L800 SDA Pro in depth w/ Stu Lumsden
heiney9
All this SDA talk makes the place feel like it did years ago.
I wasn't here years ago, but I am feeling it today! I can imagine, back in the day, and then, after the SDA line was discontinued, aw man!
But, they're back! Woo hoo!
Hope you become a Legend dealer Skip!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Already posted Brock.Political Correctness'.........defined
President of Club Polk -
I'm very happy they are not amplified or have electronics in them as I would never consider owning them- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
News of these got me interested in Polk Audio again!
Welcome @Deltadon yes very exciting. More to come as folks here (including me) are eager to get their ears on em!
Thanks. Love to know how they sound in comparison to the LSiM series and of course the original SDA speakers. I had an old pair of SDA compact bookshelf speakers years ago.
Awesome! Love the CRS's for sure! I just picked up a minty pair not too long ago for crazy cheap! Most likely destined for the garage rig at some point!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Curious to know what cables are being used for the demos and if there is any difference in the sound.
Deltadon post #3 and your on the brink of a rabbit hole! Yes! I was a cable non-believer, but I have witnessed on my own rig substantial improvements with good quality cables! Lot's of choices, both speaker cables and IC's, for your journey.
Not sure of what they ran at RMAF, but lot's of information (and debate) on cables here! Have fun!
Polk has used Audioquest, but I'm not sure what they used at RMAF. Of course cables will make a difference in the sound. They are after all a component.Political Correctness'.........defined
Just curious because I would think that they did plenty of research to optimize the design. It may also depend on the amplifiers being used as well. The computerized tools that engineers have at their disposal nowadays is amazing. Have the technical specs for the L800s been published? -
I’ve watches this video several times and it’s such a good job on so many levels. Kudos to Stu and everyone at Polk!
There doesn't appear to be a cable between the Legend SDA speakers right? How is the SDA sound achieved, or is that a secret only Polk Audio, their parent company and the Chinese government knows? Do these speakers have any new pending patents?
There is a cable! SDA IC cable! Only on the L800's.
Back side interface:
Cable:
They do have a interconnect cable.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Thanks for correcting me, I also missed it at 10:51 in the Stu Lumsden video. So there is an optimal spacing based on the cable length, which is?
Interesting note about new patent claims at 10.57.Post edited by Deltadon on -
Duplicate post, please delete.
Good question. The cable is 12 feet long I think....Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I hope they make a 20 footer at some point...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Spacing is really dependent on your listening position, IIRC. Ideally, you should space them such that it forms an equilateral triangle between yourself and the speakers.
My SRS's are about 10ft apart.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Looking at the way the rear of the speaker looks, the 12’ cable only allows for a spacing of about 8 feet between them. My TL’s are 9 feet at centerline, but need 18 feet to go through my cabinet from one side to the other.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Can the cables be connected in series to increase separation?
That cable looks as if two can be connected in series to increase length. It has a male and female on both ends. That will be answered soon.2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
I imagine they would sell longer after market cables- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
20 feet? Are you guys listening in a warehouse?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
The extra length helps with cable routing. Some people don't want to have the cable strung out like a clothesline between the speakers.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Now, call me a heretic, but maybe the cable length was set to 12 feet for a reason(?).
The product page indicates other lengths of the SDA cable will be sold but the speakers come with a 12 foot cable in the box. My guess is a dealer of the Legend line will accommodate the setup for the purchaser so they're happy with the product. I always thought the 20 footer was way too big and resulted in having to find a way to avoid coiling the extra length.
Here is the patent information for the new SDA's
http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO2&Sect2=HITOFF&p=1&u=/netahtml/PTO/search-bool.html&r=2&f=G&l=50&co1=AND&d=PTXT&s1="polk+audio".AANM.&OS=AANM/"polk+audio"&RS=AANM/"polk+audio"The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
From the patent application...
The angled first and second arrays are then are then fed signals from a new crossover which is optionally configurable using switches or jumpers such that either (e.g., left baffle or right baffle) array can be selected by the user or installer as being (a) the main array or (b) SDA/effects array by rerouting signals through a switch or jumper block.
Does this mean that we get to determine which driver performs the SDA function?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
https://www.youtube.com/watch?v=4Tnns8Os0Hg
