Google Home can't find Polk MagniFi MAX
PeggaramaNo1
Installed Google Home and tried to create a new device. After some searching it says no device found. The soundbar is on and right next to the iPad. I just read up the menu and the Chromcast Built-in indicator light isn't on. Is that the reason? How do I get it to come on? When I turned the power on the orange power light came on then 5 white lights came on (Menu says 'OPTICAL') briefly and went off leaving only the orange power light.
I thought maybe it's because the optical cable is connected to the TV so I unplugged it, powered off and powered back on. Nothing changed. The 5 light came on and off.
Try turning on Bluetooth on your phone and then close and relaunch google home app
Turning on the BlueTooth in your phone and closing can help you get rid of this.
Did you try google maps2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »Did you try google maps
Or asking Alexa?
