Polk SDA-1A Cabinet Refurbish HELP!
I have a pair of 1As and the pervious owner wasn’t nice to the cabinets. They sound great, but the base of each look terrible and the veneer is chipping. My thoughts were to take on a refurbish project and replace the veneer, but I cannot seem to find any info on the forum. More than likely I suck at searching but for some reason I come up empty. Any help or info would be appreciated!
  • JayMX
    JayMX Posts: 459
    I had a similar situation with a pair I just refurbished with ash veneer. The bases were completely wrecked. So I opted to remove them completely and just install leveling feet into the base of the cabinet. There are a few pics here:
    JayMX wrote: »
    Finally finished with these. Grille cloth has been replaced with the jet black from Speakerworks @Toolfan66 recommended. Great stuff! Was quite a journey. Up for sale. If anyone is interested PM me. Probably not worth it to ship, but I do travel from Salt Lake City to Boise Idaho or south to Las Vegas from time to time.
    Thanks to all for your help and suggestions!
    Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL (198’s), R100's, R200’s, R300 🤩
    Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5B (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (4x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA1(mod to “a” & SL1000 Wuhan mod), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
  • Joshwest90
    Joshwest90 Posts: 109
    JayMX wrote: »
    JayMX wrote: »
    Those look great! That’s what I’m looking at doing is pulling the veneer sanding down and re applying new veneer. Where did you get the veneer? Any tips/tricks? Any tutorials?
  • JayMX
    JayMX Posts: 459
    I get my veneer from MacBeath because they’re local, but they have several locations and they ship:
    https://www.macbeath.com/products/108234-veneer
    You can look over a couple of the veneering projects I’ve posted here:
    https://forum.polkaudio.com/discussion/177885/monitor-7-refresh
    https://forum.polkaudio.com/discussion/181226/making-monitor-10s-great-again
    https://forum.polkaudio.com/discussion/183831/sda1b-or-early-c-opinions
    The process is pretty simple. Detailed in the threads above. I use contact cement on the surfaces of the cabinet and the veneer with good results. Others have used veneer with adhesive backing. Use dowels to hold the veneer off the surface as you adhere. Use a roller to squish it all together, then lots of weight for 24 hours to ensure a good bond. Also I learned the hard way that it has to be warm in the space where you’re working. I did some pieces at 50degs F and they didn’t laminate well, no matter how much weight I put on them. I purchased a smaller trimming router which works better/is less cumbersome for the tight spaces (inside driver and port openings).
    Very fun and rewarding. Pm me if you have any questions! Happy to help!
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,806
    edited May 2019
    I didn't see your earlier thread. Those look amazing. I would have never thought ash would that great. Thanks for posting again.
    Your work is impeccable!!
    I returned to the original thread and I did see part of it - the KG4 part evidently.
    Post edited by BlueBirdMusic on
    Harry / Marietta GA
  • Joshwest90
    edited June 2019
    Little bit of the progress photos
  • Faustin
    Faustin Posts: 1,151
    Go, go, go, goooooo! You should be able to remove the lower "kick plate" to make it easier to work on. I think "IIRC" it is screwed in from the inside of the cabinet. Once done, I am sure you will be glad you went through all of the work.
  • Joshwest90
    Faustin wrote: »
    I’ll have to look into that. I was wondering how it came off. I was going to rebuild the bottoms as well and put a run of felt along the bottom for sound deadening attempts
    F1nut Posts: 51,936
    Felt.....no. Put spikes on the bottom.
  • Joshwest90
    They are currently on wood floors. Will spikes damage the flooring?
    F1nut Posts: 51,936
    Use spike floor discs.
  • Joshwest90
    edited June 2019
    @F1nut ok ill look into it! @pitdogg2 @Schurkey On the cross over aspect.. I am going with the Clarity PX capacitors. I cannot seem to find the 27 micro farad capacitor required. Any idea where to find these?
  • Joshwest90
    ok so that was my next question. it doesnt matter to mix capacitor brands? As long as the values are the same?
    F1nut Posts: 51,936
    Try Sonicap, they have every value you need and sound great.
  • verb
    verb Posts: 10,176
    Looking good @Joshwest90 making great progress! You are inspiring me to get off my arse and finish a 1C project that has been idle for some time now! :smile:
  • Joshwest90
    verb wrote: »
    Thank you @verb!!
    @pitdogg2 @F1nut @Schurkey @Faustin @JayMX
    For the caps I went with Clarity PX except for the big 27mfd I went with Jantzen Audio
    For the resistors I went with Mills MRA-12
    I plan on removing the two polyswitch and putting a 0.5ohm resistor in its place.
    Looking into the dimensional tweeter removal is where I have a question. From what I read, the dimensional tweeter is the outermost tweeter. If that is removed is there a sticky somewhere that described this process? I was considering doing so because removing one from each speaker would allow me to upgrade to the RD0194 from Polk. My fiancé won’t notice 80.00 or say much about that but 160 she would haha. Is there a huge difference removing the dimensional tweeter and going with the upgraded tweeter?
    F1nut Posts: 51,936
    Disconnect the lead wires and secure the ends so the don't short out. Done.
  • Faustin
    Just leave whatever tweeter you currently have installed in the speaker, and as F1nut said just disconnect it and secure the ends.
  • Joshwest90
    Faustin wrote: »
    Ok so there is no need to adjust the circuitry for it then?
    F1nut Posts: 51,936
    No
  • Schurkey
    Schurkey Posts: 2,122
    edited June 2019
    Joshwest90 wrote: »
    There's also no need to buy new caps and resistors for the SDA tweeter section of the crossover.
    In fact, if you just removed the polyswitch for the SDA tweeter, DON'T put a jumper in it's place, the shunt to ground for the SDA tweeter doesn't bleed off power, and the impedance of the speaker goes up just a little.
  • Joshwest90
    Question: while going through all of this it made me stop and question. If they call for a 27 mFd Capacitor and someone used a 25 mfd or a 30 mfd what would happen. I don’t understand what the Capacitor changes.
    F1nut Posts: 51,936
    It would alter the frequency response. Basically, throw the sound off.
  • Joshwest90
    Has anyone ever attempted to play with these crossovers to see if changing Capacitor size would make a difference?
    F1nut Posts: 51,936
    I'm sure someone, somewhere has. There's no question that changing the value of a component will alter the sound. That you can take to the bank.
  • westmassguy
    westmassguy Posts: 6,850
    Joshwest90 wrote: »
    The guys that designed these forgot what most of us know. They were/are pretty smart. If you can't find a 27uf, use a 12uf and a 15uf in parallel.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
