Polk S60 Treble doesn't work
travistrle
I recently realize that my left polk s60 treble doesn't work. I change the speaker wire with the right speaker. But it still doesn't work.
I use receiver SR6013 to drive my Polk s60. What should I do now? Contact Polk Warranty?
Tweeter or crossover issue, remove the tweeter and plug it in to your Amp at low volume, if it works, your crossover is bad, if it dosnt, your tweeter is bad.
You can also just swap the tweeters between the speakers and see if the issue stays with the bad speaker- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Is it easy to swap the tweeter?
Yes- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
is there a pdf or youtube show how to do that. I honestly don't know how to do that
Remove all the silver bolts on the front baffle, tweeter is probably clipped into it- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Thanks VR3
Today I receive the tweeter from polk customer service, replace it is very simple and that fixes the issue. Really love how quick the polk audio customer service work on my case. It only takes 10 days when I contact the polk customer service.
Great!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Good to hear the great results and also that Polk customer service was quick and responsive to your issue. Congrats!
Now take it easy with that volume knob... LOLSo, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
Agreed, or get a separate amp to handle the power. You pushed the volume too hard and killed your tweeter, be careful or you will be replacing it again.
Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I think I didn't push it hard. I use MARANTZ SR6013 to drive my polk s60 and I usually listen at 50% of volume.
travistrle wrote: »I think I didn't push it hard. I use MARANTZ SR6013 to drive my polk s60 and I usually listen at 50% of volume.
50% (halfway) on the volume knob is usually the upper limit. I would guess that would be even more risky if you are using more than 2 of its 9.2 channels. -
Yup, you are overdriving your Marantz with the volume that high. Receivers simply don't have the ability to meet the demand due to their inadequate power supply. The more volume you use the less power it has especially if you are using more than two speakers.
Start investigating amplifiers. I always recommend getting at least a 200wpc amp. This is usually more than enough to allow your speakers to operate to their full potential, and the best part is the clarity, and details that you will pick up from music that you thought you knew so well is just great.
Amps to look at are....Parasound, Rotel, Outlaw, Emotiva, Sunfire, Marantz also makes amps check Accessories4less for those.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Look for a used Parasound 2250. Audio Advisor has a new 2250 v.2 on sale for $999.00. That's $400.00 off.
