Small Form Factor Power Amp - Suggestions?
verb
verb Posts: 10,176
edited May 2019 in 2 Channel Audio
So I'm looking to upgrade my office rig.
Currently I'm running a Marantz CD-1 and the matching AMP-1, which I love. And a pair of Acoustic Technologies single driver floor standing speakers, with a SVS PB12 Plus sub. I am really happy with this setup, but:
I recently upgraded my DAC (NS Intenso), and tube pre-amp (EAR 834L) downstairs in the basement rig. I would like to use these upstairs in the office, both are small form factor, and they are just too nice to just sit on the shelf! :smile:
Any suggestions for a small form factor amp? Even monoblocks would work.
Found this thread on Audio Karma, for reference. Any insight on those suggestions would be helpful. As always, my fellow Polkies! :smile:
Yep, for @DSkip, Dayens Ampino monoblocks are mentioned! :smile:
https://audiokarma.org/forums/index.php?threads/awesome-small-form-factor-amps.707145/
To start, when I was getting my read on about McCormack, I found this little heater:
McCormack Micro Power Drive!
And a pair of Muscial Fidelity Monoblocks! These look crazy!
Thank you all in advance!
Post edited by verb on
«13
  • codycatalist
    codycatalist Posts: 2,662
    edited May 2019
    PS Audio Sprout?
    It is attractive and quite small. It has a sub out and seems to allow you to use a separate preamp with the "Analog In, Analog Out" options on the back.
    Also the Nelson Pass Amp Camp Amp comes to mind.
    The Amp Camp Amp comes as either a 2 channel or monoblock.
  • verb
    verb Posts: 10,176
    Thanks brother! The PASS looks cool! I looked at the Sprout, but I'm really looking for just a power amp, as I got the EAR pre! :smile:
    mhardy6647 Posts: 34,994
    edited May 2019
    verb wrote: »
    In re: the Pass Amp Camp Amp (ACA):
    The ACA is quite nice, but also low power, and also Class A (i.e., generates quite a bit of heat). It may be recalled that our own @ALL212 built -- umm -- some of these. One of them, out of the kindness and karmic generosity of an unnamed Polk forums member, has been on an extended visit at my house :)
    The one here is the original morph of the ACA, @ ca. 6 wpc, but was built as a stereo amp with active cooling and Bottlehead-style form factor.
    I was curious about these amps because the philosophy and the performance are somewhat akin to a SE 2A3 amplifier. I can say that a 2A3 amp does better the ACA in terms of real, flesh-and-blood liquidity in the midrange, but the ACA is absolutely in the fight (i.e., not embarrassed in a head-to-head comparison with a decent-quality 2A3 amp) and is a fraction of the cost (probably ca. a third, comparing kit/DIY to kit/DIY). Bass performance of the ACA might even be a tad better.
    47746467802_f53b3e0aa0_b.jpgDSC_4537 (3) by Mark Hardy, on Flickr
    EDIT: hmm -- one of those Bee-nanner plugs isn't exactly fully seated on the left channel output of that amplifier, now, is it? :#
  • rooftop59
    rooftop59 Posts: 8,121
    Parasound z amp but it’s not exactly high end...
    Game Room 5.1.4:
    Bedroom 2.1
  • kharp1
    kharp1 Posts: 3,453
    Hey Verb, I have a pair of the mono's that I got at LSAF 2 years ago on my inaugural visit. I'll send you a PM.
    edited May 2019
    Maybe the famous/infamous Carver Cube would be a good choice for you, @Verb? :)
    http://www.carversound.com/carver-amplifiers/m-400t/
    (borrowed images)
  • izafar
    izafar Posts: 819
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
  • GlennDog
    GlennDog Posts: 3,152
    verb wrote: »
    Mono blocks, you say? Small form factor?
    These generate zero heat and are stackable . . .
    From AA
    “The EVS 500M is our super high powered ICEpower® mono block amps. These amps use ®ICEpowers most powerful and best module (the 1000ASP) that puts out over 550 watts into 8 ohms and over 1100 watts into 4 ohms. These amps will redefine value in high powered amps. The mono block chassis are 8 inches wide, 12 inches deep and 3 inches tall. They use the same feet, input jacks and binding post bypass system as described above. A pair of them can easily sit next to each other on a shelf. The amps weigh 7.5lbs. each”
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • honestaquarian
    honestaquarian Posts: 3,260
    As soon as I saw this I KNEW the whole Carver cube debate would begin anew (again)🤦🏼‍♂️
  • verb
    verb Posts: 10,176
    Anyone have experience with Bel Canto?
  • verb
    verb Posts: 10,176
    GlennDog wrote: »
    verb wrote: »
    From AA
    Are you selling yours? :smile:
  • DoneandGone
    DoneandGone Posts: 74
    How about the new Schiit Vidar, and if you fancy a little psuedo Class A, the Aegir.
    They are on my radar.
    Audio Room
    PS Audio Perfectwave DAC MK2, Bridge 1 streaming perfectly now B)
    Marantz SM-11S1
    Foundation Research LC2
    Kef XQ1 bookshelves
    Dual Goldenear Forcefield 3 Subs
    PS Audio receptacle
    3 PS Audio Noise Harvesters
    PS Audio power, interconnects and speaker cables
    Homemade sound absorption
    Lots of blocks for weight and a red single listening chair
  • DoneandGone
    Audio Room
    Marantz SM-11S1
    Kef XQ1 bookshelves
    PS Audio receptacle
    tonyb Posts: 33,072
    edited May 2019
    verb wrote: »
    Not personally, but I have heard a few pieces of theirs. Their house sound , to my ears, trends to the more sterile side of things. Just my opinion there.
    So does the McCormack micro, not exactly Steve's best foot forward.
    edited May 2019
    In case it wasn't obvious, the Carver "suggestion" was a joke (as evidenced by the little smiley in the post) -- those little cubes were famous (even more so than the legendary Flame Linear 700B) for self-immolation.
  • codycatalist
    What's the sensitivity of those speakers verb? I can't seem to find it online but being a small FR driver I imagine it's high.
  • verb
    verb Posts: 10,176
    Good question! Checking, but I found this. Pretty low power requirements.
  • verb
    verb Posts: 10,176
    Not obvious to me, but what do I know! Now I get it! Trying to burn down Verb's house! Lol! :smile:
  • maxward
    maxward Posts: 1,688
    The Pass ACA is looking good.
  • verb
    verb Posts: 10,176
  • verb
    verb Posts: 10,176
    kharp1 wrote: »
    So, I am continually amazed and delighted about the generosity of our CP members!
    Kerry decided to part with his PASS ACA monoblocks! And I must say, for an absurdly great deal!
    Shout out to Kerry for his generosity!
    Looks like they'll be a good match for my speakers! I'm gonna give em a go, looking forward to it!
    One caveat, if I ever decide to part with em (fat chance :smile: ) Kerry will buy em back to ensure they stay in the CP family! No worries sir! They shall!
    Thanks again Kerry! :smile:
  • verb
    verb Posts: 10,176
    Coming home to Daddy! :smile:
    Clipdat Posts: 13,094
    Attaboy, Kerry!
  • codycatalist
    Glad I made a suggestion that someone took. I don't have experience with those amps but have heard nothing but good things and they seemed to fit your criteria.
  • verb
    verb Posts: 10,176
    Thanks brother! May all your suggestions be heeded! :smile:
  • codycatalist
    verb wrote: »
    Actually most are of lower to midfi equipment. I'm a budget kinda guy ya know lol. Hope it works out and you are in Class A bliss my friend.
    VR3 Posts: 29,425
    Congrats Verb!
    Will be sweet in the office, install them at your feet and they could be little feet warmers in the winter! :)
  • kharp1
    kharp1 Posts: 3,453
    Hope that they're all you could want for that rig.
    Now, who wants to make a deal on a pair on Rosso Siena's???
    EndersShadow Posts: 17,704
    Marvin’s always trying to sell something lol
  • kharp1
    kharp1 Posts: 3,453
    Verb, I'm sensing that you may be a full blown junkie!
