A McIntosh in Verb's House!
1567810
  • verb
    verb Posts: 10,176
    About 5 minutes later, I get this email, from one of the technicians that was cc'd on the original response:
    Hi David,
    The MC300 is common ground and it is fine to use one in Stereo mode into SDA’s.
    However, if you bridge a pair, they are of course separate units and so there is no common ground between to 2 amps. This certainly will not work with the SDA’s.
    Chuck Hinton of McIntosh, Wadia, and Snell Tech Support
    McIntosh Labs
    2 Chambers St
    Binghamton NY, 13903
  • verb
    verb Posts: 10,176
    So the bottom line, from what I've learned (thank you all for your comments) without an A1 or even better, a Dreadnaught, my SDA's cannot be driven with monoblock amps!
    Of course, I have the blade/blade IC, of which IIRC that version is incompatible with either. I wonder if that holds true for any older (non pin/blade) set of SDA's? What to do now? Well, as most of you know, it's a journey! :smile: Lot's of options out there!
  • sbb2112
    sbb2112 Posts: 134
    Chuck is very knowledgeable about the combo. He’s been there a while. I f you’v Got money to spend, the newest iteration of the 300 wpc amp has way more headroom than the 300 or the 302. Largest amp that will work with the b/b sda’s. I have heard almost 600 at peaks. I saw the test but can’t locate now.
    Main System
    Marantz AV8802A PrePro
    Marantz MM7025 Amp rear surrounds
    McIntosh MC7205 Amp center, ceiling and mid surrounds
    McIntosh MC300 Amp front mains
    Oppo 203 Bluray
    Polk SDA-SRS with VR3 monastery crossovers
    Polk FX1000 Mid surrounds
    Klipsch RP-440C Center channel
    Klipsch RP-15M Rear surrounds
    SVS prime elevation ceiling surrounds
    Rythmik F15HP sub
    Samsung 8500 curved screen 65" LED 4K
    Mac Mini Server
    Office System
    Musical Fidelity M6s dac/preamp
    Oppo 103D Bluray
    Polk SDA-SRS 2
    Parasound HCA-1500A
    Polk PSW 650 sub
    Microrendu
    Roku Ultra
    Mac Mini Server
  • verb
    verb Posts: 10,176
    sbb2112 wrote: »
    Loving my MC300 for sure! And, now I've got 2 of em! :smile:
    Viking64 Posts: 7,504
    verb wrote: »
    HOARDER!!!!!!
  • honestaquarian
    honestaquarian Posts: 3,260
    Try the vertical biamping then now that you have two.
  • sucks2beme
    sucks2beme Posts: 5,680
  • verb
    verb Posts: 10,176
    sucks2beme wrote: »
    Wow! That’s cool! Price is right too! Oh God, you got me thinking! :smile:
  • sucks2beme
    Thinking gets me in a lot of trouble....
  • motorstereo
    motorstereo Posts: 2,317
    edited July 2019
    verb wrote: »
    sucks2beme wrote: »
    Balanced inputs and bridgeable if you feel the need for 1200+ wpc. That is a fair price imo as the 2600's do not come up often like the earlier 2300's and 2500's. The MR80 they have listed is a spectacular tuner which also is fairly priced. I'm glad that place isn't local to me.
  • verb
    verb Posts: 10,176
    Operation McIntosh is a success! Package delivered this afternoon, our son who is home signed for it, and put it safely in the basement! :wink: Been a crazy week so far, I'll open it up over the weekend! :smile:
    Clipdat Posts: 13,078
    At least pop open the box right away to check for damage, even if you can't get to hooking it up until the weekend.
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    Ugh, your right of course! :smile:
  • verb
    verb Posts: 10,176
    So thanks Drew you made me strain my back a bit! :smile: Unpacked, from an original MC302 double box including the pallet. 3" foam slabs throughout. Everything looks clean! No obvious signs of damage.
  • verb
    verb Posts: 10,176
    Here she is! On the left. :smile: Of course I'll put her through the paces this weekend! :smile:
    Tony M Posts: 11,566
    NICE!!! B)
  • indyhawg
    indyhawg Posts: 1,668
    Very nice amp set up Dave.
  • verb
    verb Posts: 10,176
    Interesting. Hadn't really thought about that.
  • motorstereo
    I wonder if vertical is safe to do without the dreadnaught in place? With a different amp on each speaker I'm thinking it's taking the chance of one amp "seeing" the other with the sda connector in place.
    I've done horizontal on my 2.3s in the past with no transformer and no problems. But it was done without an active crossover so there were no appreciable gains.
  • https://www.psaudio.com/pauls-posts/bi-amping-horizontal-or-vertical/
    I was actually thinking of horizontal bi-amping. I always get those two mixed up.
  • We wanna see a review
    :D
    pitdogg2 Posts: 26,927
    It's an amp it has perty lights, it's heavy and it get freaking LOUD.....
    how's that? B)
  • verb
    verb Posts: 10,176
    :D
    Patience grasshopper! :smile:
  • verb
    verb Posts: 10,176
    I, did not know, there was a distinction! :smile:
  • mlistens03
    mlistens03 Posts: 2,767
    This is probably a pretty stupid idea... but couldn't you just simply run a wire from the chassis of each amp? I can't come up with anything obvious that would make this not work, and if there is a wire connecting the two they will be common ground will the not?
    Feel free to tell me why I am wrong. ;)
  • ptrooper
    ptrooper Posts: 501
    I'd run that past the manufacture for sure before attempting .. I know with the sunfire signatures that this can't be done..or as they said "they don't recommend it"
    audioluvr Posts: 5,870
    verb wrote: »
    :D
    In other words "Forget it. You'll never see one..."
  • miner
    miner Posts: 1,305
    steveinaz wrote: »
    It's not that I lie to my wife about equipment cost, it's just that I tell her what I think it should have cost. I think that's a fair compromise.
    Hopefully once you leave this earth she won't sell it for what you told her it cost? I am in the same dingy as you Steve.
  • verb wrote: »
    :D
    Well????
    Do you have both of those suckers hooked up yet horizontally biamped or what?????
