Speaking of linear power supplies
mhardy6647
mhardy6647 Posts: 33,046
edited May 2019 in Electronics
I went to NEAR-Fest (https://near-fest.com/ ) last weekend with a mission. My mission (which I chose to accept ;) ) -- to find a decent-quality, fairly robust DC linear power supply, ideally a cheap one.
Well... there was no dearth of power supplies of all shapes and sizes. One vendor had a whole stack of very decent looking ex-lab DC power supplies at what looked like reasonable prices. One slightly homely example caught my eyes. Dual, variable 24 VDC supplies @ 2.5 amps. A little less oompf than I was hoping for, but the price made up for that -- 15 smackers.
The guy who sold it to me said it worked fine -- the only issue was that the mounting bezels for the two meters were... well... not present. I figured a little double-stick tape could provide a simple if not terribly elegant solution... so home with me it came.
Finally got 'round to smoke testing it today. It definitely works -- next step, of course, take a look at the output on a 'scope (or just hook something to it and see how quiet it is -- or isn't).
To paraphrase Crocodile Dundee
That's not a power supply.
This is a power supply.
33943321368_709a00d16b_b.jpgDSC_4595 (2) by Mark Hardy, on Flickr
  • codycatalist
    codycatalist Posts: 2,662
    That thing is BEEFY!
  • motorstereo
    motorstereo Posts: 2,052
    That would be similar to me using my mc1201's on my khorns.......just a wee bit of overkill :)
  • verb
    verb Posts: 10,176
    So Mark I’m wondering if my little PASS mono’s would benefit from the same. Any suggestions? 19v, not sure of the current requirement.
    I would think so, yes. I am thinking about trying this HP with the ACA that is (still) here, in fact. The one here is running on two Dell laptop bricks -- they're 90 watt P/S, I think. 90 watts at 19 V corresponds to about 4.75 amps, though :|
  • verb
    verb Posts: 10,176
    I’ll run upstairs and check em out. See what their rated at. Thanks Mark!
  • dragon1952
    dragon1952 Posts: 4,894
    I've had great luck with these Chinese R-Core LPS's. I've got 2 exactly like this one, a 5V and a 19V as well as a smaller 9V version without the display. I'm running a NUC with the 19V, an SSD dock with the 5V and a Matrix X-SPDIF 2 with the 9V. Dead quiet and very nice upgrades.
    https://www.ebay.com/itm/100VA-Ultra-low-Noise-100W-LPS-R-core-Linear-power-supply-DC-5V-24V-With-display/132529660801?hash=item1edb622381:g:Zz0AAOSwZlZaQHiF
    2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Inakustik Reference USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
  • kharp1
    kharp1 Posts: 3,453
    No info or knowledge of, nor affiliation with, but saw this over on Klipsch forum:
    https://community.klipsch.com/index.php?/topic/184159-hdplex-200w-linear-power-supply/
  • kharp1
    kharp1 Posts: 3,453
    Little research shows retail of $485, so, not that great a deal. Might take less.
    edited June 2019
    Dollar for dollar, I'd -- humbly* -- suggest that all y'all be lookin' at laboratory DC power supplies from your favorite surplus dealer (or good ol' eBAY). Obviously, some
    rehab might be required, but you'll be looking at extremely high quality, stable, robust and well designed, engineered and built components if you go the Lambda, HP, etc. route. Prices for lowish-voltage supplies are low to cheap, too.
    ______________
    * of course, humbly :#
    edited June 2019
    Clipdat wrote: »
    kharp1 wrote: »
    Coincidentally this was just measured at ASR: https://www.audiosciencereview.com/forum/index.php?threads/review-and-measurements-of-the-hdplex-200w-supply.7713/
    so... in that 'review', the question which was begged -- what does the output of the power supply look like?
    To wit:
    How clean is the DC output?
    How precise are the fixed outputs (or the variable outputs, for that matter)?
    How well regulated is the output voltage as a function of load (current)?
    I mean, those are meaningful parameters, and not difficult to measure -- and directly and both qualitatively and quantitatively comparable to assess this P/S against others (linear or switching).
    Clipdat Posts: 12,606
    Not sure. You should email Amir those questions and post the response here.
  • dragon1952
    I'd be more interested in a competent person doing a listening evaluation rather than just measurements. If measurements were all it took to determine the end result then we'd all be saving a lot of cash :^ /
    edited June 2019
    dragon1952 wrote: »
    Indeed.
    The Seventies (when some, perhaps many, of us, came of hifi age) were rife with a focus on numbers even sometimes at the expense of sound. :(
    And, as in all metrics-based endeavors :/ it's not hard to game the system if all that matters are the quantitative measurements. E.g., tonnes of negative feedback can yield quantitatively low THD, broad, flat bandwidth and high "damping factor" (i.e., low output impedance). The problem is that large amounts of poorly implemented NFB can do way more harm than good -- sometimes quite literally, as in amplifiers that are driven to
    self-destructive ultrasonic oscillation by reactive loads (such as - ahem - Polk Audio's somewhat infamous "Cobra Cables"). :#
    The irony of this Onkyo integrated amplifier brochure was completely lost on me when I was amplifier shoppin' in 1977-78.
    12017183446_78b4c69b64_b.jpgonkyo by Mark Hardy, on Flickr
    Full disclosure - the A-5 and A-7 were actually pretty darned nice amplifiers, silly ad copy notwithstanding :p
    Legendary HH Scott engineer Daniel von Recklingshausen hit the nail on the head with his oft-quoted quip:
    If it measures good and sounds bad, -- it is bad. If it sounds good and measures bad, -- you've measured the wrong thing.
    http://hhscott.com/vonrecklinghausen.htm
  • dragon1952
    Yes. I remember when I was stationed in Germany in '76-'79 which was right about when the spec wars began. I remember agonizing over the spec sheets of various receivers when I should have just trusted my ears.
    edited June 2019
    dragon1952 wrote: »
    Yeah, I did, too -- fortunately, I also listened a lot, too.
    Perhaps even more fortunately, some of the stuff that measured well also sounded good.
    As a strictly editorial aside: the more of those "Audio Science Review" things I read, the more I wonder if it's not simply a mammoth put-on; a parody of the objectivists (who are, needless to say, low-hangin' fruit for parody).
    E.g., harping on signal to noise ratio -- Folks like me who use truly high-sensitivity loudspeakers might stand to hear a difference between SINAD of, say, 110 and 120 dB -- folks listening through today's fashionable mid-80s dB/watt at 1 meter loudspeakers... not so much.
    And THD as a surrogate for sound quality? Typical dynamic loudspeakers (cones, domes, planars, and whatnot) have output THD, particularly in the bass, on the order of several percent. If one hears a difference between an amp with, say, 0.01% and 0.1% THD on a real-world loudspeaker, it's probably not the difference in amplifier THD that one is hearing.
    THD is easy to measure but pretty much unrelated to sound quality.
    The spectrum of harmonic distortion components produced by an amplifier does have important sonic consequences -- but that ain't what total harmonic distortion measures, of course.
    B)
    You could look it up, as they say :)
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Dollar for dollar, I'd -- humbly* -- suggest that all y'all be lookin' at laboratory DC power supplies from your favorite surplus dealer (or good ol' eBAY). Obviously, some rehab might be required, but you'll be looking at extremely high quality, stable, robust and well designed, engineered and built components if you go the Lambda, HP, etc. route. Prices for lowish-voltage supplies are low to cheap, too.
    ______________
    That's great advice, but for right now, I'll vainly* stick with the aesthetically sleek linear power supplies from the audiophile power supply companies. :)
    _________
    *of course looks matter.
    https://www.youtube.com/watch?v=Lfmp_kZ0ZfE
    F1nut Posts: 49,802
    Amir......LOL.......LMAO......LOL.......
  • CGTIII
    CGTIII Posts: 1,028
    edited June 2019
    Not for 19V or 5V, but for 3, 4.5, 6, 7.5, 9, and 12V up to 2A, this is said to be regulated and linear. Bought one for my DAC after much research. May start using one on my modem and router too.
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
    I think he just might be the Andy Kaufman of audio review(ers).
    Food for thought.
    B)
    edited June 2019
    ______________
    _________
    I do see that point -- but I like the purposeful look of the laboratory.
    Maybe something to do with my upbringing.
    ... oh, and the power switch on the HP P/S did say "on" from the factory; just sayin'.
  • Stonecutter
    ______________
    _________
    I'm not sure what Carly Simon's great song "You're So Vain" has to do with linear power supplies (other than DK's reference to his own "vanity" for preferring "aesthetically sleek power supplies"), but I very much appreciate your posting this You Tube video.
    It brings back a lot of very fine memories of the day . . . ..
    you hit the nail on the head.
    vanity, thy name is power supply.
  • Stonecutter
    Vanity is the power supply of us all.
    To quote Thackeray's ending to the great Victorian novel "Vanity Fair":
    “Ah! Vanitas Vanitatum! Which of us is happy in this world? Which of us has his desire? or, having it, is satisfied?-Come, children, let us shut up the box and the puppets, for our play is played out.”
  • DarqueKnight
    edited June 2019
    On second thought, I see a need for me to invest in one of those homely, variable output, lab grade LPSs for test and evaluation purposes.
    I like your thinking, ol' son...
    B)
