A McIntosh in Verb's House!
  • honestaquarian
    honestaquarian Posts: 3,275
    Oh
    My
    Gawd
    Becky
    Look
    At
    Her
    Bass
    It
    Is
    SOO
    BIG!
    o:)
    B)
  • BlueBirdMusic
    BlueBirdMusic Posts: 3,090
    Great history Verb.
    Harry / Marietta GA
  • Milito
    Milito Posts: 2,003
    Congrats Dave!
  • verb
    verb Posts: 10,176
    Congrats to you verb. Imo 600+ blue eyed watts into any load no doubt gets you into the big boy category.
    It's nice to have choices and I'm wondering is it going to be bridged for 600 watts each or 300+ wpc in a horizontal biamp?
    I'm gonna bridge em. But the first question that comes to mind, are these common ground amps?
    pitdogg2 Posts: 27,857
    You have a dreadnaught is this really a concern?
  • verb
    verb Posts: 10,176
    No dreadnaught yet. Just the standard IC. Any advice would be greatly appreciated.
  • monepolk
    monepolk Posts: 1,154
    I was wondering about that. I don't believe that you can use mono amps with your SRS. I though you were looking at using them on different speakers.
  • verb
    verb Posts: 10,176
    IIRC @motorstereo ran bridged MC2500's on his. Just want to be sure! :smile:
  • monepolk
    He has 1.2TL.
  • verb
    verb Posts: 10,176
    monepolk wrote: »
    He has 1.2TL.
    Yep. So I sent an email to McIntosh. Cause I'm nervous. And, I suddenly remembered that I have an A1 cable from Mark @dorokusai as well! Should be good to go! :smile:
    edited July 2019
    verb wrote: »
    Wait you weren't in the group buy, pretty sure I remember you buying 2 and sending one to Arty... Or am I having a flashback to my microdot days😰
    Ok edit you have SRS so yea B/b ic only. .......
    Wait I smell smoke😆
  • verb
    verb Posts: 10,176
    I do have the dreadnaught parts!
  • verb
    verb Posts: 10,176
    So Ivan you made me look. Went down to the basement. The A1 that I have is pin/blade. Ugh. :smile:
  • verb
    verb Posts: 10,176
    monepolk wrote: »
    Hit the link and I get access denied.
    Tony M Posts: 11,991
    Dang Dave.
    Wrong cable... :s
    You and Drew and your audio journeys' speed bumps :)
    Nothing that can't be corrected though. ;)
  • verb
    verb Posts: 10,176
    Tony M wrote: »
    Dang Dave.
    Wrong cable... :s
    Very true! In the meantime the MC300 is shipped and on the way to Verb’s house! :smile:
  • motorstereo
    motorstereo Posts: 2,422
    Dont run them bridged without the dreadnaught
    edited July 2019
    verb wrote: »
    yea I knew that.
    don't you have 1C's?
  • GlennDog
    GlennDog Posts: 3,158
    verb wrote: »
    Time to get bizzy!
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • verb
    verb Posts: 10,176
    verb wrote: »
    yea I knew that.
    I do! 2 sets in fact! :smile:
  • verb
    verb Posts: 10,176
    monepolk wrote: »
    Thanks for the link! My SRS’s are blade/blade, but I’ll confirm the production numbers.
  • verb
    verb Posts: 10,176
    Yep. Hopefully McIntosh comes back with good news.
  • honestaquarian
    What news would you be looking for?
    Unless you rebuild the crossovers and set them up for the dreadnought, you will not be able to run these bridged.
    You should be able to vertically bi-amp your speakers with them though.
  • BlueBirdMusic
    Thought you might like this one with history. $950 and owned by the drummer of band "The Younguns" out of Atlanta.
    https://atlanta.craigslist.org/nat/ele/d/duluth-vintage-mcintosh-mc2100/6942217581.html
    Harry / Marietta GA
  • sbb2112
    sbb2112 Posts: 134
    I have an MC300 amp and the same blade/blade SRS's. The MC300 is common ground in itself but a dreadnaught won't change the fact that the SRS's are not compatible with bridged or monoblock operation. The pin/blade SRS's crossovers allow this with a dreadnaught but not the original SRS's. You could frankenstein the crossovers to get this to work but the drivers are wrong for the P/B versions. I spoke with McIntosh about this subject as I had the same thoughts but realized the dna wasn't there. I had trey build me a set of crossovers for the B/B version and they sound great. Just never going to be able to go there with them. The 300 will drive the speakers quite well as is. I am considering working on the subwoofer angle to get more and better sound and reduce the load on the whole. If I come across a set of 1.2's or TL version, that could change.
    Main System
    Marantz AV8802A PrePro
    Marantz MM7025 Amp rear surrounds
    McIntosh MC7205 Amp center, ceiling and mid surrounds
    McIntosh MC300 Amp front mains
    Oppo 203 Bluray
    Polk SDA-SRS with VR3 monastery crossovers
    Polk FX1000 Mid surrounds
    Klipsch RP-440C Center channel
    Klipsch RP-15M Rear surrounds
    SVS prime elevation ceiling surrounds
    Rythmik F15HP sub
    Samsung 8500 curved screen 65" LED 4K
    Mac Mini Server
    Office System
    Musical Fidelity M6s dac/preamp
    Oppo 103D Bluray
    Polk SDA-SRS 2
    Parasound HCA-1500A
    Polk PSW 650 sub
    Microrendu
    Roku Ultra
    Mac Mini Server
  • verb
    verb Posts: 10,176
    sbb2112 wrote: »
    Good to know we have another MC300 lover amongst us! I did get some responses from McIntosh, affirming your comments.
  • verb
    verb Posts: 10,176
    I get this email first, ok common ground, that's good, but what about bridged monoblocks? :smile:
    Hi David,
    Yes, the MC300 unit is a common ground amp. Below is a picture of the back panel of the unit. You see there are various taps depending on which ohm speaker you have as well as a negative terminal called “ground”.
    Jordan Smith McIntosh Tech Support
    McIntosh Labs
    2 Chambers St
    Binghamton NY, 13903
