Focal JM Lab Mezzo Utopia modification
I have had the tweeters playing free air half the day... all I can say is I cant wait to get these speakers back together lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Sweet!
Does the extra volume taken up by the upgrades affect mid/low end inside the cabinet? -
Hmm, not really. Since I distributed the networks over all three enclosures, won't make any difference. If I had packed it all in the bass enclosure, I think that may have presented an issue.
But I am going from over 30 ft of internal wiring to under 10, so much less in the way- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Omg bro that’s so pro
Lol, thanks man- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
One last pic before I put the tweeters back in the enclosure!
Made some progress...
Extreme tight fit in that upper cabinet!
Coming along nicely Trey
Thank you!
Hard to get any feel for sound with the mid and tweet only. The lower woofer actually reaches fairly high in the spectrum, but I can tell the mid and tweet are blending very well, which I like.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Rebuilt one today, using the Quadrax and dh labs wiring is a true bear, adds substantial time for sure.
Didn't take to many pics because I was excited, haha, will take more pics on the second one.
Can't wait to get the rest of the caps in though
Received a threatening email earlier that after 16 weeks I would receive capacitors this week. How dare they! (I cant wait!!)
You do nice work, Trey.
Thank you 😊- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Nice bro
Nice Trey. I wanted to see more speaker/room colors so I modded the pic.
"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Thanks guys, I'll take some more pics later on, I have my desk and stuff in the room at the moment while I work on my office- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Here's some pics
Wow did you make those?
I had them made by digital deck covers
Cut the cleaning needed on the speakers by 95% and they are padded as well for some protection- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Yes, you wouldn't regret it, great product- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
They are here!!
Since the maker of diffraction be gone is no more (i guess) 0 I tracked down a similar felt sold by Grainger...
The Mezzo utopia has 2 diffraction points on the tweeter baffle where the aluminum meets the wood. There is a small lip, maybe 1/32" of an inch... I placed a 1.5" wide piece of felt at this break on each side and the difference was what I recall diffraction be gone doing. The high end really cleaned up, well worth the $10
dont worry Jody, Ill include some in your box of goodies to play with! haha
One back together, about to do the other!
Thank you! 😁- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Wow Trey. Drool
One of these days. Elacs. -
Thanks Joe!
We can make the elacs beast! 💪
Just finished the second one and am about to sit down for a listen- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
