Google Home can't find Polk MagniFi MAX
Installed Google Home and tried to create a new device. After some searching it says no device found. The soundbar is on and right next to the iPad. I just read up the menu and the Chromcast Built-in indicator light isn't on. Is that the reason? How do I get it to come on? When I turned the power on the orange power light came on then 5 white lights came on (Menu says 'OPTICAL') briefly and went off leaving only the orange power light.
