Audi S4 running better then expected at the Track
mantis
Hello all,
my Son and I went to the Track to test out the S4 to see how she will run in stock form with just a Cold Air intake on it. New Tires oil change, transmission service and 40k on the clock and down to the track we went.
First pass was a shocker at 12.6@109. WOW what a run, my son got excited and went right back as I told him you need to allow the car to cool down before the next pass but he wanted to see what a second pass hot would do. It still screamed 12.9 @108 . The last pass on it was a16.6 @110 which was a .001 off from a 12.5. This car is fantastically fast especially for being factory stock with a cold air. Amazingly good car.
Dan
Nice time. Pump up the front tires for less drag.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream
That’s a great engine in the S4, and it’s capable of more with easy changes. And there is much more that can be done with a bunch of money. May be best to keep it as a daily driver setup though.
Is this the supercharged version or the newer twin turbo? I had the supercharged engine in my 2012 and it was an absolute joy to drive.2007 Club Polk Football Pool Champ
"It's like a koala bear crapped a rainbow in my brain!" -
That’s the supercharged engine. Same engine I have in an SQ5, although Audi did tweak the output for various applications. A very smooth and responsive engine and transmission combo. I understand why they went for the turbocharged version in more recent cars. Marginal fuel economy gains. I prefer no turbo lag, even if it’s minor.
When I saw the thread title I got excited, but then I see by "track" you meant "drag strip". :'(
We ran 2lbs over stock for a tight smooth run. But it did spin all 4 tires on the launch just a bit.Nice time. Pump up the front tires for less drag.
Dan
Having a 12 second daily without having to put drag radials on is amazing. We might give it a stage 1 Tune and an competitive exhaust and call it a day. The tune alone adds 100 HP which is absolutely nuts as back in my day that was not the case.That’s a great engine in the S4, and it’s capable of more with easy changes. And there is much more that can be done with a bunch of money. May be best to keep it as a daily driver setup though.
Dan
It's supercharged. Check out the photo above of the engine bay. The supercharger sits right on top of the engine.Is this the supercharged version or the newer twin turbo? I had the supercharged engine in my 2012 and it was an absolute joy to drive.Dan
Does the SQ5 come with a Double Clutch Transmission? It's probably the very fastest shifting transmissions I ever drove. Right from the factory it is completely awesome.That’s the supercharged engine. Same engine I have in an SQ5, although Audi did tweak the output for various applications. A very smooth and responsive engine and transmission combo. I understand why they went for the turbocharged version in more recent cars. Marginal fuel economy gains. I prefer no turbo lag, even if it’s minor.
Dan
Nope I meant Track. Thats what we call it around these parts. no one around here I know calls it a drag strip or drag way. It's called the track.When I saw the thread title I got excited, but then I see by "track" you meant "drag strip". :'(Dan
