Question about subwoofer: pair or 1 really good one?
13»
  • Joey_V
    Joey_V Posts: 8,600
    Lot of good points on this thread.
    I suppose subs from the less commercialized makers can produce more bang for the buck.
    I do know I need an outboard crossover to really get the sub to blend perfectly. That will have to be the JL Audio CR1.
    Special thx to WLD for his detailed posts
  • tratliff
    tratliff Posts: 1,793
    You can't go wrong with the JL. Let us know how it works out.
  • rpf65
    rpf65 Posts: 2,127
    tratliff wrote: »
    He can if he tries to sneak one into the house without permission.
  • Joey_V
    Joey_V Posts: 8,600
    I have to run it by the wife.
    I hope the proposal for the sub gets approved, I’m hoping this is the year I introduce a fault line in the neighborhood.
    pitdogg2 Posts: 27,064
    Joey_V wrote: »
    Better make it a "Drive by"
  • WLDock
    WLDock Posts: 3,073
    Joey_V wrote: »
    Yes, adding a crossover between the mains and subs is the proper way to do it...especially at your level.
    http://www.acousticfrontiers.com/three-ways-to-add-a-subwoofer-crossover-to-your-two-channel-system/
    No problem about the info. Whatever your budget, bass is a different beast than mains and being informed is the only way to get the most for your money.
    audioluvr Posts: 5,920
    How about no sub? Problem solved!
    audioluvr wrote: »
    Turn in your audio card and politely leave the building
    :D:D:D
  • WLDock
    WLDock Posts: 3,073
    edited May 2019
    audioluvr wrote: »
    If I had deep pockets like Joey and wanted to go no sub, these would do! :)
    Vaper Audio Perfect Storm White
    https://www.vaporsound.com/speakers/perfect-storm/
    Drivers Used
    -RAAL 140-15D Amorphous Core Tweeter with silver/gold Transformer winding
    -8.5″ Accuton custom Vapor Audio exclusive lower midrange
    -2" Accuton Cell C51 upper midrange
    -15+″ Sandwich Cone Audio Technology 15F woofer
    Cabinet Tuning
    -10:1 Tapering Transmission Line, slot ported, 20hz tune
    Freq Response: 16 – 38,500hz +/-3db, 24 – 26,000 hz +/- 1.5db
    Nominal Impedance: 8 ohms
    Sensitivity: 94 db
    Recommended Power: 8-500 watts via Tube Amp / 15-500 watts via Solid State Amp
    Weight and Dimensions: 450 pounds /64″ Height x 32″ Deep x 20″ Max Width
    Crossover Details: Asymmetric slopes with crossover points of 300hz, 1000hz, and 2300hz
    image.php?id=140028
    image.php?id=140029
    image.php?id=140030
  • maxward
    maxward Posts: 1,698
    Just read a good article in Positive Feedback Online which talks about subwoofer integration. https://positive-feedback.com/audio-discourse/simple-subwoofer-setup/
  • Joey_V
    Joey_V Posts: 8,600
    Thank you
