Audi S4 running better then expected at the Track
mantis
mantis Posts: 17,408
Hello all,
my Son and I went to the Track to test out the S4 to see how she will run in stock form with just a Cold Air intake on it. New Tires oil change, transmission service and 40k on the clock and down to the track we went.
First pass was a shocker at 12.6@109. WOW what a run, my son got excited and went right back as I told him you need to allow the car to cool down before the next pass but he wanted to see what a second pass hot would do. It still screamed 12.9 @108 . The last pass on it was a16.6 @110 which was a .001 off from a 12.5. This car is fantastically fast especially for being factory stock with a cold air. Amazingly good car.jod9lidakv3f.jpg
Dan
  • Milito
    Milito Posts: 2,003
    Nice time. Pump up the front tires for less drag.
  • Emlyn
    Emlyn Posts: 4,718
    That’s a great engine in the S4, and it’s capable of more with easy changes. And there is much more that can be done with a bunch of money. May be best to keep it as a daily driver setup though.
  • jflail2
    jflail2 Posts: 2,868
    Is this the supercharged version or the newer twin turbo? I had the supercharged engine in my 2012 and it was an absolute joy to drive.
  • Emlyn
    Emlyn Posts: 4,718
    That’s the supercharged engine. Same engine I have in an SQ5, although Audi did tweak the output for various applications. A very smooth and responsive engine and transmission combo. I understand why they went for the turbocharged version in more recent cars. Marginal fuel economy gains. I prefer no turbo lag, even if it’s minor.
    Clipdat Posts: 13,095
    edited July 2019
    When I saw the thread title I got excited, but then I see by "track" you meant "drag strip". :'(
  • mantis
    Milito wrote: »
    We ran 2lbs over stock for a tight smooth run. But it did spin all 4 tires on the launch just a bit.
    Dan
  • mantis
    Emlyn wrote: »
    Having a 12 second daily without having to put drag radials on is amazing. We might give it a stage 1 Tune and an competitive exhaust and call it a day. The tune alone adds 100 HP which is absolutely nuts as back in my day that was not the case.
    Dan
  • mantis
    jflail2 wrote: »
    It's supercharged. Check out the photo above of the engine bay. The supercharger sits right on top of the engine.
    Dan
  • mantis
    Emlyn wrote: »
    Does the SQ5 come with a Double Clutch Transmission? It's probably the very fastest shifting transmissions I ever drove. Right from the factory it is completely awesome.
    Dan
  • mantis
    Clipdat wrote: »
    Nope I meant Track. Thats what we call it around these parts. no one around here I know calls it a drag strip or drag way. It's called the track.
    Dan
