Help pick my home theater upgrade path! (Towers, subs, or what else)
Landmonster
Landmonster Posts: 79
edited June 2019 in Speakers
Hi guys.
So my home theater as it stands, includes the following:
  • 2 Polk LSiM 703 bookshelf speakers
  • 1 Denon X4500h receiver
  • Xbox One X (media streamer, and 4k Bluray player)
  • Samsung JS8500 65" 4k TV
As such, I have no surround, no subwoofers, and no towers. :(
Planned audio additions:
  • 2 Polk LSiM 707 tower speakers -- ($1600-2000)
  • 1 Polk LSiM 706 center channel speaker -- ($500-600)
  • 2 powered 15" subs (Rythmik, HSU, JTR, etc.... not sure yet) -- ($2500+)
  • 1 power amplifier (either 2, 3, or 5 channels) -- ($1,000+)
  • 1 AVR cooler (Looking at the ACfinity S9) -- ($80)
  • ??? (could be room treatments, power conditioning, atmos speakers, etc... don't know yet... suggest something)
Since I cannot afford all of this at once... The question is.... what should my upgrade path look like?
I see a few real options here:
Option A: Get a center channel speaker, plus 2 subwoofers, for around ~$3,000. This will give me a complete front stage, lots of bass, and take a load off of the receiver (hopefully)... by crossing over all the bass to the subs. I don't know how much of a load off this is. I should probably add the AVR cooler in here if I do this.
Pros: Gives all the bass I will ever need in my theater up front, and gives a complete front stage.
Cons: Provides no surround sound at all, and the front sound stage may lack depth of without the towers. Receiver may still run hot powering 3 speakers, even if subs are handling the main bass.
Option B: Add 2 tower speakers, and a power amplifier, for around ~$3,000. This will give me a 4.0 surround sound system, and give me much more bass, since I'll be adding power amplification and tower speakers with large woofers. A center channel and subwoofers will not be absolutely necessary yet.... as I can run a phantom center, and allow the amplified Polk towers to make the bass.
Pros: Gives instant access to surround sound, takes huge load off of the receiver.
Cons: Lacks bass from subwoofers, lacks center channel
Option C: Suggest your own combo? I want to stay around $2,500 to $3,000 here for this phase, and use the components I have listed above.
    F1nut Posts: 51,898
    Polk is closing out the LSiM series, so you better buy all your speakers now, which happen to be on sale right now
  • BlueFox
    BlueFox Posts: 15,250
    Do the subs last. I never turn my sub on anymore.
  • rooftop59
    rooftop59 Posts: 8,120
    Yep, wait on the subs: get the lsims now!
    Game Room 5.1.4:
    Bedroom 2.1
  • tophatjohnny
    tophatjohnny Posts: 4,189
    I never turn my subs on..I leave them on. They kick in when they need to. But yes grab them speakers when they are darn near giving them away. Subs can always be added down the line.
  • cfrizz
    cfrizz Posts: 13,415
    Yup, speakers first since they are being closed out. Then an amplifier, then subs.
  • tonyp063
    tonyp063 Posts: 1,135
    Listen to this wisdom @Landmonster
  • PSOVLSK
    PSOVLSK Posts: 5,396
    I'd go with a sub(s) and an amp.
    I don't think floorstanders and a sub will be much better than the 703's and a sub(s) (and this opinion is based on personal experience).
    My personal opinion is that subs make the most difference in an HT.
    Add a couple of SVS or HSU subs and an amp and you will be blown away.
  • rooftop59
    I can also see @PSOVLSK’s logic. The 703s are great speakers, and the two most important speakers in an HT setup are the center and sub. If your room isn’t massive, a 704c with a couple nice subs would be awesome!!!
    Game Room 5.1.4:
    Bedroom 2.1
  • BlueFox
    IMO, that’s just stupid. Unless all you watch are moronic movies that are nothing but explosions. Anyway, you have been given various advices. Take your choice.
  • kharp1
    kharp1 Posts: 3,453
    edited June 2019
    Size of room would help. I'd recommend getting the speakers while they're cheap. 2 fronts and the best center you can afford. Move the current bookies to surround duty. If you can swing it spring for one sub now. You can always add a second later if need be. Then see how it sounds. If you want more from your system then look for a 3,5 or 7 channel amp.
    Depending on room dimensions you could possibly use the 705 and you're looking at $1400 for the pair. Add the center for $230 and you still have enough change to get a nice sub.
    Rome wasn't built in a day.
  • BlueFox
    Yes. Good advice. Sorry for being spun up earlier.
  • PSOVLSK
    I honestly think I could downgrade the speakers in my HT and still be very happy since I have an SVS Plus/2. As a matter of fact, I know I could because I've had lesser speakers (including the LSi703) in my HT.
    Floorstandes and a quality sub or two subs and keep the 703???? That's a tough one IMO.
  • kharp1
    kharp1 Posts: 3,453
    PSOVLSK wrote: »
    You say that until you end up with smaller drivers that distort or become excessively shrill.
  • mrloren
    mrloren Posts: 2,473
    Hmm, hard choice. I'd go with a center and sub for a 3.1 then add floor standers.
  • PSOVLSK
    kharp1 wrote: »
    PSOVLSK wrote: »
    Guess I just don't listen loud enough because I never had that problem with LSi703 as the speakers in my HT.
  • kharp1
    kharp1 Posts: 3,453
    I like lifelike reproduction. Neighbors hated me when I lived in an apartment.
  • shs
    shs Posts: 105
    I use a 703 for a center and 705s for the front left and right. They can definitely do the job when it comes to home theater with the help of subwoofers. If you get 705s or 707s for the left and right, you could use your 703s for surrounds, or use the 703 for L&R and get some 702 F/X for surrounds while they last.
    SONY VPL-VW385ES, Da-Lite 92" 0.9 HD progressive 16x9 screen, Apple TV 4K, Oppo UDP 203, Anthem AVM 60, D-Sonic 4000 (800x3, 400x4) for bed layer, 2 Crown XLS 1002 (225x4) for Atmos; Speakers: Polk LSiM 705s, 703 front, 4 702F/X surround, 4 Polk TL3 (Atmos), Velodyne DD15 Subwoofer.
  • JPete
    JPete Posts: 295
    With $3k I'd go balls deep in the used market and pickup an amp, some towers, a center and a sub. Use the 703s for surrounds and probably still have a little left over for a better player and decent cables.
    Lexicon RT-10, Parasound P5, McCormack DNA 0.5, Polk SDA CRS+, SVS Sub
    Schiit Modi, Luminous Audio Axiom II, McCormack DNA-1, Digital Phase AP 2
    Marantz AV7701, Emotiva XPA-5, Paradigm 11se Mkii, DCM Time Windows, NHT 2C, SVS Sub
    Spares - Kenwood C1 Pre, NAD 2200PE, Polk Monitor 10B, Polk Model 11, other odds and ends
  • Jimbo18
    Jimbo18 Posts: 2,351
    Because of the sales on the LSiM, I would go for the towers and center now, as a couple others stated earlier.
  • F1nut wrote: »
    Do you actually know if they are "closing them out", or just having a sale?
    If they are being phased out, what are they being replaced with?
  • I plan on using my 703s as surrounds. I had intended to get the 707s as L/R, and the 706c for the center.
    My logic for this was that the 703, 707, and 706 all have the same size driver arrays. They have 6.5" woofers, and 3.25" midrange drivers.
    The 705 and 704c clearly have different drivers, and seem matched to go together.
    The 707 seems matched for the 706c.
    I have never owned any of them besides the 703, but that's just what I see from looking at the marketing lineup.
    F1nut Posts: 51,898
    Yes, closed out.
    F1nut Posts: 51,898
    edited June 2019
    Flawed logic. The center is the most important and timbre matching (the tweeter mainly) matter the most for the front 3.
  • kharp1
    kharp1 Posts: 3,453
    What are your room dimensions??? VERY IMPORTANT PIECE OF THE PUZZLE.
  • F1nut wrote: »
    What would you recommend then, oh wise one? How would anything from the LsiM lineup trump the 707 and 706c front stage?
  • kharp1 wrote: »
    15" wide, 16" deep, 10" ceiling. Left wall is open bar to the kitchen area
    F1nut Posts: 51,898
    That is not a big room. The largest speaker isn't always the best choice, but I can tell you're going to get them regardless just don't say I didn't try to steer you in the right direction. The 705, heck even the 703 would be plenty.
  • kharp1
    kharp1 Posts: 3,453
    The 705 would be my choice as well.
  • WLDock
    WLDock Posts: 3,073
    edited June 2019
    kharp1 wrote: »
    The 707 / 706 addition will run $2600 alone. How does the idea of five 703's sound to you? It does not get much better than 5 identical speakers for HT if you can make them work in your room?
    The 703 is a fun speaker that I liked better than some Chane A3rx-c towers I had.
    https://us.v-cdn.net/5021930/uploads/editor/7l/yur468i9irzh.jpg
    For about $3000 I think you could have it all and not miss or want for much more in your medium sized 2400 cu ft room.
    3 x 703 = $1125
    5 x Monolith by Monoprice speaker stands = $300-$350 ($60-$70 each)
    Good value, heavy duty, can be filled and have a large 8.5" x 6" top plate, 75 lbs weight limit to deal with the 8.81" x 14.56" base , 29.6 lbs 703's!
    1 x HSU VTF-3 MK5 HP 15" = $865 shipped
    1 x Used B&K 7250 SII 5 ch (200W/ch) amp - $600
    https://www.usaudiomart.com/details/649526324-bampk-7250-series-ii-5-channel-amp/
    1 x Used Furman, Belkin PureAV, Panamax power conditioner (eBay, usaudiomart) - $80-$300
    Post edited by WLDock on
  • rooftop59
    I like @WLDock's suggestion a lot! That would be one ROCKING home theater, and would also pump out some sweet two channel music...
    Game Room 5.1.4:
    Bedroom 2.1
