Need economical cables ....
Need 2 6 foot runs of 14 gauge cables ....
Any economical suggestions?
I’m talking like Blue Jeans economical ...
Their 14 gauge cables are almost a half inch thick ... too unwieldy....
Bk
PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • codycatalist
    codycatalist Posts: 2,661
    @Clipdat Has mentioned the Krukonceptz Krux is a good wire that isn't too expensive. DIY is pretty cheap at $3 and some change per foot. You can get wire that is already terminated on Ebay.
    The smallest they have is 12g though.
    Drew, were these hard to handle, bend, heavy in any way?
    Clipdat Posts: 13,100
    I was going to mention the Krux cable, but it's pretty big because of how all the individual wires are braided together. Also as a result of that it's fairly heavy. Seeing as how the OP didn't like the BJC cable, I figured he also wouldn't like these.
    That being said, the price is right, as is the performance. I highly recommend trying these out if they fit your budget: https://www.ebay.com/itm/KnuKonceptz-Krux-Interlaced-Braided-8-Gauge-Speaker-Cable-8-Pair-w-Banana-Plugs/392222051240
    They're also available in bi-wire.
  • jdjohn
    jdjohn Posts: 3,381
    To be sure, speaker cables? If so, you can't beat Monoprice 14AWG pure copper cables for price. You can find that at Home Depot or Lowe's...or Amazon.
  • mrloren
    mrloren Posts: 2,474
    Monoprice or Amazon Basic
  • rooftop59
    rooftop59 Posts: 8,120
    Clipdat wrote: »
    For that price you can also win a ZU audio auction for speaker cables FYI...haven't heard the Knus so I have no idea how they compare...
    Game Room 5.1.4:
    Bedroom 2.1
  • helipilotdoug
    helipilotdoug Posts: 1,230
    We have a great 14 gauge cable we can make for you, our Bravo 14 AWG OFHC Speaker Cables. Or I can put together a DIY kit for you if you'd rather do it yourself. PM me if you are interested. As a Club polk member you get a 10% discount.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • westmassguy
    westmassguy Posts: 6,850
    Doug will get you squared away.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • gyosa
    gyosa Posts: 770
    edited July 2019
    Found some Kimber Kable in my box of forgotten stereo stuff ...
    2 , 6 foot pieces ....
    Forgot I had it ...
    I bought it in the late 80’s - early 90’s .... was rather expensive, I thought , at the time ...
    Used it on my B&K with the Polks .....
    Also found some brown/black Kimber Kable ...
    I remember one was more expensive than the other ... can’t remember which , though ......
  • delkal
    delkal Posts: 764
    Enjoy. Vintage Kimber Kable should be better than any of the brands we were discussing.
    But after 30 years it would be a good idea to cut off an inch and get to the bright wire.
  • gyosa
    gyosa Posts: 770
    edited July 2019
    Will do ...
    Also found a bunch of interconnects by MIT and Vampire Wire ...
    Totally forgot about that box of old forgotten stuff from back before I got married and had a kid !
    The days of tape decks , turntable's and CD players ....
    Ha ha ...
    Bk
  • PSOVLSK
    PSOVLSK Posts: 5,400
    Glad you found it before you purchased new stuff. I always seem to find my hidden/forgotten stuff after the fact.
  • gyosa
    gyosa Posts: 770
    edited July 2019
    Anyone know which kimber is the better stuff ?
    Looking at their website , looks like the black/grey is - assuming it's the same stuff...
    Both are 8 strands .
    Bk
  • +1 for Monoprice -- You don't need to spend more than Monoprice for speaker cables.
    +1 for Blue Jeans cable, when it comes to interconnects.
  • Black Gray Kimber is VS
    Black Brown Kimber is PR
    VS > PR
    Yeah right, and all you need is a Yugo for a car too.
  • rooftop59
    tonyb wrote: »
    Don’t forget miller light for beer and a jug of burgundy for wine!
    Game Room 5.1.4:
    Bedroom 2.1
    nooshinjohn Posts: 25,995
    rooftop59 wrote: »
    tonyb wrote: »
    You don't know what you are talking about. All you need is Colt 45. Miller and the Jug are snake oil.
  • SIHAB
    SIHAB Posts: 5,587
    the champagne of beer!
  • mrloren
    Actually Monoprice has stepped up some of their wire offerings
    https://www.monoprice.com/product?p_id=33839
    The normal in-wall stuff is not bad. No, I didn't say great, just not bad. Better than Home Depot lamp cord.
    The clear jacket Monoprice stuff will turn green in 6 months to a year.
    In-wall speaker wire is more permanent which is why it should be a better quality cable. Your system over time evolves for the better I would hope, so why leave a not so great cable in the walls to run it.
    At least for the front 3 speakers, surrounds don't need great cables because they handle ambient sounds.
  • Blue jeans cheap, and neutral sonically, tight bass = CAT5. Have used for interconnects and speakers, also is a great internal wire. DH labs silver over copper 14 ga does many things very well, you could spend more and get less. Also I have used DH ic wire for tweeters, very very good. Small guage is fine unless you run at 50 watts all the time. OK so this is rhinestones on a jean jacket spelling out Jersey Girl.
    mhardy6647 Posts: 35,224
    edited September 2019
    Strictly FWIW:
    I outgrew my CAT5 infatuation about a decade ago -- although there's still a little floatin' around here (e.g., inside my Duplex cabinets). Need to do something about that one of these days...
    Nowadays, I like this stuff -- though perhaps not for y'all with monstrous powered amplifiers driving low-sensitivity loudspeakers, though, I'll readily acknowledge.
    Belden 9497 (13 ga)
    (borrowed image: https://cheaptubeaudio.blogspot.com/2017/04/l-japanese-497mkii-r-us-9497-click-pic.html)
    47715535421_e0e1c2eb9d_b.jpgDSC_4465 (2) by Mark Hardy, on Flickr
    (the sharp-eyed will espy CAT5 feeding the supertweeter in the photo of my Frankenaltecs' all-first-order XO above :# )
  • gyosa
    gyosa Posts: 770
    I’ve been using the Kimber VS (black / grey ) for the last month or so ....
    Sounds great ....
    Bk
  • BDT
    BDT Posts: 212
    I've always had good luck with Signal Cables........
