Crown XLS 1502 - is it enough to power RTiA9s?
in Speakers
Hello everyone, got myself into a little dilemma. I was able to pick up a pair of RTiA9s for a reasonable price. Read up before pulling the trigger so I somewhat knew that they needed POWER. I currently have it hooked up to an old Roksan Caspian Power Amp (70W continuous into 8 ohms) via Receiver's front Pre-Outs. Well... it's ok but it's not enough.
I'm not an audiophile - I do enjoy listening to music but it's mainly for the home theater. Would the Crown XLS 1502 be enough or do I need to step it up a little and go to 2002 or step up even more to the 2502?
Thanks for your thoughts and advise.
And please don't return to this thread a month from now and ask which Audio/Video Receiver would be best to "bi-amp" your RTiA9s or I'll send that little dog in my avatar to chew your legs off.
That being said, I used a pro amp on my LSi25s for about 6 months, and at the time I thought it sounded good. But I didn't know what I didn't know, and when I replaced it my ears were opened.
I don't know as much about the RTiAs, but my NAD C352 drove my LSis without breaking a sweat. Good brands to look for in a power amp are NAD, Parasound, Rotel, B&K, etc. Most you can find used for $2-500ish I think?
Other people here can give you more, better advice.
Although crowns get loud, moving to a better dedicated amp was the best move I've made....
For my ears that is
Game Room HT: Denon AVR-X4200w; Sony UBP-x700; Definitive Technology SM450; Definitive Technology LCR2000; Definitive Technology StudioMonitor350; Mirage Nanasats; Sub - HSU VTF-2 MK5
Master Bedroom
Cambridge Azur 551r; Definitive Technology promonitor 800; ACI Titan Subwoofer
haha - guess if I ask now - I won't get my legs chewed off... Marantz SR5010. Not the lastest but somewhat holds up. Only looking to update/upgrade the amp...
I actually started searching the used market (all my equipment are used) for an amp. To get the wattage for the amount I'm willing to spend... I'm looking at 20 year old equipment - hence I started looking at pro amps.
SDA 1C's w/Clarity Cap ESA; PA, Mills, RD0194-1's
SDA 2B TL's w/RD0198-1's
Yaqin MC-30L integrated tube amp
Current is more important than wattage.
Would you be able to provide more info? Still a newb. Thanks.
No.
I can't quantify current is more important than wattage...
I've seen 45 amperes peak current per channel and another unit's spec states It can deliver over 3 kW of fully regulated power... the basics and most consistent quantifiable spec seems to be watts per channel
I need help to understand how current comes into play.
Just get the Crown amp then. While you're at it, trade the RTiA9s for some Bose. Then toss the Bose in a dumpster and get a sound bar.
Village Idiot of Club Polk
No. You.
I’m in Toronto. We use Kijiji up here.
The RtiA9 is a very good performer for home theater but as you have found out require serious power.
I was in the same boat many years ago and ended up buying a Yamaha avr and added a NAD power amp. Handles the speakers very well and currently retails for $1799 CAD. I negotiated mine down to $1500 when I bought it new.
NAD, Anthem & Bryston are all manufactured in Ontario so you should be able to easily access them for an audition.
Checkout Canuck audio mart for used gear. https://www.canuckaudiomart.com/
Bloor Radio in Toronto carries audiophile gear (NAD & Bryston as well). They may have some traded units there in addition to the new gear.
Take the others advice on “pro” amps. They are not designed for the home use environment.
Good Luck with your amp search.
Front - LsiM707, Front presence - LsiM703, Future ATMOS - VS 700LS
Center - LsiM706c, Rear surrounds - 80 F/X LS, VS 900LS. Sub - (pair) Klipsch R-12SW
AVR - Yamaha RX-A3010
AMP - NAD C275BEE
Main HT - LG 4K 75”, Sony UBXP800M2
Bedroom HT - LG 55" 4K, Philips BDP7501 4K UHD player , Yamaha SRT-1500 sound projector, Spare room HT LG 50” plasma, Yamaha BD-671
Office - Pioneer X-CM56, Bose iPod dock
In Storage - 4 - RTiA9, RtiA3, CSiA6, FXiA4, Blackstone TL1
The only source of knowledge is experience. Albert Einstein
I started out with Carver SS amps, which IMO are very good, but moved on. This is a journey after all. Do what your budget allows, I like good used stuff (plenty here on CP from time to time), and see where it goes! We'll help you for sure!
Office: PC, EAR Acute CD Player, EAR 834L Pre, Northstar Designs Intenso DAC, PASS ACA Monoblocks, Denon UDR-F10 Cassette, Acoustic Technologies Classic FR Speakers, SVS SB12 Plus sub, MIT AVt2 speaker cables, IFI Purifier2, AQ Cinnamon USB cable, Groneberg Quatro Reference IC's
Spare Room: Antique Sound Labs Wave AV-8 Monoblocks, Tisbury Mini Passive Pre, Tjoeb 99 tube CD player (modified Marantz CD-38), Analysis Plus Oval 9's, Zu Jumpers, AudioEngine B1 Streamer, Klipsch RB-61 v2, SVS PB1000 sub, Blue Jeans RCA IC's, Shunyata Hydra 8 Power Conditioner
Garage: Cambridge Audio 640A Integrated Amp, Project Box-E BT Streamer, Polk Tsi200 Bookies, Douglas Speaker Cables, Shunyata Power Conditioner
Quality is more important than voltage, current, or wattage when it comes to amplification.
IMO, of course.
my hair dryer puts out 1500 watts doesn't mean it will run my speakers with authority.
I'll do my best to describe here. But I could be wrong and it will not be the first time.
Simply put speakers are not just 8 ohm or 4 ohm. As the ohm value goes down the amp needs to provide much higher current to be able to provide the same amount of watts if it cannot it clips. Some amps can get unstable in the low 3 ohm range if the speakers like to play at or near that range. A good way to tell and amp has ample current and has a great power supple (which is very important and $$$$$$) is if the amp doubles down. 200wpc @8ohm 400wpc @4ohm 800wpc @2ohm 1600wpc @1ohm. THIS AMP HAS CURRENT
Agreed, Jimmy, this is rather unlike you. I mean your posts are a bit harsh, even by Jesse's standards.
Bose... Sound bar...
When I come to this forum, I tone things down drastically compared to other forums.
I was starting to sense the "I came for advice but disregarded everything I was told and did what I wanted to do" attitude that we see so much here. That didn't fully happen, but I was done answering regardless.
A little pug chewing someone's legs off should only be perceived as a joke, as the OP did.
I honestly felt that someone other than me could better explain what I stated about current and wattage. Ken and Ivan got the "No" joke and its intentional abruptness.
My Bose/soundbar joke was an example of me showing restraint.
Being told: "Jimmy. Add an explanation on why current is more important than wattage" and only answering "No, You", was me showing considerably more restraint.
Then Joe decided to call me out again. I guess somehow I threaten his "safe space" where everyone kisses a$$ and loves Tool.
Oh, so now you're going to go from laughing at harmless jokes to acting all offended because you have a little "back up"?
