Cambridge CXN (V2) next acquisition
12357
  • Nightfall
    Nightfall Posts: 10,084
    edited August 2019
    I tried that. Even switched it to low and back to HiFi. I'll check it out again today though. This was my first time back on Tidal since the Auralic Mini, maybe it was an issue that I reopened/paid my account and immediately logged in on the Cambridge?
    afterburnt wrote: »
    Village Idiot of Club Polk
    Clipdat Posts: 13,078
    That's weird. You might try completely removing the account from the CXN and re-adding it. I know it's a pain in the **** to type in your password using the CXN's knob and screen though.
  • Nightfall
    Tried logging out and back in from the connect app.
    afterburnt wrote: »
  • Nightfall
    edited August 2019
    Okay I logged out of the account from the remote/screen itself, no app. Shut off the CXN. Turned it back on. Logged back in with the remote and screen, no app (what a PITA), and now I'm at 44/16bit
    I can play songs from the Cambridge Connect app now and they're FLAC. So it seems all is good. Did you all login from the CXN and remote itself instead of using the Connect app as well?
    afterburnt wrote: »
  • BlueFox
    BlueFox Posts: 15,251
    I don't remember. Is AAC the Apple Lossless protocol? If so that is what I use when I RIP CDs, and it is fine.
  • Nightfall
    edited August 2019
    AAC is lossy... like a more efficient and modern version of the aging MP3. ALAC is lossless.
    afterburnt wrote: »
  • BlueFox
    Yes. That's right. Thanks.
    Nightfall wrote: »
    Yes, unfortunately that's the way you have to do it to fully "reset" it.
  • joecoulson
    joecoulson Posts: 4,943
    Glad it worked and sorry had my Accalacaladank’s mixed up.
  • tophatjohnny
    tophatjohnny Posts: 4,186
    Nightfall wrote: »
    Can you force it to just stream the normal FLAC? Some albums sounded good others not so much, it was very confusing.
    Depends on original recording as to some sound good others not so. No matter how high up the chain you go with network streamers/players.
  • joecoulson
    There lies the rub for us Audiophiles as we move up the ladder. Songs we used to love become unbearable anymore if they were recorded badly. At least for me.
  • displayname
    displayname Posts: 1,202
    joecoulson wrote: »
    This is somewhat true. For the most part, I think a system with good balance won't ruin songs that are too poorly recorded, but there are some that do just kind of become a bit of a bummer.
    Analog: Hana ML > MoFi UltraDeck > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
    MastersounD Dueventi > Rosso Fiorentino Certaldo or Hifiman EF600 > Hifiman Arya Stealth
    Discogs
  • Nightfall
    joecoulson wrote: »
    On the other hand all of my records sound good to me.
    afterburnt wrote: »
  • BlueFox
    Nightfall wrote: »
    joecoulson wrote: »
    Same here. Of course, some could be better recorded, but if I like the song then I like it.
  • verb
    verb Posts: 10,176
    DSkip wrote: »
    joecoulson wrote: »
    You just haven’t found the right mix yet. When you do even bad recordings can be enjoyable again. It takes a lot of effort to get there - even my system as currently configured isn’t there and it’s driving me freakin nuts.
    Interesting Skip. Was there a time when you had the right mix of gear? Please share! :)
  • verb
    verb Posts: 10,176
    DSkip wrote: »
    verb wrote: »
    DSkip wrote: »
    joecoulson wrote: »
    Several times. New gear brings new synergies though and right now I’m not synergizin to my expectations.
    I can imagine! Iterating on new gear to get that synergy, can be, expensive! What do you look for? It can't be just trial and error. Can it be?
  • verb
    verb Posts: 10,176
    edited August 2019
    DSkip wrote: »
    Give me a call tomorrow if you are truly interested. Its a lot to go through and definitely more than I care to type out.
    For sure! Perhaps not tomorrow, work is killing me right now, but I am definitely interested in your thoughts!
  • erniejade
    erniejade Posts: 6,321
    joecoulson wrote: »
    This is why for one of my rigs, i opted for an integrated that had a loudness button and tone controls. Yes dps probably would have been a better route but, I didn't want to go that route :).
  • tophatjohnny
    Fox nailed it. If you like the song you like the song. It could be on a 50 dollar crap boom box. If the original recording vinyl or CD is crap..crap in crap out. When you use a top of the line player the truth is right there. Of course there are little things we can do to change the bit rates and all but it will be what it is and unless you have a player that really digs in and truly reveals higher sample rates changing anything about your digital recordings for play in a mediocre player is like piissin' in the wind.
    Just dobbie it up and "listen to the music" 🎶
  • Nightfall
    Does anyone make a paid third party app for Cambridge that is anymore functional or more convenient than the Connect app?
    afterburnt wrote: »
  • tophatjohnny
    Nightfall wrote: »
    Yes do tell. The connect app was what I liked the most about my Cambridge experience.
  • gyosa
    gyosa Posts: 769
    Try mConnect ... apple App Store .
    Free and paid versions.
    Should work just fine .....
    It’ll stream the first MQA unfold 24/48khz from tidal ....
    Bk
    Nightfall wrote: »
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • Nightfall
    New firmware
    5th December 2019
    v017-a-070
    Features:
    • Add support for Spotify Free.
    • Add repeat track (repeat-1) functionality to Spotify Connect.
    Improvements:
    • Improved Spotify preset handling.
    • Fixed AirPlay audio glitch when switching between AAC tracks.
    • Various Webmin updates.
    • Fixed CBUS power-on commands when unit starts up in ECO mode.
    • Fixed MCU Error messages appearing when upgrading some units.
    • Added translations for "ECO mode" in Dutch and Polish.
    • Added new StreamMagic splash-screen to unit start-up.
    • Replaced old Cambridge Connect app icons with new StreamMagic app icons.
    afterburnt wrote: »
  • afterburnt
    afterburnt Posts: 7,892
    Nightfall wrote: »
    New firmware
    5th December 2019
    v017-a-070
    Features:
    Improvements:
    Cool, I finally figured out Spotify only to find it required Premium. The Dutch an Polish it a big plus too.
  • gyosa
    gyosa Posts: 769
    edited December 2019
    It still sucks .....
    App still needs a complete and total makeover .....
    Good thing it sounds so good ....
    Bk
  • Nightfall
    StreamMagic update says it adds native Qobuz support? At work can't confirm.
    afterburnt wrote: »
    audioluvr Posts: 5,867
    Finally downloaded the StreamMagic app. I like it a lot better than the Cambridge Connect so far. Quick access to Spotify, Qobuz, Youtube music etc. Plus popular radio stations etc.
    Update: Tidal's search feature doesn't work...
  • displayname
    audioluvr wrote: »
    Interesting, I haven't had any issues with it over the past few weeks.
    My biggest issue seems to be when my CXN is in standby, stream magic won't find it most of the time. Not a big deal, just turn it on with the remote and wait a second. But that's been the biggest glitch I've had.
    I've also seen an improvement with keeping a constant signal from wifi with these past few updates. That's been nice.
    Discogs
    Tidal search works fine on my laptop, just not on my StreamMagic phone app. I'll have to send them an email ( again ) about that. Just sent them one regarding the Bluetooth feature stopped working after the update. Wanted to A/B test between using Bluetooth or USB cable on my laptop to see if I could hear any difference. If I can't I was thinking, for the time being anyways, to use Bluetooth as my 6 month old puppy keeps tripping over the USB cable...
  • Nightfall
    Isn't Chromecast higher quality that Bluetooth? I believe Bluetooth is lossy.
    afterburnt wrote: »
