AQ Rocket 33
Hello,
Just scored a set off CL for $100. The are the bi-wire rocket 33.
Should I use them in the stock bi-wire or change them to full range.
    pitdogg2 Posts: 27,255
    It you have 4 binding post on each speaker use them.
  • mrloren
    mrloren Posts: 2,474
    Yeah, I think I might just use them in bi-wire.
    I can't figure out how to get the AQ stock banana off. It's pressed on some how and no set screw nothing I can see on how to remove the cover.
    mrloren wrote: »
    Cold welded with 10 tons of pressure. Cutting them is the only way I know.
    Do not go to that extreme..... yet.
  • mrloren
    mrloren wrote: »
    No it's the plastic cover I can't figure how to get off. the banana's under are set screwed.
    I emailed AQ see if they will assist at all.
    edited May 2019
    FIRE
    lol
    Have you tried unscrewing? Maybe its just the interconnects that are cold welded. I'm sorry i thought that was across the board from factory.
    They are pretty responsive I've called and emailed
  • mrloren
    it looks like the plastic cover is pressed on somehow. I'll see what they say if the respond tomorrow. If not I will cut and put on some sure grip 300 connectors.
    If I do have to cut and replace the speaker end banana's I'll be into Rocket 33 for $140 not bad
    F1nut Posts: 51,962
    Pffft....gots me a Rocket 88.
  • mrloren
    awe man, F1Nut broke wind
    F1nut Posts: 51,962
    Wafted all the way out there, eh
    nooshinjohn Posts: 25,991
    edited May 2019
    Hot Rod LINCOLN, and a Rocket in my Pocket!
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited May 2019
    I’ve got a single Rocket 33 not bi-wire if you need one for a center channel. It’s roughly 5ft.
    Rednedtugent sent it to me a few years back, and I no longer need it. Yours if you want it.
  • joecoulson
    joecoulson Posts: 4,943
  • mrloren
    PM sent and thank you very much.
    The stock banana is crimped/pressed on, impossible to remove. I cut them and made them into full range using AQ SureGrip 300 BFA (there went that gift card).
    I had time to install them today. Nice sound with a more smooth top end. A tad warmer with a smig better mid's. Rush 2112 will be tomorrow, the true test for me.
    Cheers
    L
  • mantis
    mantis Posts: 17,557
    The Rocket 33's are really nice speaker wires. I have a few pairs of them myself. I also have Rocket 44's which my entire theater system is wired in.
    Dan
  • jeremymarcinko
    edited May 2019
    mrloren wrote: »
    Cheers
    L
    Replied.
    I’ll send it as ASAP as possible. :)
  • mrloren
    mrloren wrote: »
    Cheers
    L
    Replied.
    You're awesome thank you,
    Had the time for some good listening today. Rush 2112 Pink Floyd WYWH (SACD) and Heart Dog and Butterfly. Just fantastic. such smooth highs with a punchy mid bass. Vocals come through very clear.
    2112 Overture goes all over the place sound wise. not once @ -15db did it seem to be screaming or harsh.
  • mrloren
    This morning I did the A/B test with Type-4. I changed the right speaker back while everyone was asleep. While we were having our breakfast I played some Angus and Julia Stone. Wow imaging was way off as with the sound. Everyone was like what the heck what did you do? I let it play for a bit then went to some Elton... oh no it sounded way off. Left speaker had better mids with a nice soft high end. Right speaker was flatter with a crisper high, mids not as punchy. I changed it back to the rocket 33 and put Elton back on. Two aerospace engineers wife and son all said the rocket sounds way better... so it's not just me.
  • mdaudioguy
    mdaudioguy Posts: 5,164
    Aerospace engineers have better ears? Or are they just partial to rockets??
  • Joey_V
    Joey_V Posts: 8,603
    Not sure how aerospace engineers hear better... but I will agree, rockets beat type 4
  • Joey_V
    Joey_V Posts: 8,603
    Friend has rocket 88 and then borrowed my Aspens. He asked if I was selling them. Haha
  • mrloren
    mdaudioguy wrote: »
    Well they both went through high school and college playing in several Orchestra's. That plus their level of intelligence gives me a better opinion.
    I'm into these for less that $200 and am going to enjoy them for a long time.
  • mrloren
    @jeremymarcinko sent me a short (5') for my canter speaker. What a guy.
    We binged the last 1/2 of True Detective last night. Talk about taming a CSi-A6. Vocals deeper cleaner and smoother.
    Hmm Venom has a great vocal track, maybe tonight. I still need to run Audyssey again.
    Cheers
    Loren
