DC Trigger Question
msg
in Electronics
I'm in a situation where I'd like to use a Panamax power management unit with DC trigger to turn on/off the switched receptacles.
Thing is, for this particular setup, I don't have a piece of equipment with DC trigger control to send to the Panamax.
I'm looking for a dummy unit with remote control on/off to pretty much take the place of what a preamp with DC trigger out would do, for example.
Or any other ideas?
Or any other ideas?
Sorry Scott let me get my read on. Hope to help ya out! But, been distracted a bit with my new toy!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Found this. Kindy DIY but there may be some already available.
http://emotivalounge.proboards.com/thread/48825/ir-12v-trigger-rf-projectBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Google
Xantech ac 1
Bought a couple on ebay for 25-30 bucKS
I use one to power on/off an amp via yamaha wxc50 w a trigger output
BkDayens Ampino , Yamaha wxc-50 , Polk SDA 1c’s ( my first love .. ) , Kimber Kable 4TC, Sony 42” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Yamaha wxc-50 , Kimber Kable 4vs , Salk Supercharged Song towers ( difficult choice between these and my family if I had to choose ... 😩 ) , Sony XBR-A8F 65” OLED - DEN , MAIN RIG
PS Audio S300 - sitting in the closet for now …
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sharp 65” TV - PATIO -
Bk - good heads up on a stand-alone. I think that's the opposite direction, but handy nonetheless!
Thanks for the dialog fellas. Was having a hard time thinking of how to actually search this one. The search phrase I was looking for was "remote 12v trigger". Trust me to complicate itSorry Scott let me get my read on. Hope to help ya out! But, been distracted a bit with my new toy!
I disabled signatures. -
Cambridge Audio Streamer baby!
https://forum.polkaudio.com/discussion/186478/well-i-did-it-im-going-digital-cambridge-audio-851n/p1Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Ohh, that. Man I thought that was a week ago!
But I see you just got it. NIIIICCCE!I disabled signatures. -
Yep jumped into the digital rabbit hole!
Glad that trigger will work out for ya. Intriguing idea too! You can get em on ebay for pretty cheap!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Scott, I was thinking you should hook up a horn to your remote control DC trigger project. That way when you turn on your equipment, the horn will chirp as if you are locking your car doors. Maybe hook up some rope lighting, as well, to impress the ladies. You be pimpin'!
