DC Trigger Question
msg
msg Posts: 10,650
I'm in a situation where I'd like to use a Panamax power management unit with DC trigger to turn on/off the switched receptacles.
Thing is, for this particular setup, I don't have a piece of equipment with DC trigger control to send to the Panamax.
I'm looking for a dummy unit with remote control on/off to pretty much take the place of what a preamp with DC trigger out would do, for example.
Or any other ideas?
  • verb
    verb Posts: 10,176
    Sorry Scott let me get my read on. Hope to help ya out! But, been distracted a bit with my new toy! :smile:
  • verb
    verb Posts: 10,176
    Found this. Kindy DIY but there may be some already available.
    http://emotivalounge.proboards.com/thread/48825/ir-12v-trigger-rf-project
  • verb
    verb Posts: 10,176
  • gyosa
    gyosa Posts: 770
    Google
    Xantech ac 1
    Bought a couple on ebay for 25-30 bucKS
    I use one to power on/off an amp via yamaha wxc50 w a trigger output
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
    Clipdat Posts: 13,107
    msg wrote: »
    Or any other ideas?
    Turn the equipment on and off manually.
    msg Posts: 10,650
    edited May 2019
    verb wrote: »
    Ahh, yes, something like this should work nicely, thanks Dave.
    Bk - good heads up on a stand-alone. I think that's the opposite direction, but handy nonetheless!
    Thanks for the dialog fellas. Was having a hard time thinking of how to actually search this one. The search phrase I was looking for was "remote 12v trigger". Trust me to complicate it :)
    verb wrote: »
    What's the new toy, Dave?
  • verb
    verb Posts: 10,176
    msg Posts: 10,650
    edited May 2019
    Ohh, that. Man I thought that was a week ago!
    But I see you just got it. NIIIICCCE!
  • verb
    verb Posts: 10,176
    msg wrote: »
    Yep jumped into the digital rabbit hole!
    Glad that trigger will work out for ya. Intriguing idea too! You can get em on ebay for pretty cheap! :smile:
  • Hermitism
    Hermitism Posts: 4,353
    Scott, I was thinking you should hook up a horn to your remote control DC trigger project. That way when you turn on your equipment, the horn will chirp as if you are locking your car doors. Maybe hook up some rope lighting, as well, to impress the ladies. You be pimpin'!
