A McIntosh in Verb's House!
About 5 minutes later, I get this email, from one of the technicians that was cc'd on the original response:
Hi David,
The MC300 is common ground and it is fine to use one in Stereo mode into SDA’s.
However, if you bridge a pair, they are of course separate units and so there is no common ground between to 2 amps. This certainly will not work with the SDA’s.
Chuck Hinton of McIntosh, Wadia, and Snell Tech Support
McIntosh Labs
2 Chambers St
Binghamton NY, 13903Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
So the bottom line, from what I've learned (thank you all for your comments) without an A1 or even better, a Dreadnaught, my SDA's cannot be driven with monoblock amps!
Of course, I have the blade/blade IC, of which IIRC that version is incompatible with either. I wonder if that holds true for any older (non pin/blade) set of SDA's? What to do now? Well, as most of you know, it's a journey!
Lot's of options out there! Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Chuck is very knowledgeable about the combo. He’s been there a while. I f you’v Got money to spend, the newest iteration of the 300 wpc amp has way more headroom than the 300 or the 302. Largest amp that will work with the b/b sda’s. I have heard almost 600 at peaks. I saw the test but can’t locate now.Main System
Marantz AV8802A PrePro
Marantz MM7025 Amp rear surrounds
McIntosh MC7205 Amp center, ceiling and mid surrounds
McIntosh MC300 Amp front mains
Oppo 203 Bluray
Polk SDA-SRS with VR3 monastery crossovers
Polk FX1000 Mid surrounds
Klipsch RP-440C Center channel
Klipsch RP-15M Rear surrounds
SVS prime elevation ceiling surrounds
Rythmik F15HP sub
Samsung 8500 curved screen 65" LED 4K
Mac Mini Server
Office System
Musical Fidelity M6s dac/preamp
Oppo 103D Bluray
Polk SDA-SRS 2
Parasound HCA-1500A
Polk PSW 650 sub
Microrendu
Roku Ultra
Mac Mini Server -
Loving my MC300 for sure! And, now I've got 2 of em!
Try the vertical biamping then now that you have two.
Well, there's always this option. Mac's big dog
https://www.halfordloudspeakers.com/pre-owned-classic-stereo?lightbox=dataItem-jwo24t99"The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
sucks2beme wrote: »Well, there's always this option. Mac's big dog
Wow! That’s cool! Price is right too! Oh God, you got me thinking!
Thinking gets me in a lot of trouble....
Balanced inputs and bridgeable if you feel the need for 1200+ wpc. That is a fair price imo as the 2600's do not come up often like the earlier 2300's and 2500's. The MR80 they have listed is a spectacular tuner which also is fairly priced. I'm glad that place isn't local to me. -
Operation McIntosh is a success! Package delivered this afternoon, our son who is home signed for it, and put it safely in the basement!
Been a crazy week so far, I'll open it up over the weekend!
At least pop open the box right away to check for damage, even if you can't get to hooking it up until the weekend.
Good idea!
Ugh, your right of course!
So thanks Drew you made me strain my back a bit!
Unpacked, from an original MC302 double box including the pallet. 3" foam slabs throughout. Everything looks clean! No obvious signs of damage.
Here she is! On the left.
Of course I'll put her through the paces this weekend!
NICE!!!
Very nice amp set up Dave.
honestaquarian wrote: »Try the vertical biamping then now that you have two.
Interesting. Hadn't really thought about that.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I wonder if vertical is safe to do without the dreadnaught in place? With a different amp on each speaker I'm thinking it's taking the chance of one amp "seeing" the other with the sda connector in place.
I've done horizontal on my 2.3s in the past with no transformer and no problems. But it was done without an active crossover so there were no appreciable gains. -
https://www.psaudio.com/pauls-posts/bi-amping-horizontal-or-vertical/
I was actually thinking of horizontal bi-amping. I always get those two mixed up. -
We wanna see a review
It's an amp it has perty lights, it's heavy and it get freaking LOUD.....
how's that?
honestaquarian wrote: »We wanna see a review
Patience grasshopper!
honestaquarian wrote: »https://www.psaudio.com/pauls-posts/bi-amping-horizontal-or-vertical/
I, did not know, there was a distinction!
This is probably a pretty stupid idea... but couldn't you just simply run a wire from the chassis of each amp? I can't come up with anything obvious that would make this not work, and if there is a wire connecting the two they will be common ground will the not?
Feel free to tell me why I am wrong.
I'd run that past the manufacture for sure before attempting .. I know with the sunfire signatures that this can't be done..or as they said "they don't recommend it"
In other words "Forget it. You'll never see one..."Gustard X26 Pro DAC
It's not that I lie to my wife about equipment cost, it's just that I tell her what I think it should have cost. I think that's a fair compromise.
Hopefully once you leave this earth she won't sell it for what you told her it cost? I am in the same dingy as you Steve.[ -
Well????
Do you have both of those suckers hooked up yet horizontally biamped or what?????
