that was ultimately not implemented.
  • verb
    verb Posts: 10,176
    From the patent application...
    wrote:
    The angled first and second arrays are then are then fed signals from a new crossover which is optionally configurable using switches or jumpers such that either (e.g., left baffle or right baffle) array can be selected by the user or installer as being (a) the main array or (b) SDA/effects array by rerouting signals through a switch or jumper block.
    Does this mean that we get to determine which driver performs the SDA function?
    That's interesting John. I was reading in the text where they mention retailers, distributors, etc., not really preferring to stock L and R speakers! Very interesting! :)
    pitdogg2 Posts: 27,035
    verb wrote: »
    Well that does make sense as looking at the backs i do not recall seeing left or right on the label.
    Interesting
  • BlueFox
    BlueFox Posts: 15,251
    Since there is no L/R speaker, I wonder if this means they are just stereo speakers without the interconnect cable? If so then I wonder how they sound when used like other speakers. If they sound great as stereo speakers then Polk does have a winner with these speakers.
  • vmaxer
    vmaxer Posts: 5,120
    BlueFox wrote: »
    They do have a interconnect
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • BlueFox
    Yes. The comment was in regard to it not being used, for whatever reason.
  • Emlyn
    Emlyn Posts: 4,702
    The L800 speakers are identified as being sold as Left or Right speakers come November. I think in the video Stu also said the larger crossover board goes in one of the speakers but not both. Patent application specifics don't always translate to real world product when possible user options being exercised or not are involved. In the case of the patent filing, Polk is actually the end user rather than individual customers being the end user of the engineering design.
  • Kurt300
    Kurt300 Posts: 302
    So it seems as if the L800's are exclusively for 2 channel setups? Could anyone see any usage for dual purpose setups (2 channel & multi-channel surround sound, replacing primary L and R speakers)? Or would the introduction of additional audio from non-L800 channels nullify the "opposite channel dampening effect" in a way that degrades perception and enjoyment of multi-channel surround sound for movies? My first thought is that the SDA effect would be degraded but not nullified, as the L800's would still be an intact subset of the wave patterns. Does this make sense?
  • vmaxer
    vmaxer Posts: 5,120
    In the video they said it made it better.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Kurt300
    Kurt300 Posts: 302
    vmaxer wrote: »
    I must have missed that part - thank you.
    I can tell you from the old school 1.2TL perspective.. I have yet to hear a better speaker for HT than the big girls. My in-walls are voice matched to them as well.
  • Emlyn
    Emlyn Posts: 4,702
    There's an Atmos module option that drops into the top of either the L800 or L600, so yes they are both intended for home theater use. Older SDA speakers also make good home theater speakers with a center channel. Automatic setup features in a receiver or AV preamp may or may not get confused with the SDA function though. Haven't seen anything mentioned about that yet. There may be some special auto setup considerations for systems like Audyssey that'll be covered later. Or maybe they've been designed around that already.
  • BlueFox
    One point is you DO NOT need Atmos for excellent home theater. I don’t even use my sub anymore for HT.
  • FTGV
    FTGV Posts: 3,650
    Emlyn wrote: »
    The speaker in the pic is identified as Left so they are sold as a Left/Right pair.
    verb wrote: »
    Interesting
    FTGV wrote: »
    Emlyn wrote: »
    Yep I overlooked it on my phone. I was looking down at the L800 label instead it was right there between the binding post's. I guess I thought it would be like the older SDA's near the model number.
    As Doc would say. ....Derp!
    VR3 Posts: 29,426
    I'm 99% certain that each speaker has its own crossover board. That smaller crossover in the pic probably goes to the bass section.
    I think Polk was smart with the design because in the event of a separated pair, it looks like you could just swap the way it is hooked up internally.
  • FTGV
    FTGV Posts: 3,650
    VR3 wrote: »
    Yes each speaker will need the full crossover assembly. It would need to wired as a left or right during assembly.
